Unique Climate Control Question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by manualpro, Jan 10, 2025.
  1. Jan 10, 2025 at 9:11 AM
    manualpro
    manualpro [OP] Member
    Las Vegas
    22 TRD Pro 6mt
    Exterior LLumar Valor paint protection film over entire truck ClearPlex Windshield Protection Film LLumar FormulaOne Pinnacle Ceramic Tint 15% all around, 30% on windshield with sun strip Southern Style Offroad Slimline full plate front bumper with bull bar C4 full front skid plates CBI Rock Sliders Warn 10k Winch Factor 55 Flatlink, Fairlead, and Hitchlink ARB direct connect in bumper Daystar locking D ring Whelen SA315 Series Siren Toyo Tires Open Country R/T Trail 285/70/17 Method Race Wheels 701 Bronze 17x8.5 Offset 0 Clutch Accumulator Delete WeatherTech hoodguard WeatherTech window visors Bed BillieBars 5in bed bars iKamper mini 3.0 with insulation BAK Revolver X4s Bed Cover Cali Raised Bed Molle Panels Maxtrax recovery boards Pelican BX135 Cargo Case with cross bed mount 2 Rotopax FuelpaX 3.5Gal 1 Rotopax 2Gal Water Rtic 65qt Cooler Yankum Kinetic Recovery Rope w/ soft shackles Hooke Road Bed Channel Stiffener Support Brackets Indeflate 4 hose system Mountain Hatch tailgate insert Tailgate seal First aid kit Water jug pump Lighting Rigid 30in Spot/Flood Combo SR-Series Pro 2 Baja Designs LP6 Pro 2 BD Squadron SAE 2 BD S2 SAE Ditch: BD Squad pro, s2 pro Scene: 2 BD Squad sport Chase: 2 BD S2, xprite 36in chase bar OPT7 48in Tailgate bar OPT7 Sidekick Sequential Switchback Running Board OPT7 AURA Flexible LED Underglow Lighting under tent MESO Customs Total Tail FBC tail accessory harness for rear bars Suspension Fox 2.5 Tacoma ext w/DSC Front Fox 2.5 Tundra ext w/DSC Rear Eibach ERS 14.00 in. Length x 3.00 in. ID Coil-Over Spring ICON Multi Rate RXT Leaf Pack w/Add In Leaf Heavy Friction Works Spindle Gussets powder coated TRD red Elevate Suspension Billet Uniball UCA Cab mount chop Bison Off-Road Stop Cam Alignment Kit ARK fender splash guard DuroBumps extended front and rear Bump Stops DuroBumps Ubolt Flip kit R1 Concepts Front brakes SuperTech Premium Synthetic ATE 200 Brake Fluid Communication Uniden Home Patrol 2 w/GPS Rugged M1 Race Series Waterproof Mobile Radio Rugged R1 Business Band Handheld Radio Garmin inReach Mini 2 Satellite Communication Midland CB Radio Uniden Seat Mount Speaker Relocation WeBoost Drive Reach OTR cellphone booster Valentine V1 Gen 2 radar detector Full color defense V1 remote display BlackVue triple dashcam Scangauge II Interior OEM Audio+ Reference 500 Dual Sub Kit w/DSP SwitchPros 9100 Controller w/ Runnin4Tacos controller mount Expedition Essentials Dash Mount w/Ram Mounts 2LO transfer case controller H3R Performance HalGuard Clean Agent Fire Extinguisher Element E100 Fire Extinguisher Desert Does It Seat Jackers Wireless Carplay Protech Dash Cluster Film Engine Bay ADD W1 Catch can YotaWerx Tune ARB Twin Compressor w/mount PowerTrays - mount with BlueSea Terminal block
    I'm sure I'm coming off strange asking this, but has anyone actually look into downgrading their dual zone auto climate control to a base manual climate control? I am quite aware how auto climate works, it is perfectly fine in my other vehicles while commuting in the city; although I am beyond annoyed while traveling and feel like I am fighting the climate control half of the time. Sometimes after spending time outside, it may be 60 degrees, but after miles on a hike, I want the AC to stay on the AC, yet when I'm driving up in elevation and the temp drops to 40 degrees, I'm suddenly having the heater come on despite still being hot from activities.
    There is no point of trying to upgrade to the auto due to adding multiple electronics, but would I be able to downgrade easily with an SR5 panel and forego the auto. Dual zone isn't worth anything in a cab this small.
  2. Jan 10, 2025 at 9:16 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Not gonna happen unless you’re super dedicated. You would need a new control panel, new instrument panel wiring harness, new HVAC box or at least a large part of if, blower motor resistor, and a number of parts. I remember when the parts were detailed out to go from manual to auto…it was extensive. Same deal for going from auto down to manual.
    I haven’t experienced those complaints with auto, but I’m not at high elevation. I find setting it to auto and choosing a temp works well for me, although sometimes it’s a bit shy to actually get you to the set temp quickly. For example it was barely running the heater on a warm engine when it was 35 out in order to maintain 70. It was definitely colder than 70 in the cab, so that was annoying. I have accidentally touched the thermistor a few times, I probably should change mine for a more accurate ambient temp reading.
    Long story short, it is a very involved job to convert either direction, I’d probably throw away that idea.
    Here’s the description of parts needed to go from manual to auto. You’d need the opposite to go backwards.
    https://www.tacomaworld.com/threads/dual-zone-climate-controls.598819/page-4#post-20118395
    manualpro[OP] likes this.
  3. Jan 10, 2025 at 9:19 AM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Is rolling windows down not an option?
    Suggestausername and BillF1564 like this.
  4. Jan 10, 2025 at 9:33 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    Or just turn off Auto and run it manually?
  5. Jan 10, 2025 at 9:42 AM
    M85
    M85 Well-Known Member
    Colorado
    2019 SR ACLB
    It still sets the temperature thermostatically and varies the temperature of the air to get there. I'd rather just tell it I want cold air or warm air or medium air. Luckily I have a SR, so it is basic.
    usmc2msu, RockBunny and manualpro[OP] like this.
  6. Jan 10, 2025 at 9:45 AM
    airforceb2cc
    Don
    KCMO
    Makes sense. I'm a windows down with floor heat on kinda guy so I don't have a dog in the fight.
  7. Jan 10, 2025 at 10:48 AM
    manualpro
    Las Vegas
    22 TRD Pro 6mt
    I appreciate the responses and that is what I had figured, but just wanted to see in case the $100 replacement panel would happen to work. Not a big deal but now I know! And part of my problem actually is having the windows open because I too enjoy the window/heater combo; the temperature fluctuation is what is causing my issue but I'll manage.
  8. Jan 10, 2025 at 1:50 PM
    RockBunny
    RockBunny Well-Known Member
    Northern NH
    22 LunarTRD DCLB Sport
    I would prefer the older style of heat/ cool also. It maybe cold out but I don't need 200 degree air coming out the dash vents trying to air-fry the steering wheel and my hands.
    Changing the 'mode' is annoying since it demands attention/looking where as old ones had fixed and predictable positions that were easy to see.
  9. Jan 10, 2025 at 2:09 PM
    Willy Lump Lump
    Willy Lump Lump Well-Known Member
    21’ dcsbmt
    This and that
  10. Jan 10, 2025 at 2:18 PM
    BLtheP
    Plano, TX
    Are you running it on auto? I find that any heating pretty much goes out the vents by the doors and the floor with a little bit puffing out of the defroster vent. I don’t find it to be very roasting at all, unless my left hand is at 9;00 on the wheel. But I usually turn that vent towards the door anyways.
    If I mess with the mode or fan speed, then all bets are off because that essentially puts it in manual. I find automatic systems difficult to control in manual mode, so try to avoid doing that as much as I can. The only exception is choosing defrost, where I roll the temp up to max until that’s done and then I go right back to auto at my chosen room temp.
    RockBunny[QUOTED] likes this.
  11. Jan 10, 2025 at 2:30 PM
    RockBunny
    Northern NH
    I have the temp set around 70 ( not synced) and often change the fan speed and vent angles to limit the air-fryer effect.
    I'll have to read the manual or mess with it when parked again to see what the big problem is. Just kind of overwhelmed by auto this-and-that.
  12. Jan 10, 2025 at 2:39 PM
    BLtheP
    Plano, TX
    Essentially, auto mode wants you to choose a temp and it chooses the right air temp to blow, and the speed and location of which to distribute it. If not synched, then it will try its best to keep both passengers at their preferred temp they each chose.
    As soon as the air speed or vents are changed manually, it’s no longer really in auto mode and it kind of just runs however it’s set. The temp knob becomes misleading in that case because the temp no longer describes anything tangible, and the temp knobs really start to represent more of an older style blue to red temp knob. So imagine Lo/60 as far left blue and 85/hi as far right red (not politically lol).
  13. Jan 10, 2025 at 2:45 PM
    RockBunny
    Northern NH
    Thanks, I'll try that.
    BLtheP likes this.
