Uniball care?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Iggy, Apr 2, 2015.
  1. Apr 2, 2015 at 10:11 AM
    Iggy
    Iggy [OP] Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    I just called Camburg to check on their uniball maintenance. Besides using triflow to lube them, I wanted to know what to use to clean them. The gal on the phone recommended I use WD-40 to clean them, but I remember specifically a tech before had told me not to ever use WD-40 on the unballs and to use only triflow.
    So what are you guys using to clean the uniballs?
    I also asked about cleaning up the bushing grease, that stuff is sticky! I've tried a rag with acetone to get it off and nothing will remove it.
  2. Apr 2, 2015 at 11:28 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    wipe away the dirt n dust and gunk. and lube with some teflon lube.
  3. Apr 2, 2015 at 11:35 AM
    Iggy
    Northern CA
    Check out the build
    That's what I've been doing, but I wanted to see if I could clean them a bit better than with a rag.
