Upcoming onboard generator?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rap1973, Feb 20, 2021.
  1. Feb 21, 2021 at 2:53 PM
    #101
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    You really think people that can't even turn on a flashlight know what a main breaker is?
  2. Feb 21, 2021 at 2:56 PM
    #102
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    The better auto disconnects have ‘break before make’ switches. When you take a generator circuit online, it breaks the line power first.
    melikeymy beer likes this.
  3. Feb 21, 2021 at 2:57 PM
    #103
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Yes I have seen two male plugs on power cords if you don't get killed with that alone you flunked the Darwin awards try again.
  4. Feb 21, 2021 at 3:07 PM
    #104
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    I'm very interested as to how this Ford system works, AC generators usually are two pole so in order to make 60 cycles it has to turn 3600 RPM reliably OK overdrive it with with pulleys but unless it is some type of inverter system say like a Honda generator it gets complicated fast and seems like a lot of displacement just to turn the lights on. My guess you can buy a really nice generator for less than the Ford option
  5. Feb 21, 2021 at 3:16 PM
    #105
    melikeymy beer
    melikeymy beer Hold my beer and watch this
    2019 Tundra
    From Ford...
    The inverter uses dedicated power electronics to smooth out the voltage ripples and produce a pure sine wave at the outlet. Another benefit of the inverter is that it allows the engine to run at a lower and variable RPM as opposed to full throttle to provide the same capability, which results in lower emissions and noise and increased efficiency.
    Pro Power Onboard has vehicle mounted inverters, which are capable of generating 2 kW, 2.4 kW or 7.2 kW of output power. The output from the inverters are consistent and reliable power, which does not rely on the engine speed. The power generated by inverter (pure sine wave) is much cleaner than the power produced by conventional generators (modified sine wave).
  6. Feb 21, 2021 at 3:20 PM
    #106
    OrangeRa1n
    OrangeRa1n Well-Known Member
    Houston Area
    TRD-Offroad 2021
    Probably inverter-style since it works while you are driving; seems like the only way to make it work.
    It's just a lot of effort and cost for something that can be cheaper and more portable. It seems like it's oriented at construction crews or fleet cars, but that's a lot of wear and tear on the engine if it's running almost 24/7. I have no clue who the target audience is here.
  7. Feb 21, 2021 at 3:20 PM
    #107
    melikeymy beer
    2019 Tundra
    What I really need to know is when I sell my trailer and buy a motor home and go back to a mid size truck, will the Ranger offer this option?
    :crapstorm:
  8. Feb 21, 2021 at 3:33 PM
    #108
    melikeymy beer
    2019 Tundra
    The plot thickens
    The bottom line on F-150 Pro Power Onboard
    But what is it going to cost you? Well, first you’ll have to add the hybrid powertrain, which will cost between $1,990 and $4,995, depending on trim and configuration. Then you’ll have to add the available 7.2 kW Pro Power Onboard option, which is another $750. When we spec’d out a base XL with the SuperCrew and 5-1/2-foot box, added the hybrid and Pro Power Onboard – without any extraneous options – we were looking at a price of $43,760 including destination. We configured the Limited trim similarly and topped out at $74,420 – again without any additional options.
    https://pickuptrucktalk.com/2020/10...-2021-ford-f-150-pro-power-onboard-explained/
    Rock Lobster likes this.
  9. Feb 21, 2021 at 3:36 PM
    #109
    RushT
    North Texas
    So are we going to call these Picnic-up Trucks?
  10. Feb 21, 2021 at 3:49 PM
    #110
    melikeymy beer
    2019 Tundra
    Rock Lobster and RushT[QUOTED] like this.
  11. Feb 21, 2021 at 3:52 PM
    #111
    RushT
    North Texas
    If the shoe fits, I wear it.
  12. Feb 21, 2021 at 4:11 PM
    #112
    OrangeRa1n
    Houston Area
    TRD-Offroad 2021
    I'm pretty sure the Hybrid powertrain is not required (at least not for all of them). Ford stated in an article that non-hybrid powertrain models will have to have the engine running 24/7 to use the generator feature. I would assume that this implies that it is not limited to those models.
  13. Feb 21, 2021 at 4:42 PM
    #113
    Speedbird
    Speedbird Well-Known Member
    Fort Couch
    2017 TRD-OR
    Person I know. Half his neighbors have those whole house generac's... Many of them ran their 1,000 gallon propane tanks dry in 3-4 days. Not sure how full they were on day-1, but he said his costs ~$900 to fill.
    Talk about an emotional rollercoaster: Day-1, throw on whole house generator like a boss... Day-3/4 realize living large just cost you like $150/day.
    Rock Lobster and melikeymy beer like this.
  14. Feb 21, 2021 at 4:48 PM
    #114
    Panchovilla6192002
    Panchovilla6192002 Well-Known Member
    Arizona
    2019 Cavalry Blue TRD SPORT 4X4 DCSB MT 2003 Red ExtraCab MT 5 lug
    I’ll stay in my 150 degree arizona weather and worry about the next haboob.
  15. Feb 21, 2021 at 5:08 PM
    #115
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    There lies the trick of it. Sure, if you want to keep your pool circulated and the upstairs AC at 72, buy the whole house unit. But it'll cost in more ways than one.
    I never felt that need I guess. I just want to keep my beer cold and my internet on. :cookiemonster:
    The hammer and Grossomotto like this.
  16. Feb 26, 2021 at 5:54 PM
    #116
    TK-422
    TK-422 Toyota! Oh what a feeling.
    So Cal - SCV
    2015 4Runner TEP
    Toytech 2.5 lift BFG KO2 275-70-17
    Mine just arrived today. It will be connected to natural gas but can run on propane if needed.
    Grossomotto likes this.
