Unintended Acceleration
Discussion in '3rd Gen. Tacomas (2016-2023)' started by t2c, Sep 23, 2022.
  1. Sep 23, 2022 at 5:10 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    I guess the next thing is it repeatable?
  2. Sep 23, 2022 at 5:11 PM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    No one has asked this question but...
    Have you had any kind of tune to the ECU?
    Are you the first owner?
    OnHartung'sRoad likes this.
  3. Sep 23, 2022 at 5:13 PM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    What amount of acceleration were you experiencing ?
    To the floor, light, etc ?
    I had a camaro once years ago and the IAC motor would stick sometimes and accelerate the car.
    wilcam47 likes this.
  4. Sep 23, 2022 at 5:14 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    A buddy of mine could make his truck accelerate whenever he keyed up on his CB- he had a 200w (totally illegal) linear amplifier attached to it. I use radios (legal ones) and such on mine but never had an issue, but is there anything in your truck or mods that could be emitting or overly sensitive to EMI?
  5. Sep 23, 2022 at 5:17 PM
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    If it helps you feel better, modern Toyota's have a brake override feature. It automatically returns throttle to closed if the brake pedal is pressed, regardless of all other inputs. The only way for it to runaway is if something is physically jamming the throttle plate, like a stupid throttle body spacer or chunks of air filter from mice chewing things up.
  6. Sep 23, 2022 at 5:21 PM
    t2c
    t2c [OP] Well-Known Member
    No sir, I've felt that before as well. This was not that. Thank you for your kind words and I too sincerely hope this can be easily solved.
    VB25[QUOTED] likes this.
  7. Sep 23, 2022 at 5:23 PM
    t2c
    Yes I can confirm this since the accelerating stopped as soon as I stepped on the brakes.
    mattleg[QUOTED] likes this.
  8. Sep 23, 2022 at 5:27 PM
    t2c
    This might be a possibility. I forgot to mention in the post above that I've got a meso total taillights custom harness on my truck as well for the better illumination it provides whether it's reversing, blinkers, running lights, or braking. Also I have the high beam mod done where my headlights are the ones crash recommends. I forget if it's h9 to h11 bulb or vice versa. Also interior lights are bright white leds and I have the meso dome light. My fogs were always wired. I didn't do any rewiring. I just swapped the oem ones for ss3 max with backlight with the harness I bought on here. None of the mentioned have given me any issues thus far. But they're definitely worth mentioning here.
  9. Sep 23, 2022 at 5:27 PM
    mattleg
    Kansas
    2020 OR DCSB AT 4WD
    Did you get a message on the center display for brake override?
  10. Sep 23, 2022 at 5:29 PM
    t2c
    First owner, no ecu tuning done. Mechanically, it's all stock. I've done some mild lighting upgrades and the dealer did the spacer lift and tires/wheels.
    TacoTime55[QUOTED] likes this.
  11. Sep 23, 2022 at 5:29 PM
    t2c
    It definitely wasn't wide open throttle. I'd say light to medium acceleration. From what I can recall, it didn't change gears as it did it.
  12. Sep 23, 2022 at 5:30 PM
    t2c
    No sir. Looked at center display almost immediately to see if cruise control was accidentally engaged, but it wasn't. And no other lights were on.
  13. Sep 23, 2022 at 5:31 PM
    t2c
    Hasn't been so far.
  14. Sep 23, 2022 at 5:37 PM
    2016Tacoman
    J
    I think there is software there to detect both occurrences happening, brake and accel, and to remedy the situation. A safety feature. Why it happened is interesting.
    Floor mats clear of accelerator ?
  15. Sep 23, 2022 at 5:55 PM
    #35
    t2c
    Yes sir, floor mats were definitely not the issue. There was nothing physically obstructing the gas pedal.
    2016Tacoman[QUOTED] likes this.
  16. Sep 23, 2022 at 5:55 PM
    #36
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    I blame the lights.
  17. Sep 23, 2022 at 5:55 PM
    #37
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Custom tunes were ruled out in the other threads since there were multiple people with stock vehicles that had the same issue.
  18. Sep 23, 2022 at 6:03 PM
    #38
    2016Tacoman
    J
    At least on a good note the acceleration subsided when the brake was depressed. On past issues years ago with other vehicles this was not the case.
    And with my IAC issue on my chevy it wasn't either and was quite concerning.
    t2c[OP] likes this.
  19. Sep 23, 2022 at 6:04 PM
    #39
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    Interesting.
    I will say I notice my Sport lunge when I take it out of Park. I have OTT Tune 8.0 with Gear Lock.
    But it has not accelerated on it's own while I've got my foot off the throttle pedal.
  20. Sep 23, 2022 at 6:07 PM
    #40
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    Seems like one of the rare oddities that people have and there doesn't seem to be any obvious similarity between those that have the issues. I initially assumed adaptive cruise control was the culprit but most people with the problem tend to not be using cruise control at the time and there have been a few pre TSS models with the issue as well IIRC.
    t2c[OP] likes this.
