Unfinished interior of caps.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by anamorphic, Apr 21, 2012.
  1. Apr 21, 2012 at 4:50 PM
    anamorphic
    anamorphic [OP] Well-Known Member
    08 TRD Sport 4x4
    Anyone ever do anything to the inside of their unfinished cap? The white fiberglass is starting to bother me. Thinking about painting it with some roll-on bedliner coating.
    Thoughts?
  2. Apr 21, 2012 at 5:23 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    How bout bed rug material ?
    My cap came with a grey roof liner , I wonder if you could add that on your own
  3. Apr 21, 2012 at 5:28 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Same here. It was only another $150 to get the cloth headliner material.
    Speaker cabinet cloth... black or gray... and a few cans of 3M "90" (77 may not hold up long term) and you're good to go.
  4. Apr 21, 2012 at 5:29 PM
    OZ-T
    Peter North
    British Columbia
    Mine's more like outdoor carpet
  5. Apr 21, 2012 at 5:32 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Probably the same stuff... mine is pretty heavy. Looks and feels like the stuff I used to use on speaker cabinets, but the stuff I've seen on commercial cabinets is thinner.
    But mine were built for road use.
  6. Apr 21, 2012 at 5:36 PM
    anamorphic
    08 TRD Sport 4x4
    I asked my leer dealer if they could install the headliner. They said no and that it's a factory installed option only.
  7. Apr 21, 2012 at 5:44 PM
    OZ-T
    Peter North
    British Columbia
    Here's mine
  8. Apr 21, 2012 at 6:13 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    That's because your cap dealer only has minimum-wage installers that know how to operate a fork lift and how to find the brake light wire.
    They aren't upholstery people and you wouldn't like the result if they did it.
    It CAN be done... just not by the dealer.
    The nice thing about the carpet is it has a certain amount of "give" and stretch. You can use 4 pieces to do the front, sides, and top and working carefully, have no wrinkles or visible seams even though nothing is actually stitched together.
    You should be able to have it done at an upholstery shop for a couple or three hundred bucks.
  9. Apr 22, 2012 at 5:17 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    My last few shells had the liner from the factory. But I have been looking for a used shell, and wondered what to do if I found one without the liner. Thought about taking the time to tape off and paint the inside as you suggested, I know the carpet would be harder to install correctly. Just prep the surface as you would any surface prior to painting and you should be good to go...
  10. Apr 22, 2012 at 5:46 AM
    CantSitStill
    CantSitStill Well-Known Member
    FTR
    CNY
    I got an ARE from a place in Albany, NY a couple years ago. I ordered it with carpeted inside and it came in without. The dealer installed carpet rather than send it back, but like someone else said, I really wasn't that happy with it. I would probably go with some sort of spray on bed liner if I ever get another.
  11. Apr 22, 2012 at 9:04 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    To get someone to do the carpet liner right would cost alot more then painting. I feel if you have a white, or light colored truck the standard white gel coat finish does not look bad, but its too much white for a dark color truck IMO. Also, do not forget having the carpet liner helps with condensation issues inside the the cap the paint will not. If your not camping in it, and its just for looks, just tape off the windows and spray away. This type of surface would be hard to screw up painting, probably look just fine if you cut in with a brush and rolled it out with the rough surface of the fiberglass finish. I vote paint, its cheap, and will look good painted, and will be easier, and something many can do well.
