Unusual Sound From Rear of Truck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sprig, Jan 29, 2020.
  1. Jan 29, 2020 at 8:05 PM
    Sprig
    Sprig [OP] Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    Hard to describe but I’ll try. I have a 2009 DCLB v6 4x4 automatic. Mostly stock. 100,000 miles, well maintained. I had new rear brakes installed 4 weeks ago. Today for the first time when stopping, foot on the brakes, I heard this unusual sound. It happens as I’m slowing down and starts at about 15mph and continues intermittent until I stop. It’s coming from the rear and only when pressing on the brakes . It sounds kind of like when you have squeaky springs or suspension. It’s creak........creak.......Creak.........creak.......stop. I tried stopping using the emergency brake and it didn’t make the sound. I crawled under the truck but didn’t see anything that looked amiss. Again only when stepping on the brake 15 mph to stop.
    I’m taking it back to the shop that did the brakes and have them check it out. Anyone have any suggestions what it may be?
    Tacosail likes this.
  2. Jan 29, 2020 at 8:27 PM
    Tacosail
    Tacosail Well-Known Member
    Jerry
    Hermanville Heights, Ohio
    '13 white ACLB
    '17 wheels,int. Wipers , bed mat , relocate trailer plug , husky floor liners , Lund nerf bars, wet Okole seat covers- heat & lumbar.
    Can you or a friend jack up the rear wheels one at a time , pull off the tire and drum, and have a look for yourself ? If you can get a friend to ride in the bed in a big parking lot and listen to see which side the noise is on, to narrow it down first.
    Sprig[OP] likes this.
  3. Jan 30, 2020 at 2:00 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Did they turn the drums? Cheap pads out of round (arced is the term for pads that are rounded properly)? No grease on the pad contact area with the backing plate?
    Incorrect installation of springs and clips? Brake pad adjustment off? Possible rear bearings worn and slight wobble only noticeable when braking? That's a few.
  4. Jan 30, 2020 at 6:40 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Jack up the rear and hand spin the tire. Just simply needs a brake adjustment. I would even go further and pull the drum off to clean the hardware with brake cleaner.
  5. Jan 31, 2020 at 11:02 AM
    TakoLoko12
    TakoLoko12 Well-Known Member
    I actually recently had this same issue come up. I got a new cat back exhaust and installed it a few months ago and a month or two ago I started getting that same "creak" noise you described, on my rear passenger side. I jacked it up and looked to see of the exhaust tip was making contact. Not that I could tell. I also removed the drum and took a look in there but didn't see anything loose or broken. The drum pads still look decent as the truck only has 25,000 miles. The noise is still there. Im starting to think it might be something inside the axle.
  6. Jan 31, 2020 at 11:14 AM
    IL Capo
    IL Capo Well-Known Member
    Sidney BC Canada
    Did you check to see if your leaf springs were causing the noise....the weight of the truck on braking can cause the leaf springs to flex and make this noise. Try to lubricate the springs (in between as well) to see if this corrects the problem. If you can try to clean them out by washing or power washing them (let dry) before lubrication.
    Sprig[OP] and TakoLoko12 like this.
  7. Feb 2, 2020 at 7:48 PM
    Sprig
    Ken
    UPDATE - Friday I took the truck to the shop that did the brakes and does all maintenance and repair on my vehicles. That morning it of course wasn’t making the sounds. Explained the prob to the shop and they took the rear wheels and drums off, inspected, cleaned and adjusted the brakes. Half way home it started making a scritch....scritch....scratch... when braking under 15 mph to stop. Brought the truck back and the mechanic drove it and reproduced the sound. Said he didn’t know for sure what was causing it and to leave the truck and they would check it out. I’m dropping it off again tomorrow Monday.
    Drove it again today and no sound this morning. Drove it 50 miles with lots of stops and braking and finally started doing it again. I’m thinking in the mornings when it’s damp out and heavy dew the moisture is acting like a lubricant stopping the noise. After I drive and use the brakes for a while the moisture drys up and it starts making the noise.
    Again to me the noise sounds like an intermittent suspension creak but only happens when I am braking. I took it on a rough pot holed bouncy dirt road today (I was rocking and rolling the hell out of it) there was no noise from the suspension. Only when I brake. I’m wondering if there is something wrong with or some flaw in the brake pads. I think the shop is going to have a tough time isolating the problem/noise.
  8. Feb 2, 2020 at 8:05 PM
    badger
    badger Well-Known Member
    07 SR5
    Did they turn your drums or replace them? If they turned them, they might not have done the machine work properly. Even a new drum could have been machined off center. I would also check for a separated brake shoe.
