Uninstalling URD MAF
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CayucosTacoma, Apr 15, 2013.
  1. Apr 15, 2013 at 11:50 AM
    CayucosTacoma
    CayucosTacoma [OP] Just think outside the Yota
    San Luis Obispo/San Jose
    2004 Double Cab 4x4
    Specs in the Build Thread
    Hey,
    So I want to uninstall the URD MAF. I Had someone else install it (Wolfpack_5150) and now I want to uninstall it.
    If someone could point me in the right direction that'd be awesome. Seems like it'd just involve soldering and matching wires. But like i said i didn't install it so not sure how to remove it. Thanks
  2. Apr 15, 2013 at 11:53 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    clip the wires off. done. The MAF CAL wires just splice into the yota wiring harness. just cut the wires from the maf cal as close as you can to where they attach to the factory harness and you should be fine.
  3. Apr 15, 2013 at 12:11 PM
    CayucosTacoma
    2004 Double Cab 4x4
    o cool thanks man!
  4. Apr 15, 2013 at 12:55 PM
    MadToy
    MadToy Well-Known Member
    Nick
    Huntersville, NC
    07 Midnight Blue TRD
    OME 886, Dakar leafs, LR UCA's, 16x8.5 Level 8 ZX, 315 MTR Kevlar, All-Pro sliders, BudBuilt skids, Undercoverhwms winch mount, Warn M8000 with synthetic rope, ATO Hi-Lift bed mounts, Diff locker override, Hitch harness relocated to bumper, Undercover bed cover, Gromm Aux adapter, Grillcraft grill, DT pipe bombs, Custom Magnaflow exhaust, Brute Force HC bumper, TRD Supercharger
    Hmm.... Not sure how the Tacoma is wired, but the PSC controller (MAF) usually splits one of the factory wires, so unless you tie it back together, it ain't gonna run.
    Tacoma could certainly be different though. I just remember cutting one out of my car, and having to re-connect one of the wires out of the ECM.
  5. Apr 15, 2013 at 1:51 PM
    CayucosTacoma
    2004 Double Cab 4x4
    That's what I thought... Ill check
  6. Apr 15, 2013 at 1:58 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Call urd bruh
  7. Apr 15, 2013 at 2:03 PM
    CayucosTacoma
    2004 Double Cab 4x4
    gadgets a busy guy, hard to get a hold of
  8. Apr 15, 2013 at 2:06 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Here ya go
    URD MAF Sen Cal NA 2005 Tacoma V6.pdf
  9. Apr 15, 2013 at 2:09 PM
    CayucosTacoma
    2004 Double Cab 4x4
    thanks man, guess ill just go in reverse order
  10. Apr 15, 2013 at 3:29 PM
    MadToy
    Nick
    Huntersville, NC
    Yep. Same as my car. Step E & F separates one wire. You need to re-solder that wire back together. The others can just be cut from the PSC.
