Unknown noise and dealership can’t diagnose
Discussion in '3rd Gen. Tacomas (2016-2023)' started by HowBoutDemOs, Nov 25, 2020.
  1. Nov 25, 2020 at 7:25 AM
    HowBoutDemOs
    HowBoutDemOs [OP] Well-Known Member
    Maryland, USA
    2016 ACSB TRD Sport 4x4
    Derped badges, LED interior lights, interior storage mods, Mobtown Offroad Tailgate Reinforcement Plate and Cap, AJT Design Shift Knob
    Hey all. Did some forum searching and couldn’t find anyone having the same issue. I bought a 2016 Tacoma TRD Sport last week. My first 3rd gen (I’ve only had 2nd Gen’s previously.) When test driving, I noticed a sound that’s similar to a marble rolling around in a can. The dealership said they noticed it but the techs couldn’t find anything. I didn’t think much of it, confirmed if it turned into an issue it would be covered under warranty, and bought the truck. It’s becoming increasingly annoying and it’s bugging me I can’t figure out where it’s coming from. It sounds like a marble rolling around in a can. It’s coming from the front passenger side and it sounds exterior. It’s hard to reproduce. It usually happens when accelerating from a stop, or at low speeds when braking and it usually only happens when turning. Anyone have any ideas? Thanks in advance.
    wilcam47 likes this.
  2. Nov 25, 2020 at 7:29 AM
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
    Check inside the door. Someone might have left a socket or some such there.
    kahanabob, shakerhood and wilcam47 like this.
  3. Nov 25, 2020 at 7:31 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Did they check the marble reservoir? Maybe one shook loose.
  4. Nov 25, 2020 at 7:32 AM
    HowBoutDemOs
    Maryland, USA
    It’s more front passenger wheel well/front passenger under-the-hood area. I’ve poked around in both areas and found nothing. With my limited knowledge, my first thoughts were either something rattling in the suspension or loose brakes.
  5. Nov 25, 2020 at 7:35 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Maybe cv joint or bearing? Or lug nuts loose
    HowBoutDemOs[OP] likes this.
  6. Nov 25, 2020 at 7:39 AM
    HowBoutDemOs
    Maryland, USA
    I don’t think it’s the cv. It’s not so much a rhythmic click. More a random rattle.
  7. Nov 25, 2020 at 7:41 AM
    Midnight beauty
    Midnight beauty Well-Known Member
    White mountains AZ
    2020 midnight black Tacoma TRD Sport
    It’s the ghost of the 10mm just letting you know he still around. :D
    Kev250R, weefek and wilcam47 like this.
  8. Nov 25, 2020 at 7:43 AM
    wilcam47
    Will
    Bourbon state
    Busted shock?
  9. Nov 25, 2020 at 7:43 AM
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    Had an odd metallic clink sound on my RAV4, turned out it was something inside my tire. At just the right speed, whatever it was, followed the tire up and then dropped on the wheel just right to make the noise. Had checked everything in the suspension, then noticed it moved when I rotated the tires.
    shakerhood and HowBoutDemOs[OP] like this.
  10. Nov 25, 2020 at 7:45 AM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    Look at the tweeter cover on the dash, it rubs with the a pillar and makes a noise like that, I shoved some foam in it and it doesnt make the rattle anymore
  11. Nov 25, 2020 at 7:45 AM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Bad front body mount is always my go to on this type of thing. All of them are torn from install and are the softest rubber known to man. I think Trojan should look into Toyotas supplier.
  12. Nov 25, 2020 at 7:46 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Pull the cabin filter behind the glove box and see if junk got in there or dead critters come in thru under hood intake passenger side.
    Or someone dropped m&m in air vent.
    kahanabob and HowBoutDemOs[OP] like this.
  13. Nov 25, 2020 at 7:47 AM
    Lt. Dangle
    Ohio
  14. Nov 25, 2020 at 7:49 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Check wheel center cap, I had on make an annoying noise.
  15. Nov 25, 2020 at 7:56 AM
    LivinOnEdge
    LivinOnEdge ¯\_(ツ)_/¯
    Land of The Lost
    Four wheels and a refrigerator
    Had this issue on my 17', even had a master tech drive with me. He blamed it on the fuel. I found out in order to fix the problem, I had to get a new truck. Someone totaled my 17'. I bought an 18' and the problem went away.
  16. Nov 25, 2020 at 8:03 AM
    Freegolf
    Freegolf Well-Known Member
    Denver
    2016 offroad, manual tran
    Have you checked your roof? I had a 10 mm open end wrench I had forgotten and left up there. Last about 2 weeks sliding from end to end getting stopped in the weather stripping channel. I occasionally heard what sounded like your problem until I finally looked up there :anonymous: surprised it stayed on that long. Does the truck have a roof rack or had work done on the head liner?
  17. Nov 25, 2020 at 8:04 AM
    El_rojo_grande
    El_rojo_grande Well-Known Member
    Carson
    Savannah GA
    2021 TRD OR MT
    I had a similar issue on a Ram 2500. take a peak in the backside of your wheel, might have a little pebble or rock that's rolling around in there.
    zippo88 and HowBoutDemOs[OP] like this.
  18. Nov 25, 2020 at 8:08 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    50 bucks says its a 10 mm socket.
    But, if you want to know where it is, remove the wiper arms, remove the plastic wiper cover, I bet there is something in the wiper tray.
    Skydvrr likes this.
  19. Nov 25, 2020 at 8:10 AM
    HowBoutDemOs
    Maryland, USA
    If this ends up being it, I’ll Venmo you $50
    T-yoda and 5nahalf[QUOTED] like this.
  20. Nov 25, 2020 at 8:18 AM
    T-yoda
    T-yoda Well-Known Member
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    265-75-16 BFG AT, firestone riderites
    Also seen floor duct work under the seats having match box cars in it.... those noises can be deceiving !! GL OP
