unknown wires in dash?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Patmac, Mar 31, 2012.
  1. Mar 31, 2012 at 8:52 AM
    Patmac
    Patmac [OP] Well-Known Member
    Pat
    Chesapeake, VA
    14 TRD Sport
    20% tint, weather techs, icon stage 3. n-fab, bhlm, retrofits, SCS SR8, 285s
    i was playing around with my 07 sport and i got to the blank switch spots on the left side of the dash (the second row below the factory location for fog and av button is) and when i popped them out, there was two harness's hanging there. what are these for? traction control?
    if so where are you guys purchasing you switches from?
  2. Mar 31, 2012 at 9:07 AM
    Patmac
    Pat
    Chesapeake, VA
    14 TRD Sport
    here are some quick pictures
  3. Mar 31, 2012 at 9:14 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    The one on the right is the RSCA switch, and the other is the DAC switch.
  4. Mar 31, 2012 at 9:16 AM
    65tacodude
    65tacodude Well-Known Member
    Wade
    Manteno, IL
    '16 4Runner Trail Barcelona Red
    OEM running boards and roof rack. Yellow fog bulbs and WeatherTech mats and window visors.
    They are more than likely for the RSCA and down hill assit I think for the OR version. Some manufactures make 1 harness that is mutli-plexed to the systems controller to save cost instead of making custom harnesses as the vehicle is being made. Chris had the right switches. I was just guessing. :cool:
  5. Mar 31, 2012 at 1:18 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Isn't RCSA standard and hooked up on the Sports ? It is on mine .
  6. Mar 31, 2012 at 1:20 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Beats me.
  7. Apr 1, 2012 at 8:59 AM
    Patmac
    Pat
    Chesapeake, VA
    14 TRD Sport
    sounds good. thanks fellas
  8. Apr 1, 2012 at 10:06 AM
    joes06tacoma
    Joe
    Central Coast, CA
    I think it's RSCA- Roll Sensing Curtain Airbags. OP has an access cab. No side airbags, or possibly just optional until 2009. My 2006 AC does not have the side airbags.
    My truck has the Clutch Start Cancel button in the center spot in the lower row of switches. The outer two on the lower row are blank.
    My 2009 company Tacoma has RSCA and traction control / auto LSD switch in those two outer spots.
  9. Apr 1, 2012 at 11:14 AM
    wado66
    wado66 Well-Known Member
    Could be one of a few things that can go in that area.
    1. Auto LSD. (Traction Control)
    2. RR dif Lock (Rear Differential Lock)
    3. DAC (Down Hill Assist)
    4. Clutch Start Cancel
    5. RSCA Off (disables Side Air Curtain)
    Below is my TRD Sport
  10. Apr 1, 2012 at 11:38 AM
    yakker1982
    yakker1982 Active Member
    Bay Area, CA
    12 DCLB 4WD V6 Sport
    As previously stated, most likely they are RSCA on the right and DAC in the center. However, just putting in the switches won't make you have those options. I wish it did. :)
  11. Apr 2, 2012 at 4:55 PM
    Patmac
    Pat
    Chesapeake, VA
    14 TRD Sport
    i want the traction control button how do i get it
  12. Apr 2, 2012 at 4:57 PM
    Patmac
    Pat
    Chesapeake, VA
    14 TRD Sport
    so you saying im not wired for it from the factory
  13. Apr 2, 2012 at 5:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I have a switch in my house like that..........and 3 that run the same light.....
  14. Apr 2, 2012 at 5:14 PM
    OZ-T
    Peter North
    British Columbia
    That's a 4 way switch
  15. Apr 2, 2012 at 5:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I thought so too.....but each one only has 2 wires in it.
  16. Apr 2, 2012 at 5:25 PM
    L J
    L J Well-Known Member
    Illinois
    07 4X4 SR5 TRD Sport DCLB
    What you can do is use the plug to the left in your picture to connect to the dimmer circuit. I used the solid green wire and green/white wire to power the light in an FJ cruiser aux light switch so it dims with the dash lights.
  17. Apr 2, 2012 at 5:27 PM
    Night
    Night Well-Known Member
    Canada
    '11 TRD OR AC MagGrey
    Banks Monster Exhaust, aFe ProGuard 7, 3M Film, UnderCoating, alpine 920 headunit, alpine 6.5 components, 20% tint all around, JL Stealthbox, PDX-V9 Amp, Avid Lightbar, Avid Sliders, Full Metal JackRabbit Tonneau, TRD S/C
    Conspiracy!
    OP maybe pre-wiring like how they already had the pre-wiring for fogs.
  18. Apr 2, 2012 at 5:34 PM
    Night
    Canada
    I may be interested, whats the pro's and con's of said project? And cost.
  19. Apr 2, 2012 at 5:40 PM
    Saskquatch11
    Saskquatch11 TRUCK YEAH
    if you have a light switched in 3 locations you'd have two 3 way switches and one 4 way switch, the 4 way in between the 3 ways. there should be two 3 wire cables at the 4 way.
  20. Apr 2, 2012 at 5:41 PM
    OZ-T
    Peter North
    British Columbia
    That's what I thought
    Stoopid Chris
