Unheard of electrical issue...need help?
Discussion in '1st Gen. Tacomas (1995-2004)' started by lucas450r, Nov 7, 2015.
  1. Nov 7, 2015 at 9:49 AM
    lucas450r
    lucas450r [OP] Member
    Indiana
    Deer Hauler
    I have a 97 Tacoma 2.7L. The issue first started as my 10amp gauge fuse kept blowing. I next realized that when the fuse blows the alternator also stops charging the battery. I originally figured it was a voltage regulator/ alternator issue causing the trouble so I replaced the alternator and soon as a backed the truck out of the barn it blew the gauge fuse again and the new alternator quit working? any suggestions would be greatly appreciated.
  2. Nov 7, 2015 at 11:50 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    replace your trailer wiring harness, when they go out they short things out when you hit the brakes.
  3. Nov 7, 2015 at 1:03 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Back up lights can do the same thing.
    You put it in reverse and the fuse opened .
    Might want to check for a shorted switch or wires rubbed through.
