Upcoming Colorado Events
Discussion in 'Colorado' started by GeoTaco, Nov 14, 2011.
  1. Jun 25, 2012 at 8:39 PM
    #881
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    2011 Mall Crawler
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
    The new Sean266!
  2. Jun 25, 2012 at 9:05 PM
    #882
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    Soooo pretty!
  3. Jun 25, 2012 at 9:14 PM
    #883
    NativeTaco
    NativeTaco Mountain Man
    Travis
    Fort Collins, CO
    '08 DCLB
    ARB, OME, BAMF, ATO, Rigid, more... Mountain Man Limousine
    I am in for some 2 wheel action! Dual sports and scooters? No prob, I'll just be waiting around at stop points with NYCO ;)
  4. Jun 26, 2012 at 4:09 AM
    #884
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    I shall borrow the neighbor kids Razor and proceed straight to the bar at the end of the days ride. :D
  5. Jun 26, 2012 at 4:50 AM
    #885
    06rubi
    06rubi Well-Known Member
    Kenney
    Pueblo West, CO
    10 MGM (wife's truck)
    Debadged, tinted windows, 7 pin relocated, bed lights, 12 volt socket in bed of truck, on board air, auxiliary fuse box, grill craft, hella 500's, t-rex eyelids, pink budbuilt skids, icon remote resi coil over, camburg uca, alcan rear springs, ubolt flip, icon 2.5 remote rear resi shocks
    Not sure what springs you got but for 63's you are gonna need spring hangers and shackle mounts. Shock relocation is really needed to for full flex. Gonna need blocks and 6-8" shackles depending on desired lift. Taco springs just need spring hangers, can use stock shackle mounts. Could probably use the shocks you have for now but you'll want to do the same shock remount as you would with the 63's. 5" shackle should do the trick.
    For the front it's a whole nother can of worms. If you are putting rears up front you'll need spring hanger, IFS steering box and a mount, high steer kit, shock mounts, shocks and a driveshaft.
  6. Jun 26, 2012 at 8:11 AM
    #886
    csuviper
    csuviper Moderator Moderator
    Brian
    Broomfield, CO
    2012 Tundra Rock Warrior 5.7L 4x4
    3" Toytec Ultimate Lift, 315/70R17 Duratracs, RW Wheels, Grillcraft Grill, Toyota "Raptor" Lettering and more
    I think I have the plan for now but not sure if I can execute it in time. I am in need of a welder and someone to weld. I don't trust my welds at all. Plus I need to order the parts quick to get them in time to install.
    For the rear the plan is to use my old 07 Tacoma rear leafs. Starting with just the two long ones and will add leafs as needed. The stock rear is 48" long (20.5/27.5) and the 07 Tacoma rear is 55.5 (27.375/28.5). I will cut off the old spring hanger to the front and weld on new ones ~6 7/8" forward. I will leave the rear ones stock.
    The truck already has 6.25" long shackles eye-to-eye on the rear of the rear spring. Currently these are sitting nearly straight up and down so the added 1" to the rear will help put them at a better angle. The current setup is roughly a 6" lift from stock and I hope to reduce the height slightly to somewhere around 5" lift from stock.
    Current shocks and locations will remain the same.
    *Future plans: U-bold flips, center mount shock bar, weld on shock mounts to axle and get the correct length shocks.
    I chose not to do the Chevy 63 route because I already have longer springs that are free of charge. A guy I met out wheeling that owns a small one man off-road fab company told me the best route to go is Ford F150 springs that are I believe 57" long. My 07 Tacoma springs aren't far off from this length.
    Stock front is 45" long (22.5/22.5). Rear up font is 48" long (20.5/27.5). I am going to keep the stock front hanger for now (will weld on beefier ones later). The truck already has 6.5" long shackles eye-to-eye on the rear of the front spring. I will keep this location as well. Currently the shackles are sitting nearly straight up and down so the added length will will help put them at a better angle as well as move the axle forward 2". My only worry here would be that the added 5" to the rear will sit the shackle down to the point of hitting the frame. That's when the front hanger would definitely be needed. Again the current setup is roughly a 6" lift from stock and I hope to reduce the height slightly to somewhere around 5" lift from stock.
    The truck already has high steer kit. The truck is an 84 with solid front axle already so steering box should be ok. A flat pitman arm would be nice.
    Probably need a longer driveshaft. I was hoping that lowering the truck a touch would give me enough to keep the stock one. If one is definitely needed then I will have to wait on all of this till later.
    Installing some u-bold flips to the front. Current shocks and locations will remain the same.
    *Future plans: Shock hoops, correct length shocks, front hanger, flat pitman, drive shaft.
  7. Jun 26, 2012 at 8:44 AM
    #887
    Gramps
    Gramps
    07 TRD DC 4x4
    If you want another set to play with I have my 07 springs as well with the 1.5" AAL in them. I keep meaning to take them to recycle but if you want them you can have.
  8. Jun 26, 2012 at 9:32 AM
    #888
    csuviper
    Brian
    Broomfield, CO
    If you don't want them then yea, I might take them. From what I have read, people are cutting down leafs and making them 4-6 packs for the front.
  9. Jun 26, 2012 at 12:30 PM
    #889
    DOT
    DOT Well-Known Member
    Jobin
    Littleton CO
    2007 FJ
    3'' toytec lift
  10. Jun 26, 2012 at 12:40 PM
    #890
    Gramps
    Gramps
    07 TRD DC 4x4
    How quickly could you get them? I am getting pressure from my better half to get the crap cleaned up?:D
  11. Jun 26, 2012 at 2:07 PM
    #891
    ffemt2987
    ffemt2987 Shut up Hippie!
    Austin
    Golden
    Cement 3rd gen that was supposed to stay stock
    Rack, sliders, softopper, tjm bumper, eibach temp suspension
    If he doesn't take them I may throw them on my truck. I just have the TSB in the rear. So they'd give me 1.5? ... anyway. I'll be next in line.
  12. Jun 26, 2012 at 2:12 PM
    #892
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    What do you have up front? I liked the stance of your truck. I was thinking 5100's but just did a measurement and in the rear I'm 22.5" from the center of the wheel cap to the fender and I have 19.75" in the front so I don't think a 1.75 w/5100's will get it done. I do have the TSB done so that could be to blame for the difference. My front looks really low now.
  13. Jun 26, 2012 at 2:31 PM
    #893
    ffemt2987
    Austin
    Golden
    I have 5100's @.85 with eibach coils. It sits pretty much level but I am going to do either top plate spacers or new coils and drop the 5100s to 0" I still get rub even with trimming though.
  14. Jun 26, 2012 at 2:34 PM
    #894
    Ostrichsak
    Jer
    Those are the Eibachs with a 1.6" lift, right? So like 2.45" or so total lift up front? Stock rear then other than the TSB 4-leaf?
  15. Jun 26, 2012 at 2:53 PM
    #895
    csuviper
    Brian
    Broomfield, CO
    Go for it, they are yours. I was just going to play with pulling leafs apart to build my fronts and rears on the crawler. I could use the ones you pull off if you aren't going to use them. Another thought is that the leafs I pulled apart have a thick add on leaf for lift. That one combined with the block made it a 6" lift. I think the block was only 3" tall so the other 3 came from that leaf.
  16. Jun 26, 2012 at 3:28 PM
    #896
    ffemt2987
    Austin
    Golden
    Yeah, but I don't think I am at any more than 2" Even before the bumper and skid it was about the same. I measured and Mike "toytec ULK" had about another inch and he was at 2.75
  17. Jun 26, 2012 at 4:13 PM
    #897
    ffemt2987
    Austin
    Golden
    Eric... I guess I'll take 'em. PM me your address and I could probably pick them up tomorrow.
    I'm not sure how soon I will get them on but I would be happy to give you the old ones.
    Does anyone think it would be a bad idea to to top plates? I have researched and it seems to be a go with my current set up and should be the same as what toytech offers with their 3" lift with eibachs.
    I guess we should move this over to the BS thread....
  18. Jun 26, 2012 at 4:14 PM
    #898
    Gramps
    Gramps
    07 TRD DC 4x4
    PM me and we can figure out a time for you to come get them. Brian said they are yours. I just called the recycle place today so good timing. :D
    Or text me @ Three 0 Three Three 24-5 Three 47.
    Dope! Posted right after you!
  19. Jun 26, 2012 at 4:17 PM
    #899
    Gramps
    Gramps
    07 TRD DC 4x4
    PMed. Top plates should be no issue. I am running them on my Toy Tec coilovers now.
  20. Jun 26, 2012 at 4:38 PM
    #900
    Ostrichsak
    Jer
    I wasn't going to do a lift then I saw trucks like your plus had the TSB done and now my truck looks like it's a hybrid 4x4 (rear) and low rider (front) so I think I want to do something about it now. Considering just ordering up a front set of 5100's and seeing if I can run it up to 2.5" w/o running into UCA clearance issues. If I do I would either go back to 1.75" and deal with it being 3/4" lower or order up some Eibachs and go to 0.85" on the 5100's.
