Upcoming Oil Change
Discussion in '1st Gen. Tacomas (1995-2004)' started by rrosebr, Nov 17, 2010.
  1. Nov 17, 2010 at 10:54 PM
    rrosebr
    rrosebr [OP] Active Member
    Drew
    Blacksburg, VA
    04 4x4 Dbl Cab V6 TRD
    K&N Air Filter, K&N Oil Filter, Security System MOD, Line-X Bedliner, Fog Light MOD
    So I did an Amsoil "Engine Flush", drained, put the recommended 10w-30 Amsoil oil in and installed a K&N oil filter at around 52,500. My factory recommended 5,000 oil change is approaching and I want to know what some of y'alls advice is...Change everything (ie go to Mobile 1 and change the filter(what's the use in Amsoil)), just change the filter (another K&N, or something else?) or leave it for another 5,000 miles (or longer). Thanks in advance.
    Drew
  2. Nov 17, 2010 at 10:59 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Use the search button (upper blue bar), lots of information already out there about this topic.
    I'm pretty sure the majority (if not 100%) of the people always change both the oil & filter.
    Others who use synthetics, will still change it at regular intervals. Others will let the intervals go longer.
  3. Nov 18, 2010 at 11:52 AM
    thatSchusterguy
    thatSchusterguy Well-Known Member
    Cincinnati, OH
    96 X-Cab
    OME/881 Dakars Demello HD sliders Marlin 1200# Clutch Rust and Duct Tape
    Changing a full synthetic at 5k miles is a waste of oil, change the filter every 5k and go at least another 5-10k on the oil. As long as you aren't leaking from anywhere (i.e. contaminating it) that oil should keep its composition for 15+ thousand miles easily.
    In the end its your truck, so do what you feel most comfortable with...
  4. Nov 18, 2010 at 11:58 AM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    So for things like this is says to make sure engine oil is fully drained....how can you full drain it because oil is going to be dripping down cylinder calls and be "stuck" to the pan and on the parts, therefore you never really "fully" drain all the oil out.
  5. Nov 18, 2010 at 12:04 PM
    Janster
    Jandy
    Lancaster, PA
    Are you referring to switching to synthetics after using regular oil?
    Don't worry about it - you can mix regular & synthetic oils. You don't need to get every spec of oil out. Just let it drain like you normally would.
  6. Nov 18, 2010 at 12:06 PM
    08pretaco
    az
    No I was referring to engine cleaning detergents such as the Amsoil OP used. I know that synethic and non sythetic can be changed out and/or mixed :)
  7. Nov 18, 2010 at 12:09 PM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    Now that I am running mobil 1, I change the filter every 5k and oil every 10k.
  8. Nov 18, 2010 at 12:28 PM
    soccerkidbs
    soccerkidbs Active Member
    Brandon
    Southern Oregon
    2002 D\C Prerunner SR5 TRD
    6000k HID Head light kit, K&N CAI, 2" revtek lift, LED map lights
    You will be fine. Draining like normal will get rid of the engine cleaner. They would not sell it if a few drops left over would harm your engine.
  9. Nov 18, 2010 at 12:30 PM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Over the road truckers run synethic's in there rigs, they do an oil analysis from what a I can remember at 20 -30 K if it comes back favorable they run that oil 80K + and just change out the filter. So save your money boys.
  10. Nov 19, 2010 at 11:18 PM
    rrosebr
    Drew
    Blacksburg, VA
    Have you ever done an analysis?
  11. Nov 21, 2010 at 3:54 PM
    rrosebr
    Drew
    Blacksburg, VA
    I bought a K&N and I'm just going to change it right at 5,000. Then the next 5,000 I'll change the filter again and drain the oil.
