Unexplicable Power Boost
Discussion in '4 Cylinder' started by DanGer, Feb 15, 2009.
  1. Feb 15, 2009 at 9:58 PM
    DanGer
    DanGer [OP] Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    Or I hope to get it explained. So recently I have observed a VERY noticable powerboost in my 2007 4 banger. I bought it in June with mid 19k miles on it. The only thing I can think to trace it to is I took out the secondary air filter shortly after I got it. Now it is about 23k miles so I'm thinking it might have adjusted to the modification on the intake? Anyone wanna toss in their $.02?
  2. Feb 15, 2009 at 10:06 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    How sure about you about the power boost? It could be that you could have gotten better throttle response which you thought was a boost in power.
  3. Feb 15, 2009 at 10:13 PM
    Soundwave
    Soundwave Well-Known Member
    B.C. Canada
    2013 TRD sport Double Cab 4x4
    OEM Roof rack
    Please describe the power increase your experiencing?
  4. Feb 15, 2009 at 10:15 PM
    DanGer
    That could be very true because I do not know the exact difference. Now that you mention it, it seems that is the case. I notice it when i let the clutch out in first, but I have not done any highway driving since noticing it at higher RPMs.
    Could it also be that the computer readjusted to my driving habits from the previous owner?
  5. Feb 15, 2009 at 10:19 PM
    DanGer
    mostly taking off from a dead stop. I have a manual tranny so when I let it out the same way I have always done and it pulls a little harder and accelerates quicker. I'll test it out accelerating at higher speeds to give you a better idea.
  6. Feb 15, 2009 at 10:21 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    Not sure if the computer knows one driver from the next, it knows fuel/air mixture and adjusts for that. Maybe that is what you are asking? With removal of the secondary filter, maybe the engine in getting a little more air and is adjusting for that... just my guess, don't know too much about 2nd gen Tacos.
  7. Feb 15, 2009 at 10:23 PM
    Soundwave
    B.C. Canada
    OEM Roof rack
    It is interesting. I have a 2009 4x4 2.7 with just over 1200kms (800miles) and the more I drive it the peppier it feels as it slowly breaks-in I am assuming? But your 2007 with 19,000miles already should be broken in? Must be something to do with the air filter removal like you say. I still havnt done that to mine yet. I am concerned with voiding the warranty if I remove it. But I really want to!
  8. Feb 15, 2009 at 10:28 PM
    DanGer
    Ya I had heard somewhere that the computer can readjust to a drivers habits. Maybe hearsay but I thought I would toss it out there. The secondary filter is the only cause I can think of.
  9. Feb 15, 2009 at 10:36 PM
    DanGer
    Yes as the one thing I was weary about is if the previous owner broke the engine in properly but the clutch didn't slip and there were no signs of improper care. I had my mechanic at work (a genius with engines) take it for a night and check it out and he couldn't find anything but good with it. in fact he converted his '81 dogde pick up to biodeisel completely out of scratch (quite a feat seeing how he build the converter for the cooking oil on his own out of scratch) He is the only I would trust with it!
    as for your warranty concerns. Just be careful when you drill out the rivets you don't go through the outside casing. whenever you take it in for service you can just pop it back in plus in order to void the warranty toyota has to prove your mod was the exact cause of the problem.
  10. Apr 23, 2009 at 6:58 PM
    jeremiekc
    jeremiekc Well-Known Member
    Jeremie
    Vilseck, Germany
    07 Regular Cab Base Model
    Secondary Air Filter removed, Painted Brake Calipers, AFN Drop in air cleaner, OEM Chrome Bumper, OEM Chrome grilll, OEM Cruise Control, OEM Interval Wipers, Hard Wired Garmin Nuvi 670, X-Runner Rims, Devil Horns, 6000w HID's, Bling Light Fogs with Blue Halo, OEM Bilstein Rear Shocks, 12V Plug in Truck Bed pocket. Debagged, 13" Antennax, Color Matched Satoshi Grill, URD Short Shifter, WeatherTech Floor Mats, PainLess Wiring Switched Fuse Box, Black Sand Pearl X-Runner Badges
    I have an 07 Reg Cab with 10k miles on it and I have noticed occassionaly it will do it. It feels like the computer readjusting. Mine did it with the secondary air filter in and out so I dont think that is the problem. I am going to ask the service guru next time I take it in.
  11. Apr 23, 2009 at 7:04 PM
    DanGer
    sounds like your engine is just breaking itself in, and will continue to do so for a while. mine was over 20K when it happened so IDK
  12. Apr 23, 2009 at 7:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Thats about the milage my 2000 2.7 seemed to settle in.
  13. Apr 23, 2009 at 7:07 PM
    DanGer
    Ya its hard for me to place where mine came from since I bought it with 19k
  14. Apr 24, 2009 at 6:17 AM
    06dak
    06dak Well-Known Member
    Central Ohio
    05 PreRunner SR5 4cyl
    Undercover hard tonneau, Husky front liners
    Boy I can't wait for it to happen to mine!
    I bought it with 19.5k... :)
  15. Apr 24, 2009 at 6:23 AM
    98tacoma27
    Ben
    Not Beech Creek
    It's just the powerbands kicking in.
  16. Apr 24, 2009 at 6:27 AM
    TacticalBacon13
    TacticalBacon13 Sorry for party rockin'
    Dunk
    Beech Creek
    2014 tundra platinum
    baby seat and a muffler
    maybe he should buy a new powerband or get a stronger one:D
    have you ever heard someone refer to the powerband as a part? like oh well i got my new shit on and a new powerband this thing rips so hard now.
  17. Apr 24, 2009 at 6:33 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    They useually give you a new power band when you buy some Type R stickers.
  18. Apr 24, 2009 at 6:56 AM
    98tacoma27
    Ben
    Not Beech Creek
    I thought the Type R stickers were the powerband?
  19. Apr 24, 2009 at 8:00 AM
    wawireguy
    wawireguy Well-Known Member
    In the winter we get oxygenated fuel that lowers power so when spring hits I get a "bigger" powerband, lol! Could be a air temp altitude change also.
  20. Apr 24, 2009 at 8:22 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Not sure. I thought Vtec was the powerband, and Type R made it larger. The ones you have to watch out for are the Type R Vtec SS Hemi GT's
