Unusual "Spark" at front of engine Anyone seen before?
Discussion in 'Garage / Workshop' started by BamaToy1997, Apr 19, 2014.
  1. Apr 19, 2014 at 10:34 AM
    BamaToy1997
    BamaToy1997 [OP] ASE Master Tech Vendor
    Bill
    Navarre, FL
    Multi-point tow hooks, new bored 2.7L engine, custom paint. 3 inch adjustable Fabtech front coils, 2.5 inch rear AAL. Front Aussie locker. LED bed lights. Full LED conversion interior and exterior. Relentless Fabrication front and rear bumpers. 4X4innovation sliders. BAMF bed rack. CVT rooftop tent.
    This is not Tacoma related, but I was just curious. A customer of mine came in this morning with her 2001 Hyundai. She was complaining of an intermittent "tick" noise from her engine. Sure enough we could hear it. It was somewhat consistent about every 8 seconds I would guess. Inspection showed something I had never seen or heard of before. Every 8 seconds a spark would arc from the harmonic balancer to the timing cover (an air gap of about 1/4 inch)
    I had never seen this before, but when I did some searching I found that it is actually pretty common, and a result of static electricity buildup. I would think under the hood, where there is a chance of oil or fuel leaks, that this would be a bit of a concern, but I have not found any evidence of a fire linked to this. Has anyone else out there seen this before?
  2. Apr 19, 2014 at 10:37 AM
    Gaunt596
    Gaunt596 Resident Otaku
    Matthew
    Central Maryland
    07 Double Cab Long Bed V6 SR5 "Patch Adam"
    Rain visors, Fog Light Anytime, Uniden 505xl CB Radio and 5 foot Firestick antenna, RTMR Fuse box, Mobtown Offroad Recovery Bar with 2" Receiver Tube
    bad ground maybe? causing electrical buildup and then it arcs to a ground, which in this case is the timing cover?
  3. Apr 19, 2014 at 10:43 AM
    BamaToy1997
    Bill
    Navarre, FL
    All research shows that it is static electricity buildup due to the outer section of the pulley being metal, with a rubber "damper" separating it from the main part of the balancer bolted to the crankshaft. I have heard everything from harmonic vibration to bad engine drive belts. We did add a 6 gauge ground strap cable from the engine block to the unibody, and that has done nothing to change it. It is quite interesting in that I have been doing this career for 25 years, and never saw or heard of this before, but it seems to be pretty common.
  4. Apr 19, 2014 at 11:07 AM
    Gaunt596
    Matthew
    Central Maryland
    hmm... i may have to go run my truck for a bit and see if it does this as well... is there a way to ground the pulley while this is occurring to see if it stops?
  5. Apr 19, 2014 at 11:22 AM
    robssol
    robssol Bang Bang
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, ACLB
    Fog lights mod, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, Plasti-dip rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED hood lights by tacodane, Rampage 22" LED light bar, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming switch.
    I did a little research in ESD about 20 years ago. ESD commonly is caused by a conductive surface rubbing against a nonconductive surface. So a rubber belt running on a steel pulley makes sense. Since you cannot reliably or safely ground the balancer, I would suggest insulating surfaces close enough for the spark to jump to. Or a second thought I just had you could try a small strand of wire jumping from the outer part to the inner part of the balancer. Hope this helps.
  6. Apr 19, 2014 at 8:33 PM
    BamaToy1997
    Bill
    Navarre, FL
    Thanks for the idea. Not sure how I can do it while making it look good. I'll figure something out. Just thought it was pretty weird.
  7. Apr 19, 2014 at 8:53 PM
    smmarine
    smmarine Well-Known Member
    Sean
    Melbourne FL
    1999 Tacoma 4wd, 2.7L Auto
    Harrop Eaton front and rear E-Lockers, Ultimate headlight upgrade, LCE header
    BamaToy is stumped? Haha ;)
  8. Apr 20, 2014 at 8:31 AM
    Watt maker
    Watt maker Keepin' the lights on!
    Ron
    Grants, NM
    08 4Runner SR5 V6 4x4, 2014 4Runner TE
    You will want to run two strands of wire with that method. Sort of like o-0-o in order to keep it somewhat balanced. I've never seen this issue before either.
  9. Apr 20, 2014 at 12:38 PM
    BamaToy1997
    Bill
    Navarre, FL
    Smart azz! :p
  10. Apr 20, 2014 at 12:46 PM
    Watari06V6
    Watari06V6 Faster than a speeding ticket
    Wounded Knee
    TRD-V6-SR5-06
    get that on film and send to Hondai. it might be a kaching in your wallet for reporting it first LOL
  11. Apr 20, 2014 at 3:04 PM
    Tacoma Mike
    Tacoma Mike 42 Year Toyota Master/ASE Master Tech.
    Southern Maine
    2011 Double Cab V6
    Large Storage Box, 02610 intermittent switch swap, "Hot Wire" Power Outlets, DRL Shut Off, Disable Fob Beep, Disable Seat Belt Buzzers, Parking Light Mod, Battery Tender, 4 Leaf Spring Pack, Rear Headrest Removal, Custom Ultragauge Mount, Factory Tow Package (7 Pin) Rear Diff Mod, Taco Lean Mod
    I've seen it bill.
    Same thing. After about 5 seconds an arc from the pulley to the tcover.
    Traced it to a bad fiber in the alternator belt. Swapped the belts and no more problem.
  12. Apr 20, 2014 at 5:08 PM
    smmarine
    Sean
    Melbourne FL
    Oz-T has been rubbing off on me, I apologize ;)
  13. Jun 4, 2014 at 1:17 AM
    robssol
    robssol Bang Bang
    Rob
    S. Wisconsin
    Did you ever figure this one out?:confused:
  14. Jun 19, 2014 at 4:34 PM
    o0oSHADOWo0o
    o0oSHADOWo0o Just Lurking in the Darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    BHLM with amber LED "eyebrow" strips and Angry Red Eyes, Black Depo Tail lights, Knight Rider Hood Scoop Mod, Amber Grill Backlighting, Amber Lamin-X Fog light film, Fog Lights Anytime Mod, Black T-Rex Grill Inserts, Red interior LED lighting, Go Rhino 5" Oval Nerf Bars, Modified side mirror turn signals, Drill-less license plate relocation bracket. OEM Bed mat. Weather Tech floor mats.
    I have not observed this on a vehicle, but I have seen this happen on conveyors that use rubber belts.
    There was a piece of machinery at a manufacturing plant I used to work at that had a long rubber belt (like 80 feet long) that ran across several pieces of plastic. In the winter when the air was dry and when no material was being transported by the belts, a spark about an inch long would periodically appear and discharge the static charge that had accumulated on parts of the conveyor.
    This is pretty much how a Van de Graff generator works.
