Unlock both doors with FOB
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Deserted1, Jul 4, 2011.
  1. Jul 4, 2011 at 7:35 PM
    rpking
    rpking Well-Known Member
    Roger
    Ohio
    Tacoma 4x4 TRD off road
    painted engine cover, bed cover, color match door handles, window tint, seat covers, weather gaurd floor mats, TRD stainless steel cat back exhaust, front skid pan, bug deflector, custom holster mount in center console, OME 884X springs and shocks, 2" AAL, OME shocks
    the beeps piss me off so now I just pull out my sig 45 along with my key fob and hell i have found with a little practice I can fire at the same time the beeps go off problem solved
  2. Jul 4, 2011 at 10:24 PM
    Deserted1
    Deserted1 [OP] Hellion
    Lexington, TN
    4wd Super White
    Icons Front and Rear, Demello Offroad Bumper and Sliders
    you do know you can turn the beeps off right?
    (a) Open the driver side door and insert the key into the ignition cylinder.
    (b) Remove the key from the ignition cylinder and, within 5 seconds, reinsert the key and turn the ignition switch to ON.
    (c) After 10 seconds, the system enters answer-back buzzer switching mode.
    (d) Within 10 seconds after answer-back buzzer switching mode is started, if a transmitter button (the same button) is pressed twice, the answer-back buzzer setting changes (off to on, or on to off) to activate or disable answer-back by buzzer.
  3. Jul 4, 2011 at 10:26 PM
    Deserted1
    Lexington, TN
    4wd Super White
    Also no go as of tonight, I want to dig apart on the dash a bit more, I found my old subaru instructions and i bet its pretty close to the same, wiring color may be different but other than that they all use denso electronics.
    I tried to use where the stock alarm is tied in but that was no go, i found the unlock condition on the alarm wiring but when connected to the passenger wire it blew the fuse, so its gotta be somewhere else.
  4. Jul 4, 2011 at 10:28 PM
    cantac09
    cantac09 Official TW Igloo Builder
    Hugh Jass
    Saskatchewan
    tundra
    stock
    when i got a remote starter installed it unlocked both doors at once.
  5. Jul 4, 2011 at 10:46 PM
    808matt
    808matt Well-Known Member
    hawaii
    19 Ranger
    LMFAO! the first 2 responses made my day
  6. Jul 4, 2011 at 11:00 PM
    Underdog777
    Underdog777 Well-Known Member
    Gilberz
    '06 Stuckrunner
    Camburg LT.
    I only hit it twice if I know I'm gonna beat guts with the same chick again....
  7. Jul 4, 2011 at 11:08 PM
    Bfoster133
    Bfoster133 If i asked my dad for money, He'd knock me out
    Blake
    Thousand oaks, California
    2011 PreRunner TRD offroad
    15% Tint, 5100's at 1.75, Rear Diff Breather, CB radio, Black rattle canned rims, 265/75/16 Goodyear MTR, Magnaflow Offroad pro cat back, hi-lift bed mounted, shovel bed mounted
    hell i push it like 14 times; it pisses my girlfriend off with the beeps haha
    edit:
    if you do the math that ends up to 24 beeps... 24 glorious beeps
  8. Jul 6, 2011 at 1:27 PM
    sloppyjoe
    sloppyjoe They are more like guide lines.
    All Over
    Silver and simple
    Non
    Toyota wiring is some wierdo shit! I tried to figure out how to use an old school foot clicker for my brightlights but the wiring was so sketchy I was scared to do it for fear of burning my truck to the ground. I say click it twice..... See now that was not smart ass... But really I can see why they comment in that manner, I mean how hard is it to retrain yourself to hit it twice?
  9. Jul 6, 2011 at 4:39 PM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    The wireless receiver has 5 pins... it's probably something like
    power
    ground
    unlock pulse door one
    unlock pulse door two
    lock pulse both doors
    pull the receiver out and hook-up a voltmeter to it and test with your key fob... maybe you just need to put a jumper in there between two wires
    if you try this post back which wires are which
  10. Jul 6, 2011 at 11:07 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    I call shenanigans, got a schematic?
  11. Jul 6, 2011 at 11:11 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Read through this and I'm still trying to figure out what the point is... :stirthepot:
  12. Jul 6, 2011 at 11:16 PM
    Bfoster133
    Blake
    subb'd to see if it works
