unused switch locations
Discussion in 'Detailing' started by dayNnite4, Jul 13, 2011.
  1. Jul 13, 2011 at 7:17 PM
    dayNnite4
    dayNnite4 [OP] We can't stop here, this is bat country.
    Nick
    Southern NH
    '11 4x4 5-speed AC
    i want to get some aftermarket fog lights and my tacoma didnt come with stock fog lights. i was wondering how u pop off those plastic tabs that are in the spot where the stock fog light switch is..theyre on the far left of the dash and these 3 empty spots. any idea how to get them off without ruining anything??
  2. Jul 13, 2011 at 8:19 PM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    You have to pull dash apart to pop them out.
    Here's how you remove them for a 1st Gen
    It's easy though.
    1. Remove the 4 10mm bolts on the panel below your steering
    2. Remove the screw on the panel
    3. Pull off your AC knobs
    4. Pop off AC faceplate using a small flat head screwdriver
    5. Two screws, one on left..one on right where your AC controller is
    6. Pull out your change holder, remove screw behind that.
    7. Pull right below your upper vent..and the entire bezel will pop off.
    8. Next pull on your faceplate where your ignition is..will pop off
    9. Use a stubby phillips to undo the 2 bolts on your cluster bezel(they are above your cluster under the top of the dash)
    10. Pop off the bezel...disconnect hazard circuit
    11. Wiggle faceplate out..and you can see the switch pieces just 'pop' out
  3. Jul 13, 2011 at 8:22 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Pretty sure you just pop out the blanks on the 2nd gens
    The OP has an '11
  4. Jul 13, 2011 at 8:23 PM
    OZ-T
    Peter North
    British Columbia
  5. Jul 13, 2011 at 11:18 PM
    UndefinedTaco
    Justin
    Tracy, CA
    Toyota
    Oh, shoulda read his profile information!
    That's why I hate when people don't list it as visible..or list it in the thread:frusty:
    I never mess with the 2nd Gen, father likes stock shit! So I wouldn't know anything about 2nd Gens;)
  6. Jul 13, 2011 at 11:19 PM
    OZ-T
    Peter North
    British Columbia
    It is listed under his username
  7. Jul 13, 2011 at 11:19 PM
    JoeRags27
    JoeRags27 Because I can
    Joe
    Pawleys Island, SC
    08' Tacoma 5-spd Blacked Out
    Aftermarket tires/all black aftermarket wheels/LED interior floor MOD/Cargo bed net/Interior LED Mod/Plasti dip Emblems Mod/Plasti Dip grill Black/Black Headlight Mod/AFE Pro Dry S Filter
    Drop and Pop!!!
  8. Jul 13, 2011 at 11:34 PM
    UndefinedTaco
    Justin
    Tracy, CA
    Toyota
    It wasn't earlier :p
  9. Jul 14, 2011 at 12:15 AM
    OZ-T
    Peter North
    British Columbia
    It was when I posted 3 minutes after your first post
  10. Jul 14, 2011 at 12:58 AM
    UndefinedTaco
    Justin
    Tracy, CA
    Toyota
    Well it didn't show up for me, some sort of page malfunction :confused:
    I see it now though:(
  11. Jul 14, 2011 at 8:26 AM
    dayNnite4
    Nick
    Southern NH
    '11 4x4 5-speed AC
    thanks guys.. they do pop right out and although u cant reach it by hand, i can easily feed a wire thru the open switch spot down and behind the dash. thanks alot guys!!!
