Unusual issue
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1999prerunner, Nov 28, 2022.
  1. Nov 28, 2022 at 6:49 PM
    1999prerunner
    1999prerunner [OP] Member
    Dakota
    1999 Tacoma prerunner
    Horn upgrade
    Alright so I’ve got a pretty interesting issue going on with my 99 tacoma. Whenever I’m holding in the brake pedal and I turn the wheel past a certain point, I feel a click in the brake pedal but not the steering wheel for some reason. I don’t hear anything grinding, whining, or squeaking either. Anyone know what could be going on?
  2. Nov 29, 2022 at 7:29 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Have you inspected the area in the cab under the dash.
    I have seen aftermarket wiring caught on the steering shaft and brake pedal linkage that might cause your issue.
    Also possible something came loose is doing the same thing.
    Only when the wheel is turned both directions or only one?? When the brakes are applied.
  3. Nov 29, 2022 at 12:20 PM
    1999prerunner
    Dakota
    Horn upgrade
    Didn’t think of that. I do have a wire hanging down that goes to a pair of fog lights on my bumper. It feels that way as well when I turn both directions, but it’s slightly stronger when I turn right.
    Bivouac likes this.
  4. Jan 5, 2023 at 5:09 PM
    1999prerunner
    Dakota
    Horn upgrade
    Issue solved. My floor mat was shoved so far up that it was caught between the brake pedal and the steering column
    Kevins60, Taco critter and Bivouac like this.
  5. Jan 5, 2023 at 5:28 PM
    Bivouac
    I am Glad it was simple!
    Taco critter likes this.
  6. Jan 5, 2023 at 5:37 PM
    tcjacado
    tcjacado Well-Known Member
