Unstable idle, choppy hesitant acceleration [V6]
Discussion in '3rd Gen. Tacomas (2016-2023)' started by barcelona7568, Aug 25, 2019.
  1. Aug 25, 2019 at 3:53 PM
    barcelona7568
    barcelona7568 [OP] Well-Known Member
    CO
    16 DCLB, Stock
    Has anyone experienced the subject conditions and been able to improve or fix the condition(s)?
    I drive on 87 gas, 5,200 ft elevation, a/c on and off does not seem to matter. Vehicle is stock.
  2. Aug 25, 2019 at 5:04 PM
    Riotfunk
    Riotfunk Well-Known Member
    Taco TRD off road
    Try premium fuel
    Shellshock and Taco_Coma like this.
  3. Aug 25, 2019 at 5:16 PM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    Sound like it should be throwing codes. Have you had it to the dealership?
  4. Aug 25, 2019 at 5:17 PM
    Rustytaco71
    Rustytaco71 Well-Known Member
    2018 4Runner
    By any chance, if you floor it off a dead stop does it hesitate and takes it a second to go? If you do experience that there is a TSB that fixes that issue.
  5. Aug 25, 2019 at 5:20 PM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    Seems like the gas you're using, do you always stop at the same station?
  6. Aug 25, 2019 at 5:23 PM
    jmneill
    SE
    ^X2
    Ask Raj what's up with his gas.
  7. Aug 25, 2019 at 7:19 PM
    barcelona7568
    CO
    16 DCLB, Stock
    I drove 1600 miles in the past few days, different gas station each time. Are the symptoms for the TSB stuttering during moderate acceleration too? I did one turn left on to a highway and had to goose it, the truck seemed to stall and almost caused an accident
  8. Aug 25, 2019 at 7:32 PM
    Rustytaco71
    2018 4Runner
    Did you do it from a dead stop? If you did yes that’s the issue the TSB will fix. My truck experienced it from time to time while driving under about 10MPH-15MPH. After the TSB was done I had no more issues related to that.
    Lt. Dangle likes this.
  9. Aug 25, 2019 at 7:36 PM
    pkang0915
    pkang0915 Well-Known Member
    Bay Area, California
    2017 Tacoma DCLB OR (first time Taco owner)
    TOYTEC 2.5 kit, SPC UCA, N-fab side steps, TRD pro grille, FN FX PRO Wheels, BFG KO2S (265/70/17 C Rated), TRD Skid plate, Tyger Tonnue Cover, OVtune, Borla S type exhaust
    Try premium
  10. Aug 25, 2019 at 7:42 PM
    Flash1034
    Flash1034 Well-Known Member
    N/W Montana
    2023 Toyota Tacoma TRD Pro, Solar Octane, Automatic
    MESO Stage 1.5 LED Taillights Falken Wildpeak AT3W Tires in 265/75-16
    Dirty injector (s)
  11. Aug 25, 2019 at 8:48 PM
    Shellshock
    Iowa
    If it isn’t bad gas, it could be bad CPS
    ShirtTucker likes this.
  12. Aug 26, 2019 at 3:04 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Gas shouldn’t make that big of a difference. Get it to the dealer...
    MaTaco_4x4 likes this.
  13. Aug 26, 2019 at 6:27 AM
    MaTaco_4x4
    MaTaco_4x4 Well-Known Member
    2018 Tacoma Sport DCLB
    Octane doesn't make much difference for normal driving. 91 is recommended because it's not as twitchy (unstable) as 87, and tends to burn a bit cooler.
    This sounds exactly like "Take it to Toyota for service." to me.
  14. Aug 26, 2019 at 7:55 AM
    bhounds
    bhounds Well-Known Member
    Same symptoms as my friends 2019 Taco OR Pro ... at the dealer now getting a fuel fump replaced. Only difference, her's stopped running on the highway.
  15. Aug 26, 2019 at 5:35 PM
    barcelona7568
    CO
    16 DCLB, Stock
    I am going to replace the crank position sensor, will report back. Thank you all for the postulations thus far.
  16. Aug 26, 2019 at 6:26 PM
    SpeySquatch
    2016 TRD OR DCSB
    Sounds like a CPS issue (crank position sensor)
    TSB for that part is common
