Universal Emergency Brake Line Brackets Icon Deaver Old Man Emu
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by ryan20021982, Apr 11, 2021.
  1. Apr 14, 2021 at 10:45 AM
    saundern
    saundern Swerve for nothing
    Nick
    Simpsonville, SC
    2005 TRD Sport
    Any reason these wouldn’t work on a second gen?
  2. Apr 14, 2021 at 1:19 PM
    ryan20021982
    ryan20021982 [OP] Monochrome Tacoma
    Illinois
    2020 Tacoma TRD Off Road
    Icon Stage 3 Fuel D726 17x9 -12 Falcon Wildpeak M/T's 285/70/17 Pro style headlights Auxbeam high and low beams Morimoto xb fogs Pro grill Smoked raptor grill lights w/ drl harness from r4t Hidden grill lightbar Anytime camera kit w/ front camera AVS bug deflector AVS window visors Meso ultimate turn signals Winjet smoked tail lights OEM tailgate lock kit Tinted windows APS iArmor Side steps Taco tunes 4ch and subwoofer amp All Kicker speakers Fox acoustics dual 10" box w/ Kicker subs All Meso interior lights Meso chrome interior delete kit Meso door handle covers Meso Stealth Pro shift knob Trd black exhaust tip Demon front hook mounts with hooks Spotter mirror glass Wheelers superbumbs w/ ubolt flip kit Durobumps in the front
    If the bolt for the leaf is in about the same spot I don't see why not, but I'm just not going to advertise it since I haven't tested it. All they do is push the cable away from the leaf so it doesn't rub, and the line is loose inside the clamp so it can flex also and not cause a problem.
    gabbo2112 and saundern[QUOTED] like this.
  3. Apr 14, 2021 at 1:20 PM
    saundern
    Nick
    Simpsonville, SC
    2005 TRD Sport
    Could I try and them and return them (for a refund)?
  4. Apr 14, 2021 at 1:21 PM
    ryan20021982
    Illinois
    Yes I will be fine with that, all I ask is you post a photo on here if they work.
    saundern[QUOTED] likes this.
  5. Apr 14, 2021 at 1:26 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    They should work just fine. I could be wrong.
    3rd gen:
    2nd gen:
    Bertw192 likes this.
  6. Apr 14, 2021 at 1:26 PM
    TRDProBuddy
    TRDProBuddy Well-Known Member
    MD (Kent Island)
    2015 TRD Pro (Inferno)
    I’d be interested if they work on a 2nd gen.
  7. Apr 14, 2021 at 1:51 PM
    ryan20021982
    Illinois
    Like I said I don't see why not, the AAL is the same one that goes on the 3rd gen, actually they are for Tacomas from 1995-2021, so as long as the emergency brake line runs the same way it would work.
    Island Cruiser likes this.
  8. Apr 14, 2021 at 3:55 PM
    gabbo2112
    gabbo2112 Well-Known Member
    New York
    2020 TRD Off Road
    PM sent wish I had them on for my weekend trip coming up! Can’t wait to get them.
  9. Apr 15, 2021 at 6:26 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Just ordered a set! Wish I had these sooner as my lines have already been damaged from rubbing the leafs.
  10. Apr 15, 2021 at 4:17 PM
    GhostTRD4x4
    GhostTRD4x4 IG: @taco_mudmaster
    2019 TRD 4x4
    I got mine today! Thank you!
    ryan20021982[OP] likes this.
  11. Apr 15, 2021 at 7:35 PM
    ryan20021982
    Illinois
    Just finished a good size batch of these, let me know if anyone is interested
    GhostTRD4x4 likes this.
  12. Apr 16, 2021 at 6:51 AM
    mag4rnr
    mag4rnr Well-Known Member
    Todd
    Golden, CO
    2020 Cement Tacoma TRD OR
    Ordered and Ryan got them shipped out quick. Good, simple solution for the right price.
  13. Apr 16, 2021 at 10:49 AM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Just came in. Thanks Ryan, I'll get these mounted up to my Deavers tomorrow.
  14. Apr 17, 2021 at 9:06 AM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    FYI... these will not fit Deaver U402's without modification. The keeper bolt is too short. No biggie, but I have to run to the hardware store to get a replacement. Also, due to the bolt orientation, I have to remove the leaf pack or cut it off... I'm gonna chop it.
  15. Apr 17, 2021 at 11:24 AM
    #35
    ryan20021982
    Illinois
    Really? It looks like you have a couple threads on there, the brackets are only 1/8" thick
    Bertw192[QUOTED] likes this.
  16. Apr 17, 2021 at 1:07 PM
    #36
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    I think the issue will be that the keeper spreads apart when you loosen the bolt. Getting the threads started is nearly impossible. You might be able to clamp the keeper closed, and then engage the threads, but even then, I don't feel great about so few threads engaging.
    I ended up replacing the keeper bolt with a 3/8-16 x 3.5 bolt and a nylock nut, and it's about the perfect length.
    The only other recommendation I might have is to add another clamp hole, closer to the leaf pack. Right now, the bracket is "pushing" the brake line towards the wheel. Giving the option for it to be 1/2" closer to the pack, might make it sit more naturally.
    Regardless, I'm happy to have gotten these installed. I didn't like my brake cable flopping around and it was starting to wear through the protective jacket, where it contacted the leaf keeper.
    Thanks for the innovative product, Ryan.
  17. Apr 17, 2021 at 1:56 PM
    #37
    ryan20021982
    Illinois
    I see what you mean and ya I'm not sure on the distance between the axle and the keeper bolt compared between the Deavers and Icons
  18. Apr 18, 2021 at 6:35 AM
    #38
    ryan20021982
    Illinois
    No sure if it would make a difference but I have mine mounted with the bend on top, I see yours are flipped around compared to mine. I just noticed this.
  19. Apr 18, 2021 at 7:33 AM
    #39
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Height wise, I think we're good. My line naturally rested in that zone...
    I'm OK with how they're currently installed. I'll run it for a bit and report back if I have any issues. But thanks for checking in.
    For the record, I still recommend this product to other Deaver owners.
    msgs350 and gabbo2112 like this.
  20. Apr 18, 2021 at 9:37 AM
    #40
    Traction
    Traction Well-Known Member
    WA
    2020 TRDOR
    I want some!
