Unichip for 2005 - 2008 Tacoma 4.0L
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by I5runner, Sep 17, 2013.
  1. Sep 17, 2013 at 1:07 AM
    I5runner
    I5runner [OP] Well-Known Member
    Ratha
    Belle Chasse
    13 DCLB
    See build page
    Will fit: Tacoma 2005-2007, 4Runner 2003-2008, FJ 2007-2008 (4.0L Engines)
    Unichip performance chip and wire harness. I have this on Ebay as well for $400 Buy it now, I'm asking $300 for TW members. This was removed from a 2007 Tacoma programed for cold air intake and exhaust. You will need to either send it in to Unichip, find a authorized dealer, or order the USB cable and download the map yourself.
    I will ship USPS flat rate.
    More info directly from the manufacture website here
    • Add's up to 27hp & 26ft-lb .
    • Easily plugs into the stock ECU & ECU harness in minutes , no programming necessary .
    • Realizes the full potential of Aftermarket add-on's like Cold-Air-Intakes & exhaust systems , as each kit comes pre-mapped for the exact set-up of each car or truck.
    • No end-user tuning necessary , just plug the kit into the car & you're ready to go.
    • Easily upgradeable for future add-on's.
    • Each kit comes with two maps : a low octane performance map & a high octane performance map, switchable from within the vehicle.
    • Fully tuneable by a Unichip Custom Tuner for customized add-on's . This basically means that the Engine Management System in your ride is now as tuner friendly as the most advanced Standalone systems in the world , without sacrificing any of the factory features. This feature is unmatched by any reflash-tuning or other similar product.
    • Plug 'n Play harnesses are fully Flux capable - purchase Flux when you purchase the Plug 'n Play kit or upgrade later - Flux simply plugs into the Unichip Plug 'n Play harness.
    • Plug 'n Play kits are removed from the vehicle in minutes , returning the vehicle to stock tuning , without leaving a footprint of ever having been modified (a feature which reflash-tuning cannot match).
    • ROADSPEED-LIMIT Removal now available . Write : "Remove roadspeed limiter" in the comments section of the checkout . This feature is only available on this website.
  2. Sep 17, 2013 at 9:09 PM
    farminfireman
    farminfireman Active Member
    Myles
    WNC
    06 trd off road
    3 inch lift, custom built tool box, aftermarket headlights, smoked taillights, diff lock any time mod :), k&n cold air intake, after market headunit with 2 10inch subs behind the rear seat
    Why did you take it out
  3. Sep 17, 2013 at 9:43 PM
    InTheRough
    InTheRough Well-Known Member
    Kolt
    Gig Harbor, WA
    '20 Tundra Platinum
    Rock Warrior wheels
    What CAI and exhaust did you have?
    Edit: What CAI and exhaust was this programmed to on the 2007?
  4. Sep 17, 2013 at 11:35 PM
    I5runner
    Ratha
    Belle Chasse
    13 DCLB
    See build page
    I have a 2013 Taco, wont work for my truck.
