Uninstalling URD MAF calibrator, question
Discussion in 'Performance and Tuning' started by TRDguyKC, Oct 8, 2021.
  1. Oct 8, 2021 at 8:20 PM
    TRDguyKC
    TRDguyKC [OP] Well-Known Member
    Kris
    Sierra Vista, AZ
    Good evening gents,
    I’m planning to purchase an HP tuner for my 2007 4.0 here soon but have a question with regard to my current setup.
    I’m currently running the URD MAF (have been for going on 12 years now) and am curious to know if I can just “unplug/uninstall” to return my ECU to a stock MAP in preparation for the HP tuner.
    I’m mostly ignorant with this stuff so apologies if it’s a dumb question and thanks in advance for your help/patience.
    -Kris
  2. Oct 10, 2021 at 9:08 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    You could do that. You could also, if you have the tuning program, make all of the cells in the tables zeroed out.
