UNICHIP CAUTION
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tepidy, Dec 4, 2010.
  1. Dec 4, 2010 at 3:11 PM
    Tepidy
    Tepidy [OP] Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    I had a unichip(very expensive)installed in my tundra it worked great for a couple years and then all of a sudden started to throw all my warning lights. Shortly thereafter it started to interfere with the starting of my truck. After several visits to toyota they decided that the chip may be the cause. I left the chip in for a few more weeks until it shut my engine off while I was driving on the highway. Unable to start the truck I removed the elaborate chip and the truck started and ran fine. Wondering if anyone else has had issues with these chips. I sent it back to unichip and months later they sent it back stating there was a loose wire. Installed it and the same shit happened. No more chip. Came close to using one in my tacoma before this happened.
  2. Dec 4, 2010 at 6:19 PM
    TRDKenE
    TRDKenE DAMN GOOD DEAL!!
    Kenny
    Richmond, Virginia
    '10 D-CAB OFF-ROAD 4X4
    TRD CAI, GrillCraft.
    Uni-Chip is gay...they have shitty customer service and they make shitty products..never catch me with one on any vehicle I own
  3. Dec 5, 2010 at 1:39 AM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    you hit that nail on the head TRDkenE. There customer service is a big scam. One thing that I did find out is that all the units are made in south africa. The mapping is done here in USA. I would never use one again.
  4. Dec 5, 2010 at 1:47 AM
    schiz94
    schiz94 Thread Jacker
    Caleb
    Bellingham,WA
    08 Tacoma Reg Cab
    Morimoto Projector Retrofit, alpine cda-105,Wheelskins leather wheel cover, wet okoles,5% tint on back and 24% on front two windows,Debadged tailgate,custom sockmonkey centercap decals, xr rims pced gloss black.
    haha werent you saying that spacer lifts were good the other day?
  5. Dec 5, 2010 at 1:58 AM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    shiz94 we have beaten this dog to death man. here is my last reply that I just made to someone on the last page of that post. Read the whole thing and maybe you will see my point. "the spacer is a top plate spacer and it gives 2" of lift, the actual spacer is only about 1.25" thick. Downward travel is exactly the same as factory travel being that nothing has changed other than lowering the whole unit . Factory ride is exactly the same. Why use only spacer designated to do a total of 2" of lift intead of 3 or 4, this is because the vehicle geometry pretty much stays the same especially if you use a 1" diff drop along with a aal in the rear thus resulting in no undue stress on anything. Somewhere down the line someone convinced everyone that these type of spacers compress springs and tear up ball joints-not true if you stick to this size. Perfect way to go if you are going off road every once in a while (not racing or rock climbing) to clear larger tires (31's). "
  6. Dec 5, 2010 at 2:00 AM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    and shiz your ride looks sweet bro
  7. Dec 5, 2010 at 10:05 AM
    schiz94
    Caleb
    Bellingham,WA
    08 Tacoma Reg Cab
    haha thanks i was just wondering if you were the same user to start that other thread :D
  8. Dec 5, 2010 at 10:19 AM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    no doubt
  9. Dec 5, 2010 at 2:52 PM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    and read my reply...
    well now i know you have no idea what your talking about...
    the aarms have a fixed pivot point. the only way to raise the truck using coil spacers is to rotate those arms...and by rotating those arms what are you doing....LOSING downtravel!! stock the truck has about ~3-4" of downtravel, but when you rotate those arms w/ a spacer, you now only have 0-1" downtravel...its simple math dude.
    by doing this, you will NOT have the same factory ride...
    ok, enough time wasted on someone that obviously has no idea what they are talking about...:D
  10. Dec 5, 2010 at 3:36 PM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    hey yosh2000 let it go man there is more to life than this. Lets move on.
