Up Grade Shocks
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AHearing, Aug 28, 2019.
  1. Aug 28, 2019 at 10:55 AM
    AHearing
    AHearing [OP] Member
    Andrew
    2008 white Tacoma Prerunner
    I have an '08 4dr 2wd pre-runner, what are, if any good up grades to the stock shocks? 99% street driving - just curious
  2. Aug 28, 2019 at 10:56 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Bilstein 5100's. Inexpensive upgrade.
  3. Aug 28, 2019 at 10:57 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    5100s with the snap ring on the lowest setting. This will yield the best ride for cheap
    MtnMan307 and MattCowsmasher like this.
  4. Aug 28, 2019 at 11:06 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    This ^
  5. Aug 28, 2019 at 11:20 AM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    Bilstein heavy duty 4600’s are what you are looking for. Every time someone asks about shocks here everyone says 5100’s. The 4600 and the 5100 are basically the same shock only the 5100 is specifically designed and made for lifted trucks. The 4600’s are made for stock (not lifted) trucks. The 4600’s cost a little less too. The 4600’s are good shocks for everyday driving, off road (not severe off road) and towing. If you have plans to lift your truck then get the 5100’s otherwise go with the 4600 heavy duty bilsteins.
    Here’s from an article on the two shocks - The 5100 series and the Heavy Duty shocks use the same technology internally. Both use the same internal valving and at stock height will ride the same (shocks for lifted trucks may use different valving settings in order to accommodate the extra weight of larger tires). Both shocks are pressurized with 360 psi of nitrogen to prevent shock fade and foaming of the shock oil. The outer construction of both shocks is identical as well with an extruded metal body rather for maximum strength and top of the line seals. The 5100 series and Heavy Duty 4600 series are both covered under Bilstein's limited lifetime warranty that protects against any manufacturer defects for the life of the shock.
  6. Aug 28, 2019 at 11:21 AM
    Corny Taco
    Corny Taco The Sauce
    Blake
    Columbus/Atlanta Georgia
    06 SR5 DCSB Prerunner
    -33 inch Nitto Ridge Grapplers -18 inch fuel kranks -Bilstein 5100s -OME normal duty dakars -Toytec/Eibach coils -Magnaflow off-road pro exhaust -Prinsu roof rack -nfab rock guards -EBay Faux Trd Pro Grille -Custom basshead audio build in progress
    This^^^
  7. Aug 28, 2019 at 11:26 AM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    The 5100s are a direct stock replacement but the fronts can be adjusted to preload your springs if you want to lift the front a little, but you can set them to stock height. The 5100's have a larger shock body than the 4600's and aren't that much different in price. If you do a lift, you need the longer rears (5160 or something like that).
  8. Aug 28, 2019 at 6:10 PM
    TacoTuesday1
    SD CA
    This guy's opinion (posted previously in a different thread) convinced me to try out/buy a set of 4600's
    just haven't installed them yet; planning to soon
    Sprig[QUOTED] likes this.
  9. Aug 28, 2019 at 6:13 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Find some take offs from a Trd off road 3rd gen. Will bolt right up, great ride, and give you a very slight lift in the front (1” at most). And they’re cheap.
    BassAckwards likes this.
  10. Aug 28, 2019 at 8:13 PM
    Sprig
    Ken
    You’ll love them. Put them on my truck at about 96000 miles on the original shocks/struts. It’s like a new truck. I’ve driven from California to Utah and back and been off road with them. It’s definitely not a Cadillac ride but you don’t want or expect that in a 4x4 truck. Did great on wash board dirt roads and 4x4 trails. On the highway they seemed to smooth out the road. Definitely stiffened up the suspension overall. Hope you like them as I do.
  11. Aug 31, 2019 at 6:11 PM
    TacoTuesday1
    SD CA
    feels better!
  12. Aug 31, 2019 at 11:00 PM
    Spizike231
    Spizike231 Pickin’ & Grinnin’
    Jesse
    Sacramento, CA
    2011 MGM DCSB TRD Sport 4x4
    When replacing stock with 5100’s and wanting stock height.. is there anything you need besides the shocks themselves?
  13. Sep 1, 2019 at 5:41 AM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Nope, just a spring compressor to move the spring over. You may want new top hats if yours are worn.
