Uni-Ball Lube
Discussion in 'Wheeler's Off-Road' started by YotaDan, May 19, 2010.
  1. May 19, 2010 at 1:44 PM
    YotaDan
    YotaDan [OP] Dan
    Dan
    Oregon
    Now Available:
    Tri-Flow® Superior Dry Lubricant: 5.89[​IMG]
    Tri-Flow® Superior Dry Lubricant is an elite formula created for dry and dusty conditions. The 2oz drip bottle applicator, allows for deep penetration in hard to reach moving parts. Featuring paraffin wax and high-grade petroleum oil to allow the lube to go on wet, but then set up in a dry, 'wax-like' film so it will not attract or absorb grit and grime. Perfect for dry, dirty, dusty conditions, while still providing adequate wet weather performance. Holds up to extreme pressures and resists water wash-off. Provides incredible efficiency without attracting an excessive amount of contaminants. Great for Uni-Ball bearings.
  2. May 19, 2010 at 4:42 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 Mid-Travel 4x4 DCSB 6spd
    Kings Mid Travel, BAMF bed rack, RTT, dual battery, OBA, ARB locker, 4.56 gears
    Oh now this gets posted. I've been experimenting with a bunch of stuff and finally out in some Dupont teflon spray. It's going good on day 2, but if it starts squeeking again, I'll be ordering this stuff.
    Thanks
  3. May 19, 2010 at 4:43 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    Port Hueneme
    15 Ram EcoDiesel
    How come TC says not to lube their uni-balls?
  4. May 19, 2010 at 4:45 PM
    Brunes
    Brunes abides.
    Rotorhead
    Because they don't want you to lube it with the wrong thing. Using WD-40 or other petrol based lubes will damage the uniball lining.
  5. May 19, 2010 at 4:47 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    Port Hueneme
    15 Ram EcoDiesel
    I called them to inquire about lube, and they said no lube needed period. Another member was told the same thing when they called..
  6. May 19, 2010 at 4:49 PM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    The above listed stuff is petroleum too.:notsure:
  7. May 19, 2010 at 4:54 PM
    MJonaGS32
    MJ
    SF Bay Area (East)
    Ok, with all of this stuff posted I have some questions.
    My uniballs stared to squeek really bad when turning. Not knowing anything I put WD40 on them. After they started squeeking again, I tried some dry lube spray stuff from Blaster. They staretd to squeek again and so I then tried this dry lube through Dupont.
    At this point, have I ruined my uniballs? Should I take my UCAs apart to wipe off the uniballs, then relube with this stuff?
  8. May 19, 2010 at 4:55 PM
    Timicha
    Timicha Timicha
    TIM
    Tillamook / Portland , Oregon
    04 White Tacoma
    Fabtech 4 inch lift, tinted windows, diff drop, 33 inch MTZ tires on Raceline Raptor wheels, ELITE OFF-ROAD bumpers and sliders
    can i order this stuff from you on here or do i need to call yu?
  9. May 19, 2010 at 4:57 PM
    Timicha
    Timicha Timicha
    TIM
    04 White Tacoma
    woops didn't notice the order now button haha my bad
  10. May 19, 2010 at 4:57 PM
    Brunes
    Brunes abides.
    Rotorhead
    It's not the base tho. WD-40 is meant to stay wet and greasy. This is designed to dry out and have a waxy feeling. They also trap dirt in them because they stay wet- when this stuff dries it doesn't.
  11. May 19, 2010 at 5:07 PM
    Timicha
    Timicha Timicha
    TIM
    04 White Tacoma
    sweet well i ordered some for my camburgs figured it was only 5 bucks.. why not :p
  12. May 19, 2010 at 5:31 PM
    YotaDan
    YotaDan [OP] Dan
    Dan
    Oregon
    Both Camburg, and Total Chaos recommend to us that customers use a dry teflon lube (Tri-Flow). So we have made that available to the customers. Like someone else said, I think they are worried that people will put the wrong kind of lube on the uni-balls.
  13. Feb 16, 2011 at 11:37 AM
    YotaDan
    YotaDan [OP] Dan
    Dan
    Oregon
    How many people would be intrested in a 14oz Catridge (standard grease gun size) Grease tubes, of a grease that is designed specifically for use with Rubber and Polyurethane?
  14. Feb 16, 2011 at 11:47 AM
    Timicha
    Timicha Timicha
    TIM
    04 White Tacoma
    I may be depending on price
  15. Feb 16, 2011 at 12:02 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    FYI You can buy this stuff at most bike shops.
    I use it on my Mountain bike
    I have a large aerosol can of it also.
  16. Feb 16, 2011 at 1:09 PM
    YotaDan
    YotaDan [OP] Dan
    Dan
    Oregon
    As far as the Tri-Flow lube, it is recommended by both Camburg and Total Chaos to use the DRY lube, for use with the Uni-Balls.
  17. Feb 16, 2011 at 1:26 PM
    YotaDan
    YotaDan [OP] Dan
    Dan
    Oregon
    I know there is a lot of concern with what grease is safe to use on Poly and especially the Factory Natural Rubber. As some greases can damage the bushings.
  18. Feb 16, 2011 at 2:31 PM
    MJonaGS32
    MJ
    SF Bay Area (East)
    I'd be interested depending on price also. I'm currently using a dry lube in the form of a spray can. It lasts for a while but starts to come back. I bet the grease would last a lot longer.
  19. Feb 17, 2011 at 4:18 PM
    JoeTacoma02
    JoeTacoma02 Well-Known Member
    Beaverton, OR
    SWB 05 Double Cab 4x4 TRD Off Road
    Ordered on Monday or Tuesday and got my bottle today Dan. Thanks!
  20. Feb 17, 2011 at 4:29 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    this stuff works good to. Superlube's synthetic teflon(PTFE) based lube in a spray.
