Unused connectors
Discussion in '4th Gen. Tacomas (2024+)' started by Rvca21, Jul 24, 2024.
  1. Jan 27, 2025 at 10:05 AM
    #121
    Bites3370
    Bites3370 New Member
    @Wahhabm I have a 2024 Off-Road Hybrid also without the aux switches. How did you ended up wiring the switches? Looks really nice Thanks
  2. Jan 27, 2025 at 10:13 AM
    #122
    Rvca21
    Rvca21 [OP] Active Member
    Frosty 24
    What wires go where on the caliraised switches? I got mine installed but both blue lights come on and when I turn it off both lights go off.
  3. Jan 27, 2025 at 11:42 AM
    #123
    Wahhabm
    Wahhabm Well-Known Member
    Monther
    Here you go. Yellow from tap a fuse. Cali raised didn't separate them so they both come on. I thought that is silly and I wanted them wired correctly by lighting the background and then when you switch them on, to get the additional one.
    Vitamins likes this.
  4. Jan 27, 2025 at 2:38 PM
    #124
    Rvca21
    Frosty 24
    In my case the wire harness from the accessory is red white and black. My red wire is your white and my white wire is your blue. I got the nilight harness. I’m sure if I put the yellow on an existing wire when dash lights come on it’ll work.
  5. Jan 27, 2025 at 3:11 PM
    #125
    caribe makaira
    Caribbean, Puerto Rico
    OP, you want black on the dash illumination negative so it dims with the rest of the dash switches.
  6. Jan 28, 2025 at 9:19 AM
    #126
    Rvca21
    Frosty 24
    Which wire do I connect the black (harness/switch) wire to? The location for my switch is on my center console near the shifter.
  7. Jan 28, 2025 at 10:52 AM
    #127
    caribe makaira
  8. Jan 28, 2025 at 11:30 AM
    #128
    Rvca21
    Frosty 24
    So I attach the black wire to the purple or green wire?
  9. Jan 28, 2025 at 11:49 AM
    #129
    caribe makaira
    Violet to switch black.
    Green to switch yellow.
    Black from aftermarket harness not used.
  10. Jun 8, 2025 at 9:26 AM
    #130
    CJBiggs
    CJBiggs Well-Known Member
    2024 4th Gen Tacoma OF Hybrid
    Revisiting this old thread. I am in a similar scenario as @Wahhabm. 4G TRD OF Hybrid, no Aux switches.
    But upon inspection of the AJ1 - I have the wires. But alas, no aux harness in the footwell sidewall. To clarify - I do have the prewired sockets for the relays and I have the prewired auxiliary sockets throughout the vehicle.
    Added note - Is the J92 connector, the connection needed for the switches?
    That all said - What am I looking for? A socket connection for the switches? Those wires from the AJ1 have to go somewhere, no?
    Thanks.
  11. Jun 8, 2025 at 10:25 AM
    #131
    CJBiggs
    Damn... it seems I'm really close on this. Is J92 the connection point for the Aux Switch wiring?
  12. Jun 8, 2025 at 9:25 PM
    #132
    Wahhabm
    Monther
    I gave up myself.
  13. Jul 29, 2025 at 8:31 AM
    #133
    kidcon
    kidcon tacoless
    Conner
    Cuse/Ft Bragg
    25 SR5
    hey ya'll sorry to revive a bit of an old thread that was pretty frustrating for others as well it seems, but I picked up a 25 SR5 and I have the relay terminals, no relays, all fuses, and appears to be all the wires in AJ1 but I cannot for the life of me locate the harness. the only thing I could find from underneath that had the same color connections for the aux switches were plugged into a silver box along the body. Not sure if anyone could help but thought I'd give it a shot. thanks guys
  14. Jul 29, 2025 at 9:00 AM
    #134
    CJBiggs
    I recommend going to this thread. I am in process of trying to utilize the existing wiring to run switches to accessories.
    https://www.tacomaworld.com/threads/riddle-me-this-auxiliary-wiring.861742/
    So you are aware, there are 2 connections to find. AJ1 & J92. Wiring from both go to the switches. This appears to be the only issue. Either finding or running wires to both to then connect Aux switches and pigtails.
    caribe makaira likes this.
  15. Jul 29, 2025 at 1:05 PM
    #135
    Wahhabm
    Monther
    I gave up trying to hunt it down. They really messed up by not completing this. Why install the wires in the fuse box to begin with?
  16. Aug 18, 2025 at 6:26 PM
    #136
    Pavementaco
    Pavementaco New Member
    How did you setup the garage remote?
  17. Aug 18, 2025 at 6:37 PM
    #137
    Wahhabm
    Monther
    I got the switch from online. Google it. Then I connected the internal of a garage opener to it. Hid everything in the side round hidden compartment.
    Pavementaco[QUOTED] likes this.
  18. Aug 18, 2025 at 7:15 PM
    #138
    Pavementaco
    Cool! Thank for the quick response, just ordered myself the remote, hopefully I dont fry the board trying to solder it
