unlocking and locking on its own
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jcj007, Feb 19, 2020.
  1. Feb 19, 2020 at 11:22 AM
    jcj007
    jcj007 [OP] New Member
    2017 Tacoma TRD 4x4 Off Road
    I have had an issue that has happen several times with my 2017 Tacoma. It has only been noticed when it is parked at my house in the garage. The truck will lock or unlock (I hear the beeps from the truck) without me or anyone else touching the fob. I have two fobs and they are about 30 feet away from the vehicle when this happens. I have only noticed this while it is parked inside my garage. I usually don't lock the vehicle when I park it in the garage. And when this happens it occurs two or three times in a 5 or 10 minute period. Anyone else have this issue or know what could be causing it? Thanks.
  2. Feb 19, 2020 at 11:25 AM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    Sounds like someone is trying to steal your truck
    iDrew, GreyBaldTaco and whatstcp like this.
  3. Feb 19, 2020 at 11:32 AM
    bbartol
    bbartol Well-Known Member
    Brandon
    Central Ohio
    2025 TRD Off-Road Premium in Terra
    I know this sounds weird but do you have any LED screw-in type bulbs in the garage door opener or ceiling lights? I ask because I had two in my garage door motor unit, the kind that look like normal light bulbs but they're LED.
    They severely interfered with my ability to use my remote garage door opener and key FOB. As soon as I went back to compact fluorescent both problems went away. Just something that crossed my mind when I read this and you said it's in a garage.
  4. Feb 19, 2020 at 11:34 AM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    My garage door opener specifically mentions NOT using LED's in the manual.
  5. Feb 19, 2020 at 11:36 AM
    bbartol
    Brandon
    Central Ohio
    I wouldn't be surprised if mine does too, I don't know. I installed it years ago and just popped some bulbs when while I was upgrading the rest of the lights in my house and then I started noticing the problems so I took them out.
    TimC and jmneill[QUOTED] like this.
  6. Feb 19, 2020 at 12:17 PM
    CaptAmerica
    Cap
    In a van down by the river
    Gen 2.9 DCLB TRD Sport w/tech
    Stickers and not enough wax
    It's haunted. You need to get a young priest and an old priest...
    auskip07, Foster Imposter and DWD484 like this.
  7. Feb 19, 2020 at 12:19 PM
    Dryvah
    Dryvah Well-Known Member
    MA
    2019 Tacoma TRD
    Mine does this occasionally as well.
  8. Feb 20, 2020 at 4:43 AM
    CTF
    CTF Well-Known Member
    2017 TRD OR
    That’s just weird. Could the key fob have moisture in it?
  9. Feb 20, 2020 at 4:46 AM
    Dryvah
    MA
    2019 Tacoma TRD
    I've noticed while washing the truck around the drivers side handle, fob in my pocket, the truck will lock and unlock as that area gets wet.
    Anyone else experience that?
  10. Feb 20, 2020 at 4:51 AM
    CTF
    2017 TRD OR
    Yep that’s normal too and might be related. Maybe something in that smart door handle is getting wet and shorting.
  11. Feb 20, 2020 at 5:57 AM
    CTF
    2017 TRD OR
    Brings to mind high pressure washing. I don’t like the idea of it and won’t allow the guys at these car washes to use them on my vehicles. It pushes water in places it wouldn’t normally be able to go.
  12. Mar 28, 2022 at 6:17 AM
    TRyanOC72
    TRyanOC72 Well-Known Member
    Tim
    2020 Tacoma SR5 4WD
    My 2020 SR5, key fob and key start Tacoma keeps unlocking itself during the night. I lock it everytime I get out of the truck and go inside. I've been extra careful not to bump the fob after the first few times I noticed it. I'll go to unlock it in the morning and it's not locked. Disturbing and annoying problem. Anyone find a fix for this yet?
  13. Mar 28, 2022 at 7:50 AM
    grandpawmoses
    grandpawmoses Dirty Old Man
    David
    2021 Tacoma Limited Nightshade
    No money
    Hmmmmmm. So I could construct a battery operated LED light bulb and take it for a stroll in the mall parking lot?
  14. Mar 28, 2022 at 7:58 AM
    Enigma8246
    Enigma8246 Well-Known Member
    Lee
    Central Arkansas
    2007 4Runner Limited 4WD V8
    I had a Ram 1500 at work that would lock, unlock, and roll windows down randomly. This is what it wound up being. I disassembled the fob, blew it out with compressed air, let it sit outside in direct sunlight for a few hours on a hot day, then reassembled. No more issues.
