up and out lift - droppin a little cash ;)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 1YOTA6, Apr 19, 2013.
  1. Apr 19, 2013 at 8:18 PM
    1YOTA6
    1YOTA6 [OP] 1YOTA6
    Kyle
    Rochester, NY
    11 Db cab LongBed Tacoma 4x4 Sport
    ReadyLift 2.75 leveling lift, 1.5inch spider trax wheel spacers, Plasti-Dip wheels and front grill, Under carriage reverse spot lights, OTTRA Switches, wether tech floor mats, Toyo Open Country AT 285-70r17, on the waiting list for HomerTaco Grill :)
    Ok so im fixin to buy some spidertrax 1.5 spacers and want to add a 3inch lift with the front and rear of the truck even. whats the best combinations as some kits offer different lifts for the front and rear depending on if someone wants the front to actually be higher than the rear of the truck. I want the truck to sit level and not sure which sizes to order
    does any one know if they sell 2 inch hub centric spacers? just curious as one of my buddies was uncertain if his spacers were 1.5 or 2 and came on his 06' Tundra when he purchased it a few years ago
    where is the best place to make the complete order?
    I dont drive the truck to much off road or clime over mountains. Mainly just on the shit roads of upstate New York so I'm fine with just the shock spacers and blocks under the leaf springs(Ready-Lift) and sure with 3inches of lift a drop mount set up for the drive shaft is needed maybe?????
    thanks for everyones input
  2. Apr 19, 2013 at 9:02 PM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    ReadyLift makes a kit to level out the truck and give you a few inches of lift. The SST lift gives you 2.75"-3" in the front and 2" in the rear, or the option of 2.75"-3" in the front and 1" in the rear (PreRunner look). Both also have the differential drop spacers to help alleviate the extreme front CV axle angles. Spidertrax 1.5" is the widest I'd go, because I wouldn't use any other spacer/adapter other than Spidertrax. I've wheeled my 1.25" spacers for a year, and they've performed flawlessly.
    If you want a wider stance, honestly I'd just go with an aftermarket wheel with a different backspacing/offset then use a smaller spacer, like I did. The factory wheels tend to sit "inside" the truck some, and spacers will put it a little over flush with the fender flares.
    If you would like to order these, my shop (Rebel Off Road) is a ReadyLift and Spidertrax vendor. Check the link in my sig and give me a call on Monday. We drop ship these kits all over North America on a regular basis. I can probably even get you a TacomaWorld discount :thumbsup:
