Unintentional Acceleration
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bubba, Aug 31, 2013.
  1. Aug 31, 2013 at 10:54 AM
    bubba
    bubba [OP] Member
    Dave
    Cleveland Ohio
    TRD Sport Package
    Has anyone had this problem where the truck simply accelerates on it's own??
    The recall on the floor mats is a bunch of crapola. This has happened to me three times in 29000 miles on my 09 tacoma double cab V6. Each time I put
    the truck in to neutral bring it to a stop and shift in to park. When shifting in to park the engine returns to idle. Being as it has only occurred three times
    if I take it back to the dealer there never be able to trace it. No doubt a
    problem with the fly by wire throttle :mad:
  2. Aug 31, 2013 at 11:04 AM
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    Confused on what your saying. It does what in neutral to park? It jumps forward? It speeds off in a blaze of glory? What does it do?
    Only time mine has done anything related is with cruise control on it accelerated higher after first setting cfuise. It went up around 10-15 mph
  3. Aug 31, 2013 at 1:40 PM
    Hugh Morron
    Hugh Morron Manic Mechanic
    Bill
    Schuylkill County, PA
    12 DCLB SR5 4X4 Barcelona Red Metallic
    ARE Cap, AVS Bugdeflector II, AVS Ventshades, DTRL delete, ABS/VSC/TRAC disable, Toyota LSD with clutchpacks, N-Fab Lightbar, Hella 700ff lights
    Take it back and have it checked out
  4. Aug 31, 2013 at 2:36 PM
    bubba
    bubba [OP] Member
    Dave
    Cleveland Ohio
    TRD Sport Package
    Truck will accelerate like you pushed the petal to the floor with no
    warning. Placing it in neutral allows it to free rev and when you shove it
    in to park it goes back to idle
  5. Aug 31, 2013 at 2:37 PM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    120k miles on mine, never had an issue.
  6. Aug 31, 2013 at 2:42 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    nobody has ever had an actual case of unintended acceleration... That whole clusterfuck was a bunch of idiots who either wanted money from toyota or who were pressing the gas without noticing
    is your floormat area clear of bottles and whatnot? is your engine bay clear of debris?
  7. Aug 31, 2013 at 2:45 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Am I picturing this correct, you are driving along then with no warming full throttle. You then shift to neutral and the engine screams up to the rev limiter, you slow down to a stop with the engine screaming away and then you come to a complete stop and then shift to park and it returns to idle.
  8. Aug 31, 2013 at 2:46 PM
    straycat241
    straycat241 maXXXed out mid travel
    paul
    PreRunner TRD off road 4x2
    airaid intake, jba headers, jba exhaust, DMZ enginecage, King 2.5 coilovers , 1.25camburg uca's, total chaos lca's, shock hoops with Icon 2.5 piggybacks, camburg 4.0 Spindles, Defined engineering SUA, King 2.5" Shocks w/Reservoir, King 2.5 Bumpstops,shocktacobumper,moto metal 951's, compartment locks, blackgrill,Glassworks fenders front and rear,ViS racing glass hood,PIAA 510s,hella 500's,black rebadge,fabtech spare tire holder,tailgate delete,mudflaps delete,cobra 19 ultra iii
    I've had mine "lunge" but the ac was on
  9. Aug 31, 2013 at 2:47 PM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    So when it's taking off on it's own, you stick into neutral or park? Doesn't it rev to redline?
  10. Aug 31, 2013 at 6:53 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    This samething happened to me. I though that it was the truck, turns out it was me.
  11. Sep 1, 2013 at 10:05 AM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    I had this happen this past week. Coming into town, cruise set at 55 (hadn't touched the gas pedal in over 10 miles), I pulled the cruise stick back to cancel cruise. Engine load on ultragauge went to 100% so I pulled the cruise stick a couple more times without effect. It got just over 60 mph (4 cyl in 5th gear isn't a rocket lol) when I pushed the clutch to the floor and then the brake, but since the clutch went down first the motor got to about 4k rpm before the brake pedal override cut it back to idle. First time it's happened, hasn't done it again yet. I wonder if the high humidity affected it.
    It would have been more 'fun' with the 4.0L but with the stick it's not even a panic-worthy event.
    For those wanting to blame the floormat, I have the cheap huskyliners which prevents the accelerator from going all the way to the floor. I can only get about 95-97% engine load fully depressed. Literally the only time the load can go to 100% is under cruise.
  12. Sep 1, 2013 at 10:10 AM
    SoutheastTaco
    SoutheastTaco Resident Jackass
    steven
    columbia sc
    09 trd sport dc 4x4
    rear spring tsb, 255/75/17 bfg muds
    I smell something..
  13. Sep 1, 2013 at 10:17 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I thought the recall included a brake over-ride. :confused:
  14. Sep 1, 2013 at 10:21 AM
    iroh
    michigander
    tonneau
    It was supposed to, which I assume is why I didn't have to restart my truck when it happened to me. Once I got the rpm to fall back to idle I shut the cruise off, put it back into gear, and drove the rest of the way to work.
    Don't know why the OP's isn't
  15. Sep 1, 2013 at 10:37 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Yep
  16. Sep 1, 2013 at 10:42 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    I agree with the :kona:
    During all that shit not one real claim on this sight about that. Not that crazy things can't happen, which is why I'm not doubting your issue OP. Yet that is. :D
  17. Sep 1, 2013 at 4:55 PM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    It took years for Audi to get over the sudden acceleration thing it all ended when a Judge fined a woman $10,000 for tying up the court system.
  18. Sep 1, 2013 at 6:29 PM
    iroh
    michigander
    tonneau
    That would suck
    I'm not taking Toyota to court lol, having the ability to properly control the vehicle in the event of mechanical failures is supposed to be part of driving. Drive by wire is more reliable than cable, hands down, and I've lived through my share of sticky cables.
    I bet something happened in my cruise switch that wasn't supposed to. It is four-direction with only two wires after all.
    OP has a 2009; I remember my '09 had to get the PCM flash for that whole recall deal. OP, get it done if you haven't already. If anything it (almost) fixes the hill-happy schizo cruise control program.
  19. Sep 1, 2013 at 6:52 PM
    aaronbuell
    aaronbuell Well-Known Member
    aaron
    windsor NY
    09 TRD/OR Access Cab V6 debadged
    Fog-light anytime mod, ,black grill,URD short throw,TRD decals removed ,debadged,black rear bumper, homemade tire carrier,TreadWright tires,Evo mod,removed rear headrests and seats,ABS kill switch mod,black center caps,Clarion CX501 head unit,Relentless hood brackets with floodlights.
    My 09 had the ecm flash there should be a sticker on the underside of the hood.
  20. Sep 1, 2013 at 9:23 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Mine had the recall done but no sticker was installed.
