unexpected shut down
Discussion in '1st Gen. Tacomas (1995-2004)' started by 20tacoma02, Mar 6, 2017.
  1. Mar 6, 2017 at 3:18 PM
    20tacoma02
    20tacoma02 [OP] Member
    Jared
    2002 tacoma 5-speed
    so i have a 2.7l 5-speed that shuts down while driving down the road. i was driving down the road at about 50-60 and both the battery and oil light began to flicker. when i dropped it in neutral the rpms dropped and the truck shut down. i noticed some milky/frothy oil at the top of the oil cap and at the PCV. However after the trucked had been sitting for a day i drained about a quart out of the bottom and it looked clean. i replaced the PCV valve without any luck and the problem persisted. the truck isn't overheating but i think this might be a head gasket problem. Could anyone help me out here? id like to find the true problem before i just start tearing down the engine, Thanks.
  2. Mar 6, 2017 at 7:49 PM
    gmr102
    gmr102 Well-Known Member
    Utah County
    Formerly: 2002 Silver Stepside TRD OR Ext Cab V6 Current: 2008 Lexus GX470
    You may have 2 separate issues there. The part about the oil and battery light makes me think you may have a failing alternator. Combined with something else. Any engine codes?
    License2Ill likes this.
  3. Mar 6, 2017 at 8:02 PM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    ^This. Alternator is done for. Small chance you have a bad pos+ cable/ connection. I wouldn't drive it until you check your connections or/& have another ALT in hand. Save yourself a tow ($$).
    cruiserguy likes this.
  4. Mar 6, 2017 at 8:04 PM
    License2Ill
    Ian
    The frothy oil cap is moisture building up in the crankcase from constant short trips.
    cruiserguy and butsack like this.
  5. Mar 6, 2017 at 10:12 PM
    butsack
    butsack Well-Known Member
    SW WA
    1997 Reg cab 3rz auto
    aftermarket cassette player
    check your battery terminal connections before you buy the alternatoro_O
  6. Mar 6, 2017 at 10:18 PM
    20tacoma02
    Jared
    2002 tacoma 5-speed
    sorry, left out the fact there is a new battery and alternator
  7. Mar 6, 2017 at 10:34 PM
    butsack
    SW WA
    so did you check the connections?
  8. Mar 6, 2017 at 10:40 PM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    ^ This. And have you tested the new alternator to make sure it's supplying power? It's not common, but some aftermarket alternators can prematurely fail.
  9. Mar 7, 2017 at 7:02 AM
    Indy
    Indy Master of all I survey.
    I had a band new alt fail in less than 500 feet of driving. 14.6v to 0v during the test drive around the block.
