unusual noise
Discussion in '1st Gen. Tacomas (1995-2004)' started by w/chunter, Nov 16, 2010.
  1. Nov 16, 2010 at 12:14 PM
    w/chunter
    w/chunter [OP] Well-Known Member
    Harrogate, TN
    04 SR5 TRD 4x4
    I've been noticing an unusual noise coming from my truck. It occurs when I first start out in the mornings. I back out of the driveway and when I drop it into drive and start to pull out, I hear this noise that sounds similar to air being let out of an air break. It lasts about a sec or so, kinds like shshssssss. Any idea what it could be? I've only noticed it when the weather has gotten colder.
    Thanks
  2. Nov 16, 2010 at 12:20 PM
    ywen
    ywen Well-Known Member
    I have the same noise.. ppl made fun of me when I described it.. I don't know what it's caused by..
    it's like a PEWWSSHOOEEEE
  3. Nov 16, 2010 at 12:22 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    sounds like the abs modulator
  4. Nov 16, 2010 at 6:21 PM
    w/chunter
    Harrogate, TN
    04 SR5 TRD 4x4
    So it is something I, we, should be concerned with? Thanks
  5. Nov 16, 2010 at 6:25 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    if it is the abs modulator,its just the pump priming the abs system.....which is normal
  6. Jan 25, 2011 at 2:37 PM
    hugo1914
    hugo1914 New Member
    2011 4x4 double cab
    dealer said this was normal, abs pump activating its kinda embarassing when you friends in truck with you
  7. Jan 25, 2011 at 2:46 PM
    Joben7726
    Joben7726 wes mantooth ™
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
    Sounds like your neighbors cat, the noise is that he is pissed bc you caught his nuts in a fan belt.
    But on a serious note, hope y'all figure it out!
