Unholy Leaf Spring noise after Ready Lift install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CaliforniaTaco, Jun 26, 2009.
  1. Jun 26, 2009 at 3:19 PM
    CaliforniaTaco
    CaliforniaTaco [OP] Well-Known Member
    After putting in the leaf spring spacer in my '05 I have this nasty squeak/creak noise in the back suspension - sounds just like my '69 mustang with 40yr old parts. Did I tighten the u-bolts too much or something? Is there anything I can lube back there?
  2. Jun 26, 2009 at 3:24 PM
    CaliforniaTaco
    Good to know I'm not the only one. Just use standard automotive grease (like the kind you pump into zerk fittings)?
  3. Jun 26, 2009 at 3:25 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    Port Hueneme
    15 Ram EcoDiesel
    I've been battling the noise also. Annoying as hell!
  4. Jun 26, 2009 at 3:26 PM
    Monarch
    Monarch Threadkiller
    Kitchener, Ontario
    09 AC 4X4 2.7L 5 speed SR5 barcelona red
    Readylift, Roadmaster, Bushwacker, Pop & Lock, Redline, Weathertech, Crappy Tire
  5. Jun 26, 2009 at 3:27 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you can get a good dry moly spray lube to spray between the leaves....it'll quieten them down and keep them quiet. and it'll repel dust and stuff from getting in and causing the squeak.
  6. Jun 26, 2009 at 3:28 PM
    CaliforniaTaco
    Nah I'm pretty sure they're in there correctly, the arch is the same direction as the rest of the leaf springs.
  7. Jun 26, 2009 at 3:28 PM
    CaliforniaTaco
    awesome - that's my project for the weekend.
    thanks!
  8. Jun 26, 2009 at 3:58 PM
    Monarch
    Kitchener, Ontario
    Sorry about the misunderstanding. I thought you were talking about the 1 inch spacer block, not the add a leaf "AAL". Personally, if I was going to take my springs apart to add a leaf, I would look into teflon liners as well as cleaning the rust off the metal. Grease will just wash off eventually and the noise will come back.
    Peace.
    http://monarchrifle.com/dougs_tacoma.html
  9. Jun 26, 2009 at 6:11 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    I need to do the same, mine are getting annoying as hell.
  10. Jun 26, 2009 at 7:01 PM
    motoretro
    motoretro Well-Known Member
    Michigan
    09 Reg, Cab, 2.7 Four Cyl. manual trans
    Lowes sell a Dupont Teflon dry film product in spray can that I've used on my M/C chain for last 3 years with great results. The spray should allow you get the product into crevices and once its put on it hardens up enough not to get thrown off and it does not attract dust like grease. Might do the job....:wink:
    Motoretro
  11. Jun 26, 2009 at 7:41 PM
    Monarch
    Kitchener, Ontario
    That would explain why the trigger in my Anschutz 1403 stopped working. Thanks, I won't make the same mistake with my Savage 12 F/TR
    Anyone else notice that Ready Lift is the target of the original poster?
