Unexpected Surprise, Factory Rear Door Speaker Mounts 2013 Access Cab
Discussion in 'Audio & Video' started by Space Junk, Dec 8, 2012.
  1. Mar 15, 2013 at 4:42 PM
    ToyotaTRD
    ToyotaTRD Well-Known Member
    TRD Sport
    Here's another pic
  2. Mar 15, 2013 at 4:49 PM
    wmflyfisher
    wmflyfisher Well-Known Member
    Wes
    PCB, FL
    2010 Sport 4x4
    Where did you buy the PVC board from?
  3. Mar 15, 2013 at 4:54 PM
    ToyotaTRD
    TRD Sport
  4. Mar 15, 2013 at 5:27 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    3/4 x 8 x 8?
    8 inches or 8 feet? If 8 feet, I've got a project that will be perfect for.
  5. Mar 15, 2013 at 7:54 PM
    ToyotaTRD
    TRD Sport
    8 feet long. I think I bought a 6 footer to do the four doors. They have a bunch of different lengths and widths. It's pretty easy to cut and drill. It had a wood grain on one side IIRC.
  6. Apr 29, 2013 at 5:57 PM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    What size did you put in the rear
  7. Apr 29, 2013 at 8:23 PM
    6spd
    6spd Well-Known Member
    san diego
    2023 4x4
    I'm with this guy. your ears aren't back there. and even if you had passengers sitting back there, it wouldn't matter. but if you want to waste some money to fill up those blank holes, do it.
    if you were to spend money on your stereo in steps, I would recommend it in this sequence:
    1. stereo
    2. front speakers and sound deadening material
    3. amp for fronts and possibly sub
    4. subwoofer
    that is just my opinion. I have a dcsb, and I will not be installing new speakers in the rear doors when I upgrade
  8. Oct 11, 2013 at 3:10 PM
    MacDougl
    MacDougl Active Member
    Greenville, Texas
    '10 Access Cab 4x4
    Window visors, fog light mod, bed storage locker locks, aftermarket stereo, lighted 4x4 switch, lighted console
    Ok, are the wires there or do you have to run them to the doors?
  9. Oct 15, 2013 at 10:28 AM
    2009tacomav6
    2009tacomav6 Well-Known Member
    phx AZ
    2012 4x4
    TRD SC TRD Cat Back KMC 17x9 Addicts
    looks sharp!
    I would install new speakers anywhere you want to make it sound good. Adding rear will fill up the space behind you nicely. Good thing you don't have a double cab otherwise you would have one good set up front and a crappy one in back.
  10. Apr 11, 2014 at 9:58 PM
    Dvo
    Dvo Active Member
    Dvo
    Virginia Beach
    '14 ACLB 4x4 Sport
    Painted Skid Plate Tinted 50%F/20%B De-Badged LED interior Wet Okole Seats
    The '14 Access cab is the same, no door speakers in the back! Time to start cutting and install 6.5 alpines.
  11. Apr 11, 2014 at 10:00 PM
    Dvo
    Dvo Active Member
    Dvo
    Virginia Beach
    '14 ACLB 4x4 Sport
    You are my inspiration.
  12. Apr 12, 2014 at 7:18 AM
    tony2018
    tony2018 Well-Known Member
    Rear speakers do make a difference. If everything was wired correctly, with the right amt of juice to power the door speakers than sound quality will be improved. Got a double that had stock head unit but amps, woofers and door speakers all around and the quality was decent. Once I swapped in the 2014 navi unit the quality was so much better. I adjust the woofers down and the infinitys in the rear doors actually so much clearer and the bass was really there compared to the original stock head unit.
    Next on the list is a better line out converter.
  13. Dec 18, 2014 at 8:09 PM
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    Personally, In a car imagining and time alignment are your 2 best friends if you know how to set your sound stage, Sadly not a single SQ competition setup uses rear fill but allot of Home audio and Pro audio( thats set up correctly ) can utilize rear fill adequately depending on the focal point. For our trucks, rear fill is really and i mean really a massive last resort option, even more so with Xcab.
    Spend the money and upgrade them front speakers, quality speakers that can take power. Bridge a class AB amp And feed those front speakers the power they deserve. You won't ever Wonder or think about rear fill!
    Now if you want to use your rear swing doors to include a sub per side thats a different story
  14. Dec 19, 2014 at 6:24 AM
    B737
    B737 Throbbing Member
    Kevin
    Jersey Shore
    2015 Tundra Double Cab Limited
    stock
    THIIIIISSS. rear speakers are a communist plot.
    Those came out clean though.
  15. Jan 8, 2015 at 9:01 PM
    #35
    drscott11
    drscott11 Well-Known Member
    I have a 2012 TRD Sport Access Cab and I have the factory openings in the metal of the rear door's but NOT in the door panel. Why do some years have panels with openings and some without? Will other model year panels fit in a 2012? Seems like a short sighted decision on Toyota's part and very frustrating to boot.
  16. Jan 9, 2015 at 10:43 AM
    #36
    Babs
    Babs Well-Known Member
    Asheville NC
    TRD V6 6spd
    Scratches preinstalled from original owner
    Rears can be good if done appropriately meaning tuned, with proper time alignment. Could be a good spot for mid-bass support. In such a cabin space if crossovers, time alignment and EQ are executed well I imagine the extra drivers could do wonders. This is assuming already a good aftermarket front stage has been done, and some means of adequate all-active processing capabilities, such as a Helix DSP for example or JBL MS-8 which can auto tune it.
  17. Jan 11, 2015 at 6:34 PM
    #37
    drscott11
    Just finished installing 2 pairs of 6.5 Alpine R series separates in the front doors; no rears. It was very tough to fit both pairs in stock locations, literally one snatch hair of clearance on all sides, but it worked. Running 150 watts to each pair and 250 to a single 10" R Series sub. It sounds amazing and is completely stealth.
  18. Jan 28, 2015 at 7:00 AM
    #38
    xtrapsi
    xtrapsi Active Member
    Gregg
    Chincoteague, VA
    12 X-Runner
    TRD Short Shifter Volant Intake w/ Scoop Tri-fold Tonneau Heated Seats Entune with Nav Rockford Fosgate 05-08 Tail lights
    If not, how hard would it be to run the wires for the overhead speakers down to the door?
  19. Feb 17, 2015 at 9:17 AM
    #39
    Babs
    Asheville NC
    TRD V6 6spd
    ^ No.. IMO just run your own to the doors to your amp through the boot. Any decent OFC 14-16 ga I'd think. Leave the stock wiring alone and roll your own with better stuff and without any connectors in the line you might not know about.
  20. Nov 13, 2015 at 2:34 PM
    #40
    SpE3dF0x
    SpE3dF0x MD bound!
    Fox
    San Antonio
    2013 TRD Tacoma Sport
    Nothing its tooo new!
    I know "old post" but, I too have a ACCESS CAB wondered if anyone has tried this? Older 2005-2009 Access can door panels and line them up. They pretty much look the same WITH panels cut already?
