Unless I'm an idiot, got a warranty issue already
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JNG, Mar 20, 2019.
  1. Mar 20, 2019 at 4:43 PM
    JNG
    JNG [OP] Shitposter extraordinaire
    2019 Silver TRD OR DCSB 4x4 AT P&T
    Less than 300 miles and the locker won't engage.
    So I go out to a deserted country dirt road to make sure the various 4x4 features work. So I switch to 4hi at about 15mph. Good to go. Stop truck and put shifter into neutral, switch to 4lo. Put shifter into drive, good to go. Stop truck, press locker button, light flashes and will not engage. Upteen tries later following same procedure, locker engages. However I can only get the locker to engage a couple more times. Every other feature works as far as I can tell (crawl, MTS). Locker will not reliably engage. So am I an idiot or do I call dealer?
    2019 TRD off-road automatic
  2. Mar 20, 2019 at 4:53 PM
    Taco_Craig
    Taco_Craig Well-Known Member
    Craig
    2016 MGM Tacoma, DCSB TRD-OR
    RCI Sliders/Plates, Icon [Stage 3] Suspension
    There's lots of suggestions if you search hard enough on the forums, but... Try driving in an S-pattern (turn the wheels to one side or the other). That should get it to engage.
    Unless it's broken.
    RelentlessFab and doorsidedown like this.
  3. Mar 20, 2019 at 5:01 PM
    jnw32
    jnw32 Well-Known Member
    Dallas, TX
    2016 White Tacoma TRD Off-Road DCSB
    265/75/16 KO2s, SR5 Grille, TRD Pro skid plate, Husky X-Act Contour floor mats, Carhartt front seat covers, de-stickered, partially de-badged, Bilstein 5100s with one inch rear block
    I say call the dealer.
  4. Mar 20, 2019 at 5:04 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    The locker teeth need to align before it will engage. This usually requires driving in a slight turn to allow inner and outer wheels to turn at different speeds to line things up. Driving straight will not allow it to engage unless it just happens to be lined up before the button is pushed
  5. Mar 20, 2019 at 5:29 PM
    JNG
    I was stopped with foot on brake. I will try slowly moving the truck and see what gives.
  6. Mar 20, 2019 at 5:32 PM
    ICU1
    ICU1 Well-Known Member
    You need to be facing/going East when engaging your locker.
    Definitely a warranty issue.
  7. Mar 20, 2019 at 5:32 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    The rear wheels have to turn different speeds to each other to engage the locker unless it is magically perfectly aligned when you press the button. You must either steer and roll forward slowly, or if you are in a situation where you actually need the locker (one rear wheel wants to spin), it will lock as soon as one wheels turns further than the other.
    The locker, typically will not engage right away driving in a straight line on firm ground. You could actually drive for miles in a straight line before it has its chance.
    Taco_Craig and Chew like this.
  8. Mar 20, 2019 at 5:33 PM
    floodedkiwi
    floodedkiwi Well-Known Member
    Ken
    Naw'lins, Louisiana
    2019 GMC AT4
    Dog.
    Too funny, you know how long it took me to learn that... I had my truck at a dealer up in PA and they checked it out and it worked with no issue. I drove off and couldn’t get the bloody thing to work for love nor money, and the next year I was back in PA and my buddies friend just happened to mention this and Iv never had an issue since... That was 3 years before I got it sorted... sad I know...:rofl::rofl::rofl:
    Taco_Craig and bigmw like this.
  9. Mar 20, 2019 at 5:36 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    Damn, I knew I was doing something wrong all these years!
  10. Mar 20, 2019 at 5:45 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    I don't care how good the vehicle is... you can't get it to work until the teeth engage. Sometimes you just have to move something.
    Stocklocker likes this.
  11. Mar 20, 2019 at 5:48 PM
    Stocklocker
    17TRDORDCSBAT
    It is because it is a strong system that there is an engagement process. Knowing how it works, if it just “popped in like nuthin’”, I wouldn’t trust it.
    hiPSI[QUOTED] likes this.
  12. Mar 20, 2019 at 5:48 PM
    Woolybugger
    Woolybugger Well-Known Member
    Aaron
    2005 blk acess cab trd 4x4
    King coilovers
    I have a second gen and mine works every time but ocasionaly needs a lil coercing. Usually turning and rocking does the trick but ive never had it not engage.
    I would not be concerned yet.
  13. Mar 20, 2019 at 5:59 PM
    JNG
    OK I'm the idiot. I apparently am unworthy of driving an OR Tacoma. Just tried it 6 times with the truck barely moving this time and it engaged and disengaged properly every time. I was trying to be too 'gentle' with it earlier. I see where my error was trying to engage it while stopped. Thanks to all for the help.
    Taco_Craig, Mtn Mike, rlx02 and 9 others like this.
  14. Mar 20, 2019 at 6:04 PM
    floodedkiwi
    Ken
    Naw'lins, Louisiana
    2019 GMC AT4
    Dog.
    Well at least you learnt a whole lot faster than me....:rofl::rofl::rofl::rofl::rofl:
    StayinStock and tcjacado like this.
  15. Mar 20, 2019 at 6:08 PM
    Frankenstuff
    Frankenstuff Busy iracing
    Frankie
    16TRDORDCsb 4x4 & 2020 BMW M2 competition
    16 trd ORdcsb4x4 c4 swingout rear, cbi t3 front , arb lift,16"grabber x3 rtt, hilift,jerry cans,and sliders . 81 hilux trail donkey
    No worries I think everyone tries it at a dead stop first .
  16. Mar 20, 2019 at 6:09 PM
    cowsquatch67
    cowsquatch67 Well-Known Member
    This is the TW I know and love!
    *also enjoy long walks on a moonlit beach*
  17. Mar 20, 2019 at 6:11 PM
    JNG
    Yeah, I'm amazed I wasn't roasted alive over a bonfire.
  18. Mar 20, 2019 at 6:12 PM
    Frankenstuff
    Frankie
    Meh these threads are important for the next guy .
    Stocklocker and StayinStock like this.
  19. Mar 20, 2019 at 6:13 PM
    cowsquatch67
    Me too! I'm glad you asked before I eventually did!:anonymous:
  20. Mar 20, 2019 at 6:14 PM
    Frankenstuff
    Frankie
    Lol see helped already.
