Unknown sqeaky problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BMiller421, Sep 10, 2012.
  1. Sep 10, 2012 at 9:15 PM
    BMiller421
    BMiller421 [OP] FMLYHM
    Brandon
    Bakersfield, CA
    05 Pre-runner
    LT, Kings, Fabricated Trucks Worldwide For The Win, K&N and Doug Thorley LT Headers
    My 2005 2wd access cab automatic has been really easy to maintain over the last 7 years..
    But this very recent noise is confusing the hell out of me..
    While in drive and approaching a stop sign or any deceleration..a very loud and embarrassing sqeaky noise begins and does not stop until the truck comes to a complete stop..
    If I shift it into neutral during deceleration..the noise does not occur..
    The drive shaft..carrier bearing..3rd member..etc. all appear fine (bolted tight and normal wiggle clearances)
    Anybody have any ideas of what the sound might be? Or what could be causing this?
    Any input is appreciated..thanks in advance..
  2. Sep 10, 2012 at 10:26 PM
    Chindo
    Chindo Member
    07 ac sr5
    shifting into neutral eliminates braking systems i would guess.....if its a squeak i would check your sway bar bushings they start to squeak when the bushing dries up. I have had them squeak only in reverse on my rig before. Doesn't hurt to check and lube
  3. Sep 10, 2012 at 11:08 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Swaybar haha I think he's long gone from that.
  4. Sep 10, 2012 at 11:10 PM
    BAMFTACO
    Juan
    Kings bruh
    But it could be your brakes when was the last time you had them checked and also possibly it could be your leaf springs aswell
  5. Sep 11, 2012 at 4:47 AM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    u joint. i got an 05 and had to replace the back u joint at about 150k. i noticed my squeaking mostly when i was backing up and thought it was suspension then it progressed to a slight vibration . so put a new one in it with grease fitting i got from o'reilly's for like 16 bucks or somethin.
  6. Sep 11, 2012 at 9:33 PM
    BMiller421
    Brandon
    Bakersfield, CA
    05 Pre-runner
    Sway bar was removed back in 05..
    U joints are possible..but I replaced them last year..
    Leaf springs are out of the question cus it happens only while in drive..
  7. Sep 11, 2012 at 9:38 PM
    Esteem
    Esteem Active Member
    Folsom, CA
    07 Prerunner TRD
    This would be my guess as well. I had a similar sound while slowing down and like you, wouldn't happen in neutral. It got progressively louder after about 2000 miles and then I could find the problem easier. But since you replaced them, hard to say.
  8. Sep 12, 2012 at 12:34 AM
    FixedTRD
    FixedTRD Well-Known Member
    Will
    Alhambra, CA
    All pro LT, All pro front bumper,All pro rear fox, 1.5 full leaf and u bolt flip kit. KR sliders, bestop, high lift with custom mount, katskin leather, Hankook MT and atx artillery. DMZ SUA w/FOX triple bypass
    I know you have LT might be your unibal try to lube them up and see if it still squeaks.
  9. Oct 10, 2012 at 9:43 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    did you resolve this? if the noise happens when you accelerate too then forsure u joint.
  10. Oct 10, 2012 at 9:46 PM
    the.sight.picture
    the.sight.picture Wishes he was in the woods.
    Nick
    Blue Ridge
    2018 QuickSand
    Check out my build thread (Beginning of Money Pit)
    U joint. Have those checked. I sheered my rear u joint and heard that annoying sound. It killed me man ill tell you
