Unichip dyno (CAI and exhaust)
Discussion in 'Performance and Tuning' started by pamantea, Oct 21, 2010.
  1. Oct 21, 2010 at 11:24 PM
    pamantea
    pamantea [OP] Well-Known Member
    British Columbia, Canada
    TRD Exhaust
    Hey guys,
    I have the TRD exhaust and come the spring I will be getting a CAI. I also want to either add the unichip or the APRX1. I know the price is huge, and both website claim around 30 HP gains. My question is the dyno on unichip website, is that realistic? I mean 258.2 rWHP? Based on our stock 236 showing a 191 HP on dynos predicts roughly a 19% power loss. So with 258.2 rWHP with CAI, CatB exhaust, and unichip, that would be close to 320 HP at the crank. That doesn't add up to me.... 85 HP gained from those three items? What is going on? Is that a real dyno?
    http://www.unichip.us/system/uploads/assets/Dyno Sheets/MY05 Taco.pdf
  2. Oct 22, 2010 at 7:18 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Its more like 50 hp gain. Still alot, and Im sure an "Ideal" condition test.
  3. Oct 22, 2010 at 7:57 AM
    pamantea
    TRD Exhaust
    What do you mean by Ideal?
    Also, I have tried searching but could not find a similar dyno. Do you know/have/ or seen a dyno of a non turbo or SC tacoma with higher amounts of HP?
  4. Oct 22, 2010 at 8:17 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    My truck dynoed at 205 stock. I have seen some higher dyno's on custom tacos. Some have been in the upper 250's, so its not unheard of to get that power.
  5. Oct 22, 2010 at 8:23 AM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    On what kind of dyno?
  6. Oct 22, 2010 at 8:24 AM
    jaxchrisfla
    jaxchrisfla Well-Known Member
    flooriduh
    lots
    My numbers are in my sig. The APR X1 is the best bang for its buck as it will help any other performance mods you add later on. self tuning, easily adjusted by the end user, and cant beat the engine guardian that it has. I gained 12hp and 33tq from just adding the x1 to my truck
  7. Oct 22, 2010 at 8:32 AM
    rme
    rme Well-Known Member
    Savannah
    Green TACOMA
    XM, Panasonic Stereo, Headlights,Electric Ant,Toyota Deluxe Wheels, Rhino Lining, Cargo Rails
    I take it from what I'm reading...everyone is talking 6 cylinder?:confused:
  8. Oct 22, 2010 at 8:33 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    IIRC, It was an inertia dyno.
  9. Oct 22, 2010 at 8:56 AM
    pamantea
    TRD Exhaust
    Keep in mind I have a 4x4 access cab TRD. I don't know if that matters....but im guessing the size of tires matter? In the spring I will be putting 33" on 20" BMF novakane rims.
    And I see you have the MAF cal AND the APR. Is that overkill? Do you need both?
  10. Oct 22, 2010 at 8:58 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No. Useing a MAF cal, and an APR does nothing. The APR gives more tuning than the Maf cal. though.
  11. Oct 22, 2010 at 9:15 AM
    pamantea
    TRD Exhaust
    Would I better off with just one or the other? and what about the unichip?
    I like the idea of plug and play for the reason of warrenty.
  12. Oct 22, 2010 at 11:07 AM
    pamantea
    TRD Exhaust
    Yeah I heard that Toyota hasn't released the harnesses yet for 09 and up and once they do (if they do) APR will have a unit for these trucks. Why does unichip have harnesses and APR doesn't? Its odd. I've been reading like mad lately about all these options and if the APR does become available in the spring, I will most likely buy that.
    Does an aftermarket Y pipe do anything?
  13. Oct 22, 2010 at 12:09 PM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    Also keep in mind that unichip can only be tuned by unichip certified tuner...
  14. Oct 22, 2010 at 12:42 PM
    pamantea
    TRD Exhaust
    Yeah, I have considered that. I will be buying a CAI in the spring. I have the TRD catback exhaust now. So the unichip would be tuned for that. But if I ever buy the long tube headers, that would suck to have to get it retuned.
  15. Oct 22, 2010 at 1:50 PM
    jaxchrisfla
    flooriduh
    lots
    I didnt have them in at the same time. went from the maf cal to the x1. the x1 is a great setup also if you want to go with the trd supercharger later on. as most early trd sc's know, they reflash your ecu and once that is done, you cant remove the supercharger because they cant reflash your ecu. so if you were to sell your truck you cant really part the sc out. but if you went with the x1, since it mounts inbetween the harness, and the ecu, your tune is all in the x1 ecu, and you can remove it and never know the difference.
  16. Oct 22, 2010 at 1:53 PM
    pamantea
    TRD Exhaust
    I am loving your HP ratings! With a TRD CAI, TRD exhaust and APRX1, what HP ratings would I realistically get with stock tires and with 33" tires? Do the tires make that much difference?
