Unobtrusive sub for Double Cab?
Discussion in 'Audio & Video' started by Kingfrog, Feb 24, 2011.
  1. Feb 24, 2011 at 2:58 PM
    Kingfrog
    Kingfrog [OP] Well-Known Member
    08 TRD Rugged Trail Edition
    Undercover,Pop n Lock, Hardwired GPS, Garage door opener , Scanguage II, wireless back up camera, X994 Basslink, ...Prefer stock and non invasive functional mods
    Any way to install a HU powered Sub unobtrusively in a double cab. Not looking for BOOM or rattle just some lower end fill.
    I don't want to remove anything stock..
    Maybe just throw a Bazooka in the back?
  2. Feb 24, 2011 at 11:54 PM
    DevL
    DevL Well-Known Member
    A head unit cannot power a sub. I cannot, with a clear conscience, recommend anything that does not require ANY modification to your truck. Even the factory junk JBL set up uses the driver's side rear storage.
  3. Feb 24, 2011 at 11:58 PM
    STR8_BEAST
    STR8_BEAST Well-Known Member
    Collin
    HB, SoCal
    07 PRERUNNER TRD OR
    MAGNAFLOW EXHAUST, SOUND SYSTEM, KENWOOD DNX 7140, WINDOW TINT, REAR TSB, FRONT COIL SPACER, SATOSHI MOD, BHLM, WHITE CALIPERS, CB RADIO W/4FT FIRESTIK, MAGLITE MOD
    Your gonna need to get a stealth box.
  4. Feb 25, 2011 at 10:00 AM
    Kingfrog
    The HU I am looking at has a separately powered 70Watt Sub output. Plenty for a small cab at lower listening levels. The idea of a Sub for me is to hear the entire Freq range at lower levels. I just don't want to remove panels to install a sub. Maybe a portable box would do fine. I just don;t like carving up a stock truck. I had a Bazooka years ago and it filled the lowend nicely. If I decide to go with an HU without a powered sub output I will look for a "throw in the back solution"
    Maybe this would work on the floor behind the drivers seat. I don;t carry passengers and usually keep the back seats down.
    http://www.crutchfield.com/p_236RT8PT/MTX-RT8PT.html?tp=114
  5. Feb 26, 2011 at 6:34 PM
    ComaTosin
    ComaTosin The Not So New guy
    Drew
    Atlanta, GA
    06 SR5 PreRunner
    see my sig
    whats the big deal with removing a panel to install a sub? to each his own but I gotta say - its really easy to install stuff in tacos. Most everything "pops" right out. You'd be much better off to go ahead and buy a small amp and a shallow sub/box.
    just my .02.
    good luck
  6. Feb 26, 2011 at 6:43 PM
    crazyengineer
    crazyengineer Well-Known Member
    patrick
    Bristol, TN
    05 Tacoma SR5 TRD Offroad
    K&N Cold Air Intake, Warn Winch and Bumper Guard, Wet Okole Seat Covers, Undercover Bed Cover, TRD Kenwood Head Unit, Infiniti Speakers, JL 13.5 inch pancake sub
    this takes a little bit of modification, but not too much, just popping out the plastic in the back
    put a JL 13.5 inch pancake sub behind the back seats, i have pic of mine, you cannot tell it is there unless you fold the back seat down, and if you are wanting the storage, you only lose the space behind one, and you still get some of that space (i store a pack rod, reel, and small tackle box in the same area)
    here are some pics of what mine looks like
  7. Feb 26, 2011 at 6:44 PM
    crazyengineer
    patrick
    Bristol, TN
    oh, the sub is powered by an amp that is right next to it, I highly doubt you will find a sub that can be powered by your head unit though
  8. Feb 26, 2011 at 6:51 PM
    TacoDawgfan
    TacoDawgfan Hunker Down You Hairy Dawg!
    Georgia
    2011 Silver 4x4 TRD Sport w/JBL
    5100's at 1.75, Rear leaf TSB, Moto Metal 951 16x8, BFG TKO2 265/75/16, AFe Stage 2 CAI w/pro dry filter, Kenwood DDX374BT installed with Idatalink Maestro kit, Access Loredo tonneau cover, N-Fab steps, Tinted windows, EGR in channel vent visors, UGA drink coasters in the front cup holders, and a Graco car seat in the back seat
    Not sure where you can fit a Bazooka tube, but they do, or at least they used to sell the ones with their own amp built in.
  9. Feb 26, 2011 at 7:16 PM
    DevL
    WAY too big. The head unit with 70W sub output I have seen actually puts out under 35W and is a joke. Like I said... I cannot reccoemnd anything that is not garbage for what you describe. A Steathbox for a doublecab requires large amounts of modifications, including cutting the rear of your largest storage and drilling sheet metal for anchoring so I dont knwo why it was recomended... a custom box requires less cutting and an amp can be mounted under a seat.
  10. Feb 26, 2011 at 7:19 PM
    ComaTosin
    Drew
    Atlanta, GA
    06 SR5 PreRunner
    see my sig
    i bet a box could be made to fit in the floor area in the back but you'd still need an amp and a decent sub for the box if it is going to sound decent. IMO a sub running off of "70w" (read 35w) will sound pretty horrible if it sounds at all.
  11. Feb 26, 2011 at 8:28 PM
    Kingfrog
    Yeah I agree and after more research that any amp on the HU won't properly power a sub.II may try a powered sub like the MTX or Bazooka. I had a Bazooka years ago and it filled the low end to my satisfaction. I don't want "boom" Just a little more thump for those bass light recordings of classic rock tunes. I really don't want to remove panels and add amps.
    But I have decided on one of these HUs
    http://www.kenwoodusa.com/CompareProducts/?Models=KDC-BT945U,KDC-X994
    Thanks for the input...
  12. Mar 6, 2011 at 9:36 AM
    krudawg
    krudawg Well-Known Member
    Ted
    Goodyear, AZ
    06 PreRunner V6 SR5
    You might check out the Focal underseat powered subwoofer. It is self-powered and fits under the seat. I think the model number is FOCAL BUS 20. I had one installed in my 06 Access Cab Pre and the sound is awesome. Like you, I did not want to have a big box in the back seat of something that thumped me till I was deaf. It will run you about $600 for the unit. I had mine professionally installed.
  13. Mar 8, 2011 at 4:36 PM
    twells91
    twells91 Active Member
    Tyler
    Rabun County Georgia/Athens
    07 Tacoma TRD Sport Double Cab
    N-Fab Perunner Light bar w/ KC Slimlites, N-Fab nerf steps, Revtek 3" lift w/ super springs in the rear and Bilstein 5100s all the way around
    Is there any way to just "beef up" the stock 8" sub already in the truck? I know on aftermarket stuff you can adjust it on the amp(high and low pass). Is the amp in the truck accessible?
  14. Mar 8, 2011 at 4:44 PM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    The "Big Nig"
    Lifted, Locked, Armored. Ready To Wheel.
    I have a kicker 10" and I find that most of the time it's not even noticable. I even keep the sub volume up all the way. I would definitely not recommend anything less than that.
    by the way.. I have a MR. Marv box. look him up on here.
  15. Mar 8, 2011 at 5:41 PM
    Kingfrog
    Yeah I like that...That's along the lines of what I am looking for...Thanks.
  16. Mar 8, 2011 at 5:44 PM
    Kingfrog
    I don't have the stock woofer..And I don't want to remove panels to install a box unit and paste amps across the back wall. I think the under seat powered unit or similar will do the trick. I think people underestimate the power of 50 watts RMS in a small area. My Klipsche Promedia 2.1 computer speakers use a sub that is powered with 50 watts RMS and I rarely turn it past 10 o'clock in the room.....That volume in the truck would sound far better than the stock unit even at more volume to overcome the signal to noise ration of a vehicle.The idea is quality over quantity. I know people believe they need 1000 watts in a car. but for normal listening levels in a cabin 100-200 watts for a sub is plenty. My monitors MSP 7s are bi_amped at 80/50 and would also sound great in the car. Although I do have a powered sub I rarely use it for mixing.
    I know a little about audio as this is my work/playground.
    I do thank you all for your suggestions.
  17. Mar 9, 2011 at 6:16 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Search around some more. In addition to the Focal box I know that Infinity, Kenwood, JL Audio, Bazooka and a few others make smaller self-contained sub/amp boxes. Some are small enough to fit under the seat, some still need to go in back.
    Searching on here will give some Tacoma pics.
    BTW +1 on the sub power requirements. I'm running 200W to a 10" Arc Audio sub in a sealed box, plenty of thump when I want it. 1000W in a car/truck cabin,,, how many people put that much power to a home system to fill a space the size of their bathroom? Ahhh, but to each their own, we all overdo it with something in life!
  18. Mar 9, 2011 at 8:37 AM
    03taco
    03taco Well-Known Member
    someplace
    03 tacoma lifted 6in on 35s
    fabtech 6in lift, 35.12.50.16s,on mt classics
    i have actually looked into finding subs for our body style tacos and the best one i have found is by boss its a sub and the box and the amp all in one made to fit under seat and behind seats ill post the link
    http://www.amazon.com/BASS1200-10-I...F990/ref=sr_1_2?ie=UTF8&qid=1299688611&sr=8-2
  19. Mar 9, 2011 at 8:41 AM
    TacomaNC
    TacomaNC Active Member
    NC
    borla exhaust tintind windows
    I want to do the same thing
  20. Mar 9, 2011 at 10:23 AM
    Kingfrog
    Nice find and very good reviews a well..I have not started this project yet until I have all the goods in place so far
    The Kenwood X994/ SWI Kit is the HU I will likely get. Boss seems like Planet Audio kinda of budjet but as a sub only it can't be all that bad.
    I know some find it strange not to want to remove panels to install a sub and amp..But I am convinced I don;t need all that power and driver while running stock speakers and a middle of the road HU.
    I drive 14 miles a day 5 months a year. Don;t need anything elaborate
    Just "better" than stock. The HU alone will solve that problem. The sib is a nice addition. Since I do not listen to LO FREQ intense music like Hop Hop, RAP, Dance Trance, a smaller driver and less powerful amp will suffice
    Don;t want to rattle the truck loose...:D
