Unidentified drain on battery
Discussion in 'Technical Chat' started by dud122, Aug 9, 2014.
  1. Aug 9, 2014 at 7:38 PM
    dud122
    dud122 [OP] rabble rabble rabble
    Dan
    Riverdale Park, MD
    2004 Tacoma DC
    OME up front, Dakar in the back, Elite front bumper, Warn winch, Tactical rear bumper with tire swing/jerry cans/hi lift, Revenge Fab. sliders, Tundra brakes, Camburg UCA's, Safari Snorkle, FJ TRD wheels, Lights, CB, Switches, skids, LED's... OH MY!
    Any idea what could drain a battery while the vehicle is off and nothing is visibly left on on the truck? is it possible that some sort of poorly wired aftermarket light (i'm no electrician) could do this without the light being left on?
    my battery isn't that old and i've had to jump it several times. not sure whats wrong.
    anything i should try to troubleshoot before i look at replacing the battery?
  2. Aug 9, 2014 at 7:46 PM
    Cypherian
    Cypherian Well-Known Member
    Mid Atlantic Region
    Alternator output , Check Battery connections, Improperly installed aftermarket stereo if you have put in aftermarket lights as you say disconnect them see what happens. These are just off the top of my head. There are much better electrical folks around here they should show up eventually.
    Cypher
  3. Aug 9, 2014 at 7:53 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Look up "parasitic voltage draw".
  4. Aug 9, 2014 at 8:06 PM
    dud122
    Dan
    Riverdale Park, MD
    2004 Tacoma DC
