Unichip?
Discussion in 'Performance and Tuning' started by Cool, Jun 2, 2013.
  1. Jun 2, 2013 at 10:22 AM
    Cool
    Cool [OP] New Member
    Gavin
    Madison, Ms
    v6 4WD SR5
    has anyone ever tried the unichip, they work for stock or supercharged tacos
    anyone got any comments on them, they do run around 600$
  2. Jun 2, 2013 at 10:59 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    They come with a "pre-tuned" map. If it doesn't work right, or needs improvement, you have to find an authorized tuner. They usually charge a $250 flat rate minimum.
  3. Jun 3, 2013 at 9:18 AM
    ToyotaTacoma4Ever
    ToyotaTacoma4Ever Get Boosted
    Eric
    Alberta
    Supercharged Tacoma Sport
    Check Out The S/C Build
    There was a few people here who has already tried them and its hit and miss for it working right when it comes to your door. Performance wise you might feel a bit of a gain but I can't quite remember what the others said
    My actually experience is I had a friend order it for his scion FRS and he already had to ship it back because of the connections being on the edge of fitting and it was giving him a check engine light when it was plugged in.
    Good luck with your choice!
  4. Jun 3, 2013 at 9:38 AM
    chris5255
    chris5255 Me mber
    Renton WA
    12 Tacoma DCLB TRD Sport-'07 FJ Cruiser
    BAMF Sliders Fog light switch mod, Pelfreybilt Front bumper, Warn Zeon10 winch pinstriping for speed
    I had one on my '04 SC Tundra and loved it. I did have it mapped for my truck at an authorized tuner. (3 different maps) I think I paid around $250 for the mapping but it also came with a full before and after dyno. Much better throttle power response. In fact in the rain I had to keep it on one of the more mellow maps because it was too easy to free up the rear end leaving a stoplight. Even though I had a canopy, more weight in the back and better tires would have helped. I also saw a 2-3 mpg increase after the unichip when I could resist the heavy pedal on the onramps. The Map that I drove with most of the time gave me incredible acceleration in the 2500-3500 rpm range so passing 50-70mph was a blast.
    The only negative I ever saw was I always pulled it off before going in for any kind of warranty work(brakes and driveline TSBs). I don't think it would have been an issue but I didn't want the dealer to give me a hard time about it.
  5. Jun 4, 2013 at 9:03 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    ur better off with the URD maf calibrator
    URDusa.com
    I think Marcel had a uni and it was a flop, but I could be wrong.
    keep in mind, they (urd) tend to LEAN the trucks fuel some......If ur in an area with many steep grades/elevation changes, I would think twice.
    I did have pinging with 1.
  6. Jun 4, 2013 at 9:11 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I did, as well as Novanut. Both were fails for us. It all come down to support since it isn't open source.
    If you don't have any support for it around you, and it doesn't work properly, then you are SOL.
  7. Jun 10, 2013 at 12:37 PM
    novanut21
    novanut21 Well-Known Member
    Brent
    North Central,WV
    2009 TRD SPORT
    AFE CAI, Magnaflow cat-back, TRD S/C, TRD Quickshifter, URD Fuel Pump Kit, Wet Okoles Front&Rear, WeatherTech Mats, Sockmonkey Decals, Satoshi grille, JBA "shorty" headers, URD Y-Pipe, TTC Oil Catch Can, Lotek Dual Apillar gauge pod w/ Autometer Phantom II AFR & Vac/Boost, URD Pulley, HID Retrofit.
    ^^^Yup! It leaned out to A/F way to much. I have no authorized dealer even close to me. So only other option they have is a rental tuning kit you can purchase for x amount a week. Then find someone who is willing to use there software to tune there product. Needless to say mine is still collecting dust in the corner of my bedroom.
