up sizing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rainmaker1, Jul 27, 2018.
  1. Jul 27, 2018 at 8:17 AM
    Rainmaker1
    Rainmaker1 [OP] New Member
    mike
    2017 white tacoma 4x4
    3 inch lift
    what the largest tire can run on 2017 Tacoma with 3 inch lift? thanks in advance!
  2. Jul 27, 2018 at 8:18 AM
    Rainmaker1
    mike
    3 inch lift
    its a 4x4
  3. Jul 27, 2018 at 8:25 AM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    Depends on lift brand, wheels, tires you have in mind. Going over 2 inches with a 4x4 will cause problems.
    Use the search function. You will find lots of info
  4. Jul 27, 2018 at 8:27 AM
    M-cameron
    M-cameron Well-Known Member
    2017 Tacoma
    im at 3".....havent had any issues 30K later
  5. Jul 27, 2018 at 8:32 AM
    WSW3
    WSW3 @willwitecki
    Will
    Connecticut
    '08 Tacoma DCSB TRD Sport
    Scratches, dents, and a lot of miles
    40". Might require some trimming.
    There are many threads dedicated to this over on the wheels and tires forum, as well as on the suspension forum. There is no short answer to this, really. It depends on wheel backspace, tire width, what lift you're running, etc.
  6. Jul 27, 2018 at 8:44 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    The general rule seems to be 3" of lift you can fit 285/70/17s. Depending on the offset, backspacing etc...will determine how much you have to trim to eliminate rubbing. Some report little to none, some have to cab mount chop and trim plastic.
    Rainmaker1[OP] likes this.
  7. Jul 27, 2018 at 8:47 AM
    LivinOnEdge
    LivinOnEdge ¯\_(ツ)_/¯
    Land of The Lost
    Four wheels and a refrigerator
    Not hating on anyone, just saying. There is indeed ALOT of info on TW, sometimes though it's very difficult to sift through most of it. Lot's of different opinions, suggestions and circumstances that could easily change an outcome if one isn't too careful. Just my two cents.
  8. Jul 27, 2018 at 8:49 AM
    doorsidedown
    doorsidedown Well-Known Member
    stick to 285/70/17 and you’ll be okay. Worst case scenario you have to trim a little.
    @11Bguy
    Also, over 2” and you’ll likely need UCAs but it won’t necessarily cause problems. Stay under 3” and you’ll be fine.
    I know, I know, I’m in a second gen, why am I commenting here?
    11Bguy likes this.
  9. Jul 27, 2018 at 9:46 AM
    MGMTaco17
    MGMTaco17 Well-Known Member
    Orange County, CA
    2017 Tacoma DCSB TRD Sport
    2017 DCSB TRD Sport. TRD Pro Grille. Morimoto Elite 35W HID Headlights. Morimoto XB LED Fog Lights. Clazzio All Black Leather Seat Covers. 32" LED Light Bar Bumper Stealth Mount. BHLM. Raptor Light Kit. Leer 100R. Bilstein 6112/5100 set at 3rd notch. LT275/70-17 C-Load Hercules Terra Trac AT2. Bora .750" Wheel Spacers.
    If I had a dollar for every time I saw one of these posts..... unreal.
  10. Jul 27, 2018 at 9:52 AM
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    @Rainmaker1
    265/75r16 will clear.
    You'll need to do some trimming with 285/75r16
    Or the 17" equivalent
  11. Jul 27, 2018 at 9:52 AM
    Jason TRD OR
    Jason TRD OR SIBI BUILT LLC
    Sibi Built LLC Placentia, CA
    16 Tacoma TRD Off Road 4X4
    King suspension w/ compression adjusters custom valving and 700# coils. Icon DJ uca. Icon RXT leafs Option #3. Durobumps. Demello rock sliders. Demello 30” Light Bar Baja Hoop bumper with Smittybuilt X2O winch w/ Amber baja design fogs w/ single row Baja Designs S8 amber light bar. Brute force Fab HC rear bumper. Behind Grille Light bar. TRD Pro Skid plate. Pelfrey Mid and Transfer case skid. TC spindle and cam tab gussets. Pop and lock. Method NV wheels 16”. SpiderTrax 1.25” wheel adapters. Yokohama Geolandar M/T (315/75/16). CMC. Radiator core reinforcement. Pro grille. Tailgate inlays. Baja Designs A pillar Ditch lights. Leer 100 XQ shell w/ power locks. In bed mounted spare. Blacked out emblems. Bed Mat. Bed Stiffeners. K&N air filter. Black Headlight Mod w/ LED projectors. Wrap Armor Anti glare hood and bedside decals. American flag decals. Northstar 24F AGM Pro battery. Differential breather relocate to rear tail light. Prinsu Designs Cabrack and Cap rack. OVTUNE Sibi Custom performance 4.88 91 fuel AGM . Nitro Gear 4:88 gears. Mountain hatch tailgate insert. In bed mounted Krazy Beaver shovel with Relentless quick fist bedrail mounts. MESO ultimate turn signals. AJT Designs Quicksand Key Fob. ECGS front needle bearing bushing replacement. Tepui LoPro 2 RTT.
    Get back to work Kevin lol
  12. Jul 27, 2018 at 9:53 AM
    Jason TRD OR
    Or just have a carson CMC special:thumbsup:
  13. Jul 27, 2018 at 9:57 AM
    Clearwater Bill
    Billy
    Largo Florida
    255 80 17 or 255 85 16
    Full 33". Use OE wheels or ones with OE specs and no lift is required. Or cutting, chopping pounding.
    No additional parts, alignment issues etc.
    m603holden likes this.
  14. Jul 27, 2018 at 9:58 AM
    MGMTaco17
    Orange County, CA
    Instead of TacomaWorld, Tacoma Owners & Enthusiasts it should say "TacomaWorld, What Size Tires Can I Fit"
  15. Jul 27, 2018 at 10:00 AM
    Clearwater Bill
    Billy
    Largo Florida
    Or just have Suspension, Wheel and Tire subforums.
    Oh, wait...............
    Comb and MGMTaco17[QUOTED] like this.
  16. Jul 27, 2018 at 10:12 AM
    necrodiety
    necrodiety Well-Known Member
    Orlando
    2018 Silver TRD Sport
    OV Tune, Bakflip F1, Redline hood struts, faux pro headlights and tails, Meso: bucket, map and dome lights, fuse cover.
    And every picture should have requirement to go ahead and list what lift, tires, and wheels are on it.
  17. Jul 27, 2018 at 11:28 AM
    11Bguy
    11Bguy Well-Known Member
    Va
    2017 DCSB TRD
    Icons/ JBA UCA's
    I have 285/70r17's with JBA UCS's and all I had to do was trim a bit off the button fender flare.
    doorsidedown likes this.
