Unknown disconnected connector in engine bay..?
Discussion in 'Technical Chat' started by will.carroll7, Aug 7, 2016.
  1. Aug 7, 2016 at 6:55 AM
    will.carroll7
    will.carroll7 [OP] Well-Known Member
    2023 DCSB TRD OR 4x4 LR
    I was poking around in the engine bay of my 2013 base model and I found this unconnected 2-pin connector on the bundle running in front of the battery. The wires coming out of it are red, and black w/ white stripe. Does anyone know what its purpose is and if it should be connected to something?
    Pics:
  2. Aug 7, 2016 at 12:56 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Has your Mil come on ??
    What does not work ??
  3. Aug 7, 2016 at 1:28 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Try posting this in the 2nd-gen forum. No need to re-post photos, just include a link to this thread.
  4. Aug 7, 2016 at 1:31 PM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    When it quits raining I'll check out my DC offroad. I know I also have a couple unused plugs and have everything except heated seats.
  5. Aug 7, 2016 at 2:50 PM
    will.carroll7
    No MIL and I haven't noticed anything not working. As far as I know everything works.
  6. Aug 7, 2016 at 5:13 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    In that last picture there's a small hole in the fender just under your finger (in front of the battery clamp)... on my truck it looks like that wire harness is connected to a aluminum box bolted to that hole. The box is about 3"x 3" and about 1" thick, says Denso and has ribs on the side that faces the battery... I have no clue wtf it is or does.
  7. Aug 7, 2016 at 5:29 PM
    will.carroll7
    Interesting. Is there a part number on the box that is visible?
  8. Aug 7, 2016 at 5:34 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Oddball question. Your horns work?
  9. Aug 7, 2016 at 5:38 PM
    will.carroll7
    As far as I know. It makes noise when I push the button. :D
  10. Aug 7, 2016 at 5:42 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    Does it make noise, or would it make someone piss their pants if you pulled up next to them and honked.
    I'm racking my mind trying to remember what that module is infront of the battery. Though mine has a different style connector.
  11. Aug 7, 2016 at 5:43 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    I think that is a connector for the outside temp probe....... I'll have to look at mine to be sure it's a probe connector.
    Rambo MARINE Recon likes this.
  12. Aug 7, 2016 at 5:50 PM
    will.carroll7
    It's pretty loud.
    That seems plausible, it's in the same bundle as some wires running up to the radiator (perhaps temperature probes for coolant temp, etc?).
  13. Aug 11, 2016 at 7:04 AM
    texascolt45
    texascolt45 Well-Known Member
    mike
    groves texas
    prerunner 4 cylinder
    wheels,bilsteins,side bars
    I found at least 2 unconnected plugs on my 09.probably for something optional.like that from the factory
  14. Aug 11, 2016 at 7:06 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    does your truck beep when you lock / unlock from the fob? could be the noisemaker is gone for that
  15. Aug 11, 2016 at 7:09 AM
    Jrobertson
    Jrobertson Well-Known Member
    James
    green valley (Henderson)
    2010 Tacoma off road. 4x4
    Stock. For now.
    more importantly whats near there thats not plugged in? If there is nothing within reach of that cable im sure its nothing to worry about.
  16. Aug 11, 2016 at 7:30 AM
    will.carroll7
    I don't have power locks.
    I wasn't able to find anything. I'm sure it's not a huge issue, I was just curious about what it could be for.
    JimboAnz[QUOTED] likes this.
  17. Aug 11, 2016 at 7:54 AM
    phx13
    phx13 Well-Known Member
    Rob
    2015 DCSB TRD O/R
    MT stuff, RTT stuff, the usual.
    :rofl:
  18. Aug 11, 2016 at 8:36 AM
    Jrobertson
    James
    Stock. For now.
    could be your flux capacitor or your blinker fluid indicator. im not sure what model you bought. If its the off road model defiantly the flux capacitor.
  19. Aug 11, 2016 at 9:16 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    This was serious. i removed mine and no more beep
    Arailt likes this.
  20. Aug 11, 2016 at 9:31 AM
    OffroadToy
    Denso 23080-31010... sounds like some sort of resistor. The other numbers on it are: 196170-0550
