Unexpected Ice!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CaptainBart45, Jan 9, 2024.
  1. Jan 9, 2024 at 10:07 PM
    CaptainBart45
    CaptainBart45 [OP] Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    I know the best way to drive on ice is not to drive on ice. Last week I hit a patch of ice at about 60 mph while accelerating onto the interstate. Last thought in my mind is ice out here in the desert where a cold winter day is 50 degrees or so. Anyways, steering into the skid and adding throttle did not result in a positive outcome. I know how to turn the traction, and the stability control off, but the last thought in my mind was I might hit ice. I guess I am gonna have to re learn how to drive in slippery conditions. Or, just turn the traction, braking, control off every time I feel a nip in the air. No harm done, I came to rest at least 1/2 inch from the big rigs blowing by on the I 10.
  2. Jan 9, 2024 at 10:15 PM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    o_O If you spun out and lost the back end while accelerating, you need even more traction control than they gave you from factory. Feather the pedal, son.
    50Buck, mic_sierra, Junkhead and 6 others like this.
  3. Jan 10, 2024 at 2:58 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    The temp gauge on the dash is your best friend. Turning off traction control is the worst thing you can do. One can’t react fast enough when you hit black ice.
    Chew, 50Buck, Junkhead and 5 others like this.
  4. Jan 10, 2024 at 3:20 AM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    black ice is the most dangerous condition u can drive on u can be the most experienced driver and have the best tires and it still won’t make a difference .the only thing u can do is try to control the slide and prevent yourself from crashing . Sounds like u drove away in one piece so be glad u drove away unscathed .
    Chew, Junkhead and musicisevil like this.
  5. Jan 10, 2024 at 3:44 AM
    Schlappesepple
    Schlappesepple Well-Known Member
    Joe
    2020 4Runner ORP
    It's not a dirt track, I think giving it gas is the worst thing you can do.
    Next time, maybe ease off the throttle, and very, very gently keep the front wheels pointed where you want to go. Flipping the wheel around like you're trying to drift is also a near-guarantee to spin out.
    musicisevil and D. Lengua like this.
  6. Jan 10, 2024 at 4:03 AM
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
  7. Jan 10, 2024 at 4:30 AM
    Old goat1914
    Old goat1914 Well-Known Member
    Chicagoland, Indiana
    2016 TRD Sport DCLB 4x4
    You are a lucky man. Ice is impossible. I pounded the sound wall with both ends years ago with a 99 Tacoma on ice on the on-ramp trying to get from 30 to 35. Semi-trucks were doing 40 on the freeway.
  8. Jan 10, 2024 at 5:10 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Yep. Once the ass end goes it does not matter if you left it on or turned it off. Your truck told you "You're on your own" and turned it off for you.
    Maybe practice in the sand?
    rhdsjhn, Junkhead and musicisevil like this.
  9. Jan 10, 2024 at 5:51 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Glad you (and the truck) made it out alive!
    Ice can be very tricky, especially if you aren't expecting it. The type of ice (how slick) plays a huge factor. But in general you want 0 pedal inputs, gas or brake, and steer into it. If you need to stop ease into very light brake pressure.
    musicisevil and RedWings44 like this.
  10. Jan 10, 2024 at 6:00 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Power is the enemy and skidding is the enemy. Just let off the gas if you're sliding until you regain control, or at least control enough to feel comfortable enough to accelerate. Then it's a very light touch. Black ice is probably the worst because you don't know it is there, but nevertheless the same principles apply. FWIW I used to drive a Zamboni for work. Those things generally have studs but even those only go so far. Being gentle is your friend. Pretend you're hitting the throttle with an egg between your foot and gas pedal if you have to.
    musicisevil likes this.
  11. Jan 10, 2024 at 6:09 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    Really good advice so far. I am wondering if a Tacoma that was driven and parked on black ice could get itself off the ice using Crawl Control?
  12. Jan 10, 2024 at 6:24 AM
    Trail Limo
    Trail Limo Well-Known Member
    Minnesota ice driver here. If you do start to spin the best thing to do is ease off the gas so that the back end can hopefully get some traction then countersteer into the skid again to try to regain traction and control.
    The traction control and stability control on the truck is surprisingly good. After having driven with mine there is no way I would turn it off on ice. This truck is super slippery on ice without it and the stability control does a very good job of maintaining control when there's sufficient traction. When you completely lose traction there's nothing you can do or the truck can do.
  13. Jan 10, 2024 at 6:46 AM
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    In my gen2 I would have loved to turn TC and VSC off. Didn't work well at all and could have been a killer. The gen3 works really well and you're much better off and safer leaving it on.
  14. Jan 10, 2024 at 7:55 AM
    findbrianhere
    findbrianhere Well-Known Member
    Brian
    Bloomington, IN
    2016 Tacoma TRD Off-Road
    2.5" Old Man EMU Lift Add a Leaf Old Man Upper Control Arms 18" Black Rhino Rims 33" Nitto Grapplers Wescott Designs Rock Sliders Uptop Overland Alpha Cab Warren Synthetic Winch in-bumper Borla Exhaust Nitro 5.29 gears Genesis dual battery Morimoto headlights/taillights Injen Cold Air Intake
    I'm in Indiana and we actually have a lot of black ice out this morning. In my experience, if it's a large sheet, you're kinda just left with wherever your momentum takes you. But if it's broken I find getting off gas completely and gently pressing brake as to gingerly slow yourself down and avoid throwing yourself into a different direction if a wheel catches.. That's worked for me a couple times though I think the response to black ice is situational and often doomed to begin with.
  15. Jan 10, 2024 at 7:57 AM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    Only thing I can add is that the speed at which you encounter the surprise ice is also a determining factor for how much control you will have and for how long.
    I encountered almost the exact same situation several years ago in my first gen. Break up, warm days, freezing nights, on ramp under an overpass, black ice on the highway in the shade.
    Hit the icy straight away in the shadow of the bridge doing 55-60 in 2hi trying to get to speed (65 mph). Ass end was out before I could do anything. Foot off the gas, hovering over the brake waiting for traction. Back of the truck went left, right, left and did a 180 across both lanes, winding up on the shoulder facing oncoming traffic on the left side of the highway within maybe 5-10 seconds.
    Point the wheels where you want to go while you’re facing toward, try and keep them straight as you’re rotating on dry pavement. Brake lightly and slowly on ice then hard on pavement.
  16. Jan 10, 2024 at 8:02 AM
    Squirt
    Squirt Pepsi > Coke
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back with a 3in Speedys Snap resonator. J&L catch can. AMP Powersteps
    Why would you give it more throttle?:facepalm:
    Schlappesepple and wilcam47 like this.
  17. Jan 10, 2024 at 8:04 AM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    Same for me, a friend was driving in Indiana. Ended up 90 degrees to the lanes, across 2 lanes. Terrifying is borderline-understatement.
    Acceleration does not help when driving on top of the snow (moving between lanes over those humps) or on ice.
    musicisevil[QUOTED] likes this.
  18. Jan 10, 2024 at 8:04 AM
    eurowner
    eurowner Duke Sky
    Scoty
    Canadian Caber and musicisevil like this.
  19. Jan 10, 2024 at 8:07 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    From my experience with icy roads, your best bet is to let the truck do it's thing, ease off the throttle.... The Stability control will start applying the brakes to control the skid. By applying the throttle you override the Stability control and make things worse. A new vehicle is a learning experience for us stuck our way older drivers. Applying throttle is not the best way anymore.
  20. Jan 10, 2024 at 8:09 AM
    eurowner
    eurowner Duke Sky
    Scoty
    Absolutely correct.
