Unusual Tire Wear
Discussion in 'Wheels & Tires' started by Taco John, Nov 30, 2011.
  1. Nov 30, 2011 at 11:13 AM
    Taco John
    Taco John [OP] Well-Known Member
    Illinois
    4X4
    Have any of you tire gurus seen this before? The new passenger tires on the front of my wife's car appear to be wearing a little unusually. The inside of the tire feels like it has been flattened at a 45 degree angle compared to the rounded surface on the outside. There doesn't appear to be any cupping or feathering and I can't see where it rubs anything. The rear tires don't appear to have this.
    The tires have about 3k miles on them and the car had new shocks and was aligned when the tires were new. I also had the alignment double checked by a different shop when I first noticed the wear.
    I'm at a loss.
  2. Nov 30, 2011 at 11:16 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    Rubbing? :notsure: Thats the only thing I can think of that could cause this. Specialy since itson the front andnot rear. Are they different size than the old ones?
  3. Nov 30, 2011 at 11:27 AM
    Taco John
    Illinois
    4X4
    Nope. Same size. It is weird. At first I thought the camber is off but it checks out fine.
  4. Nov 30, 2011 at 11:46 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    That is weird, I'd be willing to bet then, that its rubbing somewhere. Maybe just somewhere its hard to see. Cause I would think if camber is off the whole tire would be worn down at an angle, not just that edge. GL with it, hope you figure it out.
  5. Nov 30, 2011 at 2:57 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Can you take a picture of it?
    Are you sure it's just no too much camber? That would cause a relatively uniform gradation from no wear on the outside to lots of wear on the inside though. You seem to be describing something more drastic.
  6. Nov 30, 2011 at 3:08 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    Does it look like this? Just about every Chevy Tahoe/Suburban that I've seen with older tires has had this problem, I'm not really sure what causes it as we've had it aligned. Have you aligned the tires lately?
  7. Nov 30, 2011 at 3:17 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    either a tie rod or control arm ball joint is worn and has play.
    easy to check. jack the front wheels up off the ground. grab the tire at the 12 o'clock and 6 o'clock positions and try to move the tire up and down. then, grab the tire at the 3 o'clock and 9 o'clock position and shake side to side. if you see or hear any movement or play of the ball joints/tie rod ends replace as necessary
  8. Nov 30, 2011 at 3:23 PM
    MonkeyProof
    SoCal- SGV
    forgot to add the wear can be attributed to worn shocks as well
  9. Dec 1, 2011 at 7:49 AM
    Taco John
    Illinois
    4X4
    It "feels" lke that tire looks but you really can't see it yet. I am trying to nip it in the bud before they do look like that!
    New shocks and recently aligned. I checked the suspension components avout 6 months ago, but probably worth a check again!
  10. Dec 1, 2011 at 6:30 PM
    BillJC
    BillJC Well-Known Member
    Bill
    Novato, CA
    2011 White SR5 DCLB 4x4
    It's the toe. It's out of whack.
  11. Dec 1, 2011 at 6:37 PM
    jbrenn
    jbrenn Well-Known Member
    allen texas
    10 sr5
    I agree I had this happen on my old ranger.
  12. Dec 2, 2011 at 8:17 AM
    Taco John
    Illinois
    4X4
    I've had the alignment checked at two different shops. I get a printout of the results from the machine. Both show it within spec.
