Unichip - initial review
Discussion in 'Performance and Tuning' started by lawrenccar1, Sep 30, 2015.
  1. Sep 30, 2015 at 11:57 AM
    lawrenccar1
    lawrenccar1 [OP] Well-Known Member
    Springfield, Virginia
    2015 4x4 DCSB TRD Off-Road
    I recently installed a Volant CAI/w scoop and Flowmaster dual exhaust. Other than sound performance was minimal. Yesterday i installed the Unichip mapped for my mods. Came with 2 maps (less aggressive timing) and more aggressive timing for higher octane fuel.
    The results are impressive. Both provide enhanced acceleration and overall quickness. The more aggressive map is ideal for me and provides almost a sporty feel driving experience.
    So far so good and i would do it again.
    cdelgado14 likes this.
  2. Sep 30, 2015 at 2:59 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Subbed for long term review
  3. Sep 30, 2015 at 3:00 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Wait..... Doesn't vvti advance the timing to optimums?
  4. Oct 1, 2015 at 10:55 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Not necessarily.
  5. Oct 1, 2015 at 5:43 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    Didn't I hear that Unichips are crap or hard to tune since there's very little tuners who specialize in tuning the Unichips for the Tacoma?
  6. Oct 1, 2015 at 8:24 PM
    cdelgado14
    cdelgado14 Well-Known Member
    Alice,Texas
    Supercharged micro machine ;)
    Bilstein 3 inch w/ 5100's
    Has it help your mpg when driving conservative?plug and play right?i read that the dealer should not be able to tell that anything was plugged into the ecu..as I still have another 50k warranty left and I'm am considering the unichip(if it's plug and play..yes I read it was but im just double checking before I pull the trigger!)
  7. Oct 2, 2015 at 5:34 AM
    lawrenccar1
    yes plug and play, took about 1/2 hr simply because a bit tight getting to the plugs. dont know about the mpg. to early to tell but i am no really concerned about that.
  8. Oct 2, 2015 at 6:59 AM
    cdelgado14
    Alice,Texas
    Gotcha.well I'm looking into a way to get a little better mpg..if you don't mind finding out I would really appreciate it!
  9. Oct 15, 2015 at 2:10 PM
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    Keep us informed about your experience.
    It's a path i will maybe follow. Tired to wait about the UCON. I'm looking to buy it with the tuner kit so i can tune it myself. There is a tuner here that i will use for the timing map on the dyno but i will take care of the fuel map and other possibilitie offered by this system (like adding a 7th injector or modifying the AFR signal in close loop).
  10. Oct 15, 2015 at 2:17 PM
    Clearwater Bill
    Billy
    Largo Florida
    How does the 'less aggressive' 'provide enhanced acceleration and overall quickness'?
    Do you mean it's more aggressive than OE, but the lesser aggressive of the two maps, retaining the ability to use regular fuel?
    Doesn't the knock sensor auto-retard the more aggressive map? I'm sure the premium fuel helps protect the point knock appears, but still???
  11. Oct 15, 2015 at 2:28 PM
    lawrenccar1
    correct both maps increase response over oem, map 0 a little, map 1 more.. still working great, running map 1
  12. Oct 15, 2015 at 2:30 PM
    lawrenccar1
    correct i believe..
  13. Oct 15, 2015 at 2:31 PM
    lawrenccar1
    anyone in nova area that wants to test drive i am open to that so you can see for yourself the response the unichip offers up..
  14. Oct 19, 2015 at 8:15 AM
    tacomatrd22
    tacomatrd22 TRD SuperCharged Tacoma
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    FlowMaster Super 44 2" lift Gray wire Fog light
    I should get this. I have my CEL on my truck from the so called knock sensors being bad (which was replaced and did nothing). Tired of look at that CEL, for $500 it will be worth it.
  15. Oct 19, 2015 at 8:21 AM
    tacomatrd22
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    A code did come up saying short circuit malfunction (can't remember exactly) 2 months ago.
  16. Oct 19, 2015 at 8:23 AM
    tacomatrd22
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    So there's no solution to this besides paying another grand on wiring just to fix this one code.
  17. Oct 19, 2015 at 8:28 AM
    tacomatrd22
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    I understand. Time to search for a automotive electrician in my area.
  18. Oct 20, 2015 at 4:42 PM
    troyb123
    troyb123 Well-Known Member
    Troy
    Lake Stevens, WA
    2014 SR5 DCSB 4X4
    Flowmaster american thunder series exhaust, AEM Brute Force Intake System, Doug Thorley Headers, BPF grille, SCS Stealth 6 wheels.
    Did the kit come with a little remote to change which map you want to run? or did you have to buy the flux? Im looking into buying the Unichip PNP kit.
  19. Oct 21, 2015 at 4:59 AM
    lawrenccar1
    yes it comes with a wired map switch that plugs into unit, long enough to mount in dash area. i leave mine in glove box
    troyb123[QUOTED] likes this.
  20. Oct 21, 2015 at 2:36 PM
    troyb123
    Troy
    Lake Stevens, WA
    2014 SR5 DCSB 4X4
    Awesome, thank you.
