Unsure what is wrong with my truck
Discussion in '1st Gen. Tacomas (1995-2004)' started by Baseboy1490, Feb 25, 2025.
  1. Feb 25, 2025 at 10:07 PM
    Baseboy1490
    Baseboy1490 [OP] Member
    2003 Red Tacoma prerunner
    Bilstein shocks, bull bar, Falken wildpeaks
    I have a 2003 Tacoma prerunner with a 3.4L engine, recently I replaced my power steering pump because it was making a lot of noise and I bled the system. Now my engine is making some weird noises and struggles to pick up speed, I am hearing some sort of grinding noise but it is more prevalent when I’m in gear, I read that it might be the torque converter but I don’t want to start pulling stuff out and replacing stuff at random. I notice that it makes the grinding noise between 1-3 gear. Could it be my transmission?
  2. Feb 25, 2025 at 10:27 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    How long have you owned the truck? How many miles are on it? Have you ever serviced the transmission at all? Did the sound begin only upon replacing the power steering pump?
    Do you get the sound when revving the engine in neutral all the way through the rpm range that would make your trans shift into those gears?
    You could also you put the rear axle on jackstands and cycle through the gears to see if the sound changes with reduced load in the gears - obviously use this method with a dose of safety to get more datapoints for the problem.
    Black97v6MT likes this.
  3. Feb 25, 2025 at 10:33 PM
    Baseboy1490
    I’ve had the truck for almost two years, it is at 240,371 miles, I have replaced the transmission fluid. The symphony of noises I hear right now started after I replaced the power steering pump. I was watching a few YouTube videos and one video where a truck made a similar noise was a Tacoma that needed a new belt pulley near the AC, I’ll need to get a stethoscope to try and pinpoint the noises when I do what you suggested. I appreciate you reaching out and I’ll update when I’ve done some testing
  4. Feb 25, 2025 at 10:35 PM
    Baseboy1490
    I also replaced the timing components and water pump about a year ago but I need to go back in and replace the cam seals because the ones I replaced leaked
  5. Feb 25, 2025 at 10:58 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    How long was it after the pump was replaced - just curious because it’s not really related to the trans but if the sound started right after it could be a bad pump although if you’re experiencing power loss then I’d imagine you’d get a lot of problems from your power steering if the new pump was locked up enough to be noticeable in terms of power loss. Just trying to determine the pump r&r is not related to the transmission issue you’re thinking is happening now.
    @gearcruncher
  6. Feb 25, 2025 at 11:03 PM
    Baseboy1490
    I want to say it was a couple days after the pump replacement
  7. Feb 25, 2025 at 11:04 PM
    Baseboy1490
    Do you know if I am able to post videos from my phone on here I’m sure it would help with diagnosing my issues
  8. Feb 26, 2025 at 8:31 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    shankyjones likes this.
  9. Feb 26, 2025 at 12:40 PM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    Yea I second what @Andy01DblCabTacoma said. You need to check your belts and pulleys up front. The grinding noise could be the AC idler pulley perhaps. Duralast makes an AC idler pulley that uses the same bearing as OEM and it's fairly inexpensive (around $30) at VatoZone
    ControlCar and shankyjones like this.
  10. Feb 26, 2025 at 9:38 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    RR’d pump…..understood
    did you clean the P/S screen that is incorporated in the p/S reservoir?
    new pump might be starving for ATF fluid bc screen clogged
  11. Feb 27, 2025 at 2:39 PM
    Baseboy1490
    Update for everyone it was the idler pulley, I replaced it and the noise was gone, as for the “transmission issue” I was having I guess it was in my head as I was not accelerating normally due to the noise the pulley was making I want to personally thank everyone for their help I really appreciate the input you guys are awesome.
