unknown bolts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by timinco77, Feb 15, 2009.
  1. Feb 15, 2009 at 2:34 PM
    timinco77
    timinco77 [OP] Active Member
    Colorado Springs
    07 Tacoma Access Cab
    Rear TSB
    Hi, I just got my truck back from toyota, they did the transmission mount TSB. When I was looking at the new mount I found 4 bolts that where loose, almost falling off. There are 2 on each side, passenger / driver. I attached a picture. Can someone tell me what they are for, and why would they leave them totally unscrewed almost falling off. I tightend them down.
  2. Feb 15, 2009 at 2:35 PM
    98tacoma27
    Ben
    Not Beech Creek
    Possibly from the old mount:confused:
  3. Feb 15, 2009 at 2:44 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Those bolts are for the frame crossmember sub asembly. They should have been tightend propperly. Had those come out, your tranny would have dropped to the ground, causeing God knows what kind of damage to your truck. If they are still loose, TIGHTEN THEM ASAP. Call the dealer in which you had the work done, and let them know they suck.
  4. Feb 15, 2009 at 2:54 PM
    timinco77
    Colorado Springs
    Rear TSB
    WOW I can't believe that. All four of the bolts, two on each side, the nuts were all the way at the end, I only tightened them so I didn't loose the screws incase they were important. Well that scares the shit out of me, if it wasn't Sunday I would be headed to the dealership. Yeah I tightned them as much as I could.
  5. Feb 15, 2009 at 2:59 PM
    timinco77
    Colorado Springs
    Rear TSB
    Oo yeah here is the pic of the new transmission mount. And by the way it did nothing for my vibrations while deaccelerating..
  6. Feb 15, 2009 at 3:00 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    See # 18.:
    Thats the crossmember that holds the tranny in place.
  7. Feb 15, 2009 at 3:02 PM
    jolayiv
    jolayiv Carolina Alliance
    Jim
    Hertford NC
    07 DC TRD 4x4 Off-Road
    Revenge-Fab Sliders, AVS Vent Guards, Rear TSB, Hose clamp MOD, Locker MOD, Flowmaster 40 Series Delta Flow, Midland Radio, Wilson 1000 antenna, Rear Diff breather MOD, Weathertech liners, Maglite mount, Bed Divider, LEER 100XR, Pop&Lock
    What's the TSB #? Just curious what this is all about. Glad to see you had nothing but loose bolt problems.
  8. Feb 15, 2009 at 3:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    those "loose bolt problems", if not caught, could have lead to MUCH greater damage.
  9. Feb 15, 2009 at 3:07 PM
    jolayiv
    Jim
    Hertford NC
    That's why I'm glad "loose bolts" is all he had. I realize what could have happened if they had fallen out.
  10. Feb 15, 2009 at 3:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ah. Gotcha. I thought you were down playing it. My bad. :sorry:
  11. Feb 15, 2009 at 3:13 PM
    jolayiv
    Jim
    Hertford NC
    It happens. no hard feelings :p
    No way! He helps us all out to much now. Just imagine if Chris got a new job he wouldn't be around anymore. :D
  12. Feb 15, 2009 at 3:15 PM
    timinco77
    Colorado Springs
    Rear TSB
    Hey jolayiv the TSB # is TSB-0132-08 for the drivline vibration. Thanks Chris4x4, the pdf file really helped me visualize, I am gonna go back out and double check the bolts again.
  13. Feb 15, 2009 at 3:16 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Are you saying my help isnt wanted? :(
    Thank you. ;)
  14. Feb 15, 2009 at 3:18 PM
    jolayiv
    Jim
    Hertford NC
    Thanks man.
