Unidentified hum
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tedaposto, Jan 11, 2016.
  1. Jan 11, 2016 at 5:53 PM
    Tedaposto
    Tedaposto [OP] Member
    Ted
    2005 TRD double cab off road
    Leer 180 cap
    So I've had a hum from the front right that has progressively gotten worse over the last few weeks. It is only when in motion.
    It stops when taking a hard left.
    Thought it was a CV Joint. Replaced CV assembly, not the solution.
    My next guess is the bearing. Any leads are greatly appreciated
  2. Jan 11, 2016 at 5:55 PM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    Sounds like a wheel bearing to me. Jack up each front wheel and rotate it and tug on the wheel. You'll hear it and feel it if it is.
  3. Jan 11, 2016 at 7:09 PM
    Tedaposto
    Ted
    Leer 180 cap
    So I jacked up the driver side and the wheel was tight. (Caliper is partial issue.) Took the caliper off and spun the shaft, the sound is coming from the driver side of the differential.
  4. Jan 12, 2016 at 3:14 AM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    I agree with eccracer104.
    If the noise stops when you take a left, it sounds like the driver's side bearing is the issue. When your taking a left, the load/weight shifts more to the right of the truck, taking some of the load/weight off the left wheel.
  5. Jan 12, 2016 at 6:27 AM
    Tedaposto
    Ted
    Leer 180 cap
    Yeah, Fitz, I've determined its the drivers side front dif bearing. Just doing research on how involved it is to replace and best place to source parts
  6. Jan 12, 2016 at 6:45 AM
    Fitz235
    Rob
    New Hampshire
  7. Jan 12, 2016 at 6:48 AM
    Pigpen
    Dan
    Northwest Montana
  8. Jan 12, 2016 at 6:53 AM
    Fitz235
    Rob
    New Hampshire
    Sorry, I just re-read your post, and saw Diff bearing.
    Did you do the 4wd test? (assuming you have 4wd, put it in 4wd, and noise goes away).
  9. Jan 12, 2016 at 6:55 AM
    Tedaposto
    Ted
    Leer 180 cap
    Haha yup, diff bearing not wheel.
    As far as H2 vs H4 it sounds the same in both twd and fwd.
  10. Jan 12, 2016 at 6:59 AM
    Fitz235
    Rob
    New Hampshire
    It sure sounds like a wheel bearing to me. Typically when the driver's side diff. bearing is going, when it's put in 4wd, the noise goes away. Also you said when turning the noise goes away. Both of those make me think it's a wheel bearing.
  11. Jan 12, 2016 at 7:02 AM
    Tedaposto
    Ted
    Leer 180 cap
    What makes me believe it's not the wheel bearing is the fact that we didn't hear any odd. Noise from the wheel bearing and traced the noise to the diff
  12. Jan 12, 2016 at 7:10 AM
    Fitz235
    Rob
    New Hampshire
    It sounds like your pretty confident. Good luck. Keep us updated.
  13. Jan 12, 2016 at 7:24 AM
    Pigpen
    Dan
    Northwest Montana
    On a ten year old truck, you will likely still hear the hum in 4wd if it'd the diff bearing
  14. Jan 12, 2016 at 7:27 AM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    Your initial post said the sound was from the front right as in passenger side but in your next post you said you jacked up and inspected the drivers side ? What you are describing is text book wheel bearing, if it was the diff the noise would go away in 4wd. When the truck is jacked up and there is no weight on the wheel bearing it will Not make any noise. I fear you have not properly diagnosed the wheel bearings so here is the proper method.
    Jack up the front end so that the wheel is completely off of the ground. Next, grab the wheel at 12 and 6 and give it a firm shake top to bottom like you are trying to wiggle it off of the axle. If there is slop in the bearing this is how you will feel it. Rotating the wheel does nothing, you must wiggle it 6&12 to feel a damaged bearing.
  15. Jan 12, 2016 at 8:00 AM
    Tedaposto
    Ted
    Leer 180 cap
    The initial post was before I checked the driver side.
    As far as the wheel bearing being bad, I'll have to check that after work today. But this still does not explain the grinding coming from the driver side diff when CV is spun by hand
  16. Jan 12, 2016 at 9:05 AM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    My two cents - The front diff itself is offset to the drivers side quite a bit so when you are under the front end turning the drivers side front wheel you are right on top of the actual diff and simply hearing the gears turning right in your face. The symptoms you are describing are just 110% what a thousand other people have experienced with a bad wheel bearing which is why we are steering you that way. Let us know after you check it...I'll put a fresh crisp $1 on a wheel bearing :)
  17. Jan 12, 2016 at 9:29 AM
    Tedaposto
    Ted
    Leer 180 cap
    Copy that. I appreciate your pennies. Definitely looking into that further this in a few hours
  18. Jan 12, 2016 at 5:04 PM
    Tedaposto
    Ted
    Leer 180 cap
    So I checked out the wheel, there is no slop in the wheel bearing
  19. Jan 13, 2016 at 10:23 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Unfortunately, it's not that simple when dealing with double row bearings such as these. A even one pit in one race of the bearing and it will make horrific noise with no play. It's also not simple to diagnose such issues over the internet, so for what you replace, you'll have to make the decision yourself based on what you're seeing first hand. I do agree with Evenflow and think you are hearing your diff side gears and spider gears, but again, it's a hunch based on your description, and not first hand info.
  20. Jan 21, 2016 at 1:11 PM
    Tedaposto
    Ted
    Leer 180 cap
    Well, I changed out the wheel bearing. Same noise is still happening under the same conditions. Next step, driver side differential bearing
