Unsolvable electrical problem with window
Discussion in '2nd Gen. Tacomas (2005-2015)' started by leloh, Dec 18, 2023.
  1. Dec 18, 2023 at 8:17 AM
    leloh
    leloh [OP] Member
    2012 DCLB TRD SPORT
    First time poster and fairly new Tacoma owner, I drive a 2012 TRD Sport DoubleCab. A few months ago my rear passenger window was working on and off and being real finicky until one day I rolled it all the way down and the window never rolled up again. Since then, I've replaced and tested with a new master window switch at the driver side, the window switch at the rear passenger door, the entire window motor assembly, and the window has not budged. Every time I try, the 20A fuse blows, no matter what parts I try and how many fuses I use, that windows fuse keeps blowing. I'm completely lost as what to do next, and I was wondering if anyone here has had a similar problem or knows how to fix it. This is driving me nuts, thank you in advance.
  2. Dec 18, 2023 at 8:21 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    A repeat fuse blowing means you've got a hot wire shorting onto another wire or rubbing against ground somewhere. No easy answers here, you're going to have to dig through the wiring and find the damaged wire. Check the flexible sections at the door jambs where the wiring jumps from the door to the pillar
  3. Dec 18, 2023 at 8:24 AM
    Jackie Moon
    Jackie Moon Well-Known Member
    CO
    2021 DCSB OR 6MT
    Is there a limit switch out of alignment? Maybe the regulator is seized and causing the motor to draw too much current?
    Just guessing but the mechanism isn’t complicated so worth a guess. That would drive me nuts too.
  4. Dec 18, 2023 at 8:40 AM
    leloh
    leloh [OP] Member
    2012 DCLB TRD SPORT
    That's what I'll do next, was really hoping I wouldn't have to mess w that wiring harness.
  5. Dec 18, 2023 at 8:41 AM
    leloh
    leloh [OP] Member
    2012 DCLB TRD SPORT
    I thought it would be something similar which is why I bought an entirely new motor and regulator. Even when testing on that, fuse still pops.
  6. Dec 18, 2023 at 3:12 PM
    Jackie Moon
    CO
    2021 DCSB OR 6MT
    The other suggestion is a better path anyway, sounds more well-informed than my wild guess haha. Sometimes saying to yourself “this is an electrical problem” blinds you to the possibility of anything else so I thought I’d just make the suggestion. Good luck chasing down that short, I hope it’s obvious!
  7. Dec 18, 2023 at 3:21 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    I would start at the door with the problematic window, pull the shield at the door opening and inspect the wiring any place it bends or moves with the movement of the door. Static wiring lasts far longer [sans mice and such] then wiring that has to flex.
  8. Dec 18, 2023 at 4:04 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Does the fuse blow with both the master switch and the door switch? Or just one of them?
  9. Dec 18, 2023 at 5:01 PM
    Waasheem
    Waasheem
    2007 xrunner
    This probably.
    If you haven’t already, get a whole bunch of fuses. Or consider the resetable fuse thing, I considered buying them but they’re kinda expensive.
    You might be able to find the offending wire, cut & splice in a new wire to run along next to it instead of trying to find the exact spot where it’s bad. Ive done that before with good results. Actually finding the bad wire is the hard part, be patient. I’ll bet it’s something like instead of putting power to the motor, it’s shorting to ground where a wire has worn insulation.
    Perhaps someone will post up the wire diagram, if it has the wire colors thats gonna be a big help.
  10. Dec 18, 2023 at 6:16 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Just to be clear it's the P RR P/W Fuse that's blowing?
    Does it blow only when you hit the switch or as soon as you turn the key on?
  11. Dec 18, 2023 at 8:54 PM
    leloh
    leloh [OP] Member
    2012 DCLB TRD SPORT
    thank you!
  12. Dec 18, 2023 at 8:54 PM
    leloh
    leloh [OP] Member
    2012 DCLB TRD SPORT
    going to do this, you're totally right, thank you
  13. Dec 18, 2023 at 8:55 PM
    leloh
    leloh [OP] Member
    2012 DCLB TRD SPORT
    both, whenever I hit both the master and the door the fuse blows
  14. Dec 18, 2023 at 8:57 PM
    leloh
    leloh [OP] Member
    2012 DCLB TRD SPORT
    ive already bought a bulk pack of 20A fuses haha. I really do hope its a simple find especially with the diagram.
  15. Dec 18, 2023 at 8:58 PM
    leloh
    leloh [OP] Member
    2012 DCLB TRD SPORT
    thank you for including the diagram, also yes that's the one that's blowing. It goes only when I hit the switch.
  16. Dec 18, 2023 at 9:00 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    The same fuse blows when you hit the switch at the driver's door?
  17. Dec 18, 2023 at 9:09 PM
    leloh
    leloh [OP] Member
    2012 DCLB TRD SPORT
    yes, both the switch at the drivers door and the rear passenger switch
  18. Dec 18, 2023 at 9:14 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Now that's very interesting, that fuse only provides power to the switch at the right rear door. The master (driver's door) switch is powered by the D FR PW Fuse (30A).
    Does it blow both directions, only up, only down?
    What about if you unplug the right rear window switch?
    TnShooter likes this.
