Unplugged my radio and lost my 4x4
Discussion in 'Technical Chat' started by floppyzebra, Aug 4, 2014.
  1. Aug 4, 2014 at 2:26 PM
    floppyzebra
    floppyzebra [OP] New Member
    Justin
    Florida
    07 SR5 TRD
    none
    I just recently picked up a 07 SR5 4dr 4x4 with 104,xxx miles on it and the previous owner misplaced a few things including the antenna so I don't have a radio. Seeing that I don't plan on getting rid of my truck anytime soon I wanted to upgrade the radio with a Bluetooth setup and unplugged the stock JBL deck to see what harness and connections I would need. Long story short, after I plugged it back in, I turned her back on and my maintenance required light was flashing along with the green 4x4 indicator as if It was trying to engage.
    the maintenance light shut off after a few seconds but the little green 4x4 indicator kept blinking. I put it in park and actually tried putting in 4H and nothing, tried 4L and nothing. Put the truck in reverse, rolled back a few feet and tried it again. Tried rolling forward and engaging it while rolling 5-10mph like I was reading in here earlier trying to figure this out. I searched around the forum and tried using the search tool as I'm a member of a few other forums and know to search for topics before posting. Also know that my 4x4 was working fine the night before as I was playing around in the dirt and had no issues. Is it possible that I unplugged something when I pulled the radio deck forward? I left the airbag plug plugged in and kept the truck on while doing all of this if any of that would matter.
    If anyone has any suggestions or has experienced this, any info would greatly be appreciated.
    Sorry if this post is in the wrong place.
  2. Aug 4, 2014 at 2:33 PM
    BAMS
    BAMS Well-Known Member
    Ray
    New Hampshire
    2011 TX TRD Access
    Stupid question, I'm sure, but did you short something out? Did anything pop?
  3. Aug 4, 2014 at 2:41 PM
    floppyzebra
    Justin
    Florida
    07 SR5 TRD
    none
    nothing popped that I know of, does the 4x4 switch run off a fuse? sorry If that's a dumb question on my part lol. not sure how the electronic 4x4 switch stuff works.
  4. Aug 4, 2014 at 2:44 PM
    BAMS
    Ray
    New Hampshire
    2011 TX TRD Access
    lol no I was saying that I was asking a dumb question. Do you have a test light? Check all the fuses. Although if the light is blinking, it's probably not a blown fuse. Start with the easy stuff first. Maybe take the negative side of the battery off and wait a bit, reconnect and see if it resets itself. Just a thought.
  5. Aug 4, 2014 at 2:45 PM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    yup...^^^^^^what he said...
  6. Aug 4, 2014 at 2:45 PM
    BAMS
    Ray
    New Hampshire
    2011 TX TRD Access
    Also, maybe you pinched a wire, clean the connections and re plug it in.
  7. Aug 4, 2014 at 2:46 PM
    floppyzebra
    Justin
    Florida
    07 SR5 TRD
    none
    It's poring rain here now, might just wait till I get my radio deck in before I pull everything back out. Sucks three days in, something bad has happened every day lol.
  8. Aug 4, 2014 at 2:47 PM
    BAMS
    Ray
    New Hampshire
    2011 TX TRD Access
    Well, it can only go up from here. lol
  9. Dec 5, 2018 at 9:49 AM
    Abline5
    Abline5 New Member
    2006 Tacoma
    Did you ever figure out what was wrong? I have the same problem.
  10. Dec 5, 2018 at 10:00 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Check the 4WD fuse see if it's blown
  11. Dec 7, 2018 at 10:27 AM
    Abline5
    Abline5 New Member
    2006 Tacoma
    Checked fuse and it’s ok. Any other suggestions? Any help would be greatly appreciated.
