UPDATE 10/20/2024: Gentex Homelink Mirrors w/Blue Compass & Backlit Buttons for 2016-23 Tacoma
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by RJP869, May 23, 2018.
  1. Dec 11, 2018 at 7:03 AM
    _gray_knight_
    _gray_knight_ Well-Known Member
    SoCal
    '18 Mall Crawler
    Just washed
    Complete plug in play if you already have the auto dim compress mirror. 5min job.
    Toms 17 likes this.
  2. Dec 11, 2018 at 7:22 AM
    msp2640
    msp2640 Well-Known Member
    Plymouth MA
    2018 TRD OR DCSB
    The mirror I purchased had the quick connect with the 12 pin connector, which was plug and play for the existing mirror on mine (2018 Off Road model - has the tech pkg, but not sure if that matters). I'm not well versed in all things Tacoma, but I believe that if your truck has the built in compass and is auto dimming version, then its a part for part, swap. The OEM mirror was help onto the windshield with one torx screw, back out the screw, disconnect the wiring quick connector. The new mirror I received, had a "phillips" style screw included, so I removed it and reused the original Torx screw (same thread). Hung the new mirror on the windshield tab, tightened up the retaining screw, and reconnected the wiring connector. It took longer to type this, than to swap the mirrors. I only used a small screw driver set with the replaceable tips for the install. I found a you tube video to calibrate the compass, which was very easy. Hope that helps - Bill
  3. Dec 11, 2018 at 7:35 AM
    aiya
    aiya Well-Known Member
    NYC
    2019 White TRD Sport DCSB
    Ordered and received my Homelink mirror. It bolted right up and plugged right in. Took me longer to find my torx bits than to install it. Great upgrade if you only have the dimming mirror.
    Thanks, Bob!
  4. Dec 13, 2018 at 8:09 AM
    Marek2012
    Marek2012 Well-Known Member
    washington
    2012 Taco 2.7 4x4
    How much?
  5. Dec 13, 2018 at 8:26 AM
    aiya
    NYC
    I went with the used Gen4 mirror for $169.
  6. Dec 15, 2018 at 10:09 AM
    RJP869
    RJP869 [OP] Owner of Bob's Automotive Mirrors & More LLC
    Bob
    La Porte, Indiana
    I don't have a Tacoma, but lots of mirrors!
    Check out page 1 of this thread - used mirrors are $169, new ones are $299.
  7. Dec 15, 2018 at 3:36 PM
    Marek2012
    washington
    2012 Taco 2.7 4x4
    Thank you. Any idea if a homelink from a 2015 would work. I have one in my garage laying around but have not had time to see if it will plug in
  8. Dec 15, 2018 at 4:19 PM
    RJP869
    Bob
    La Porte, Indiana
    If it's the OEM 2014-2015 Tacoma Homelink mirror, you can make it work. Those mirrors have a 12 pin to 14 pin adapter. You'll have to unplug the harness from the back of the mirror (there should be a plastic cap covering the connector - slip a small screwdriver in the top so you can press down on the connector lock tab, then jiggle it loose from the mirror). Remove the clip that holds the adapter harness against the stem, pop off the plastic cover surrounding the 14 pin connector, and wiggle the 14 pin connector while sliding it up and off the bracket - sounds like an involved process to do this, but it's pretty quick and simple. Then you can plug your Tacoma's 12 pin mirror connector into the back of the '15 mirror and you should be all set. Hope this helps!
  9. Mar 6, 2019 at 2:02 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Waiting on mine to get here. Bob as great to do business with. This is the last mod for a while, Clazzios with heat, remote start and now the mirror with homelink. I will be using this mod everyday.
    Denteen likes this.
  10. Mar 6, 2019 at 6:33 AM
    TiHo
    TiHo Well-Known Member
    2018 TRD Sport
    I forgot to post in here but I ordered a used homelink mirror from Bob about a month ago and it is awesome. Bob was a complete pleasure to do business with and the mirror looks brand new. If I didn’t tell you it was used you wouldn’t be able to tell. Thanks for the great service and great product!
  11. Mar 6, 2019 at 6:57 AM
    dwillhere1
    dwillhere1 Well-Known Member
    Dan
    Surprise, AZ
    2017 TRD OFFROAD
    I sent you an email Bob. Looking for the Homelink mirror with blue compass and blue back lit buttons. Don't know if this is possible. Would prefer one of your quality used ones for price. Are you at all interested in trade in credit? 2017 Tacoma TRD off road. Do have the auto dim button and compass, same as a previous person that was asking about plug and play. I imagine mine would be plug and play also? Thanks!
  12. Mar 6, 2019 at 8:09 AM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    I got mine a while back from Bob - top notch service and excellent product.
    Highly recommend :thumbsup:
  13. Mar 9, 2019 at 12:08 PM
    VaToy
    Parts Unknown
    Just got mine yesterday, litterly 15 minutes and I had it installed, calibrated the compass and programmed all my garage doors. Bob was awesome, I spoke with him directly on Monday, smooth transaction. Highly recommend.
  14. Mar 9, 2019 at 12:36 PM
    RJP869
    Bob
    La Porte, Indiana
    Thank you for the kind words & I'm glad you are happy with your mirror! :)
  15. Mar 9, 2019 at 12:41 PM
    #35
    RJP869
    Bob
    La Porte, Indiana
    Thanks, guys! I really appreciate the comments, and of course, you buying the mirrors!! :hattip: I'm very blessed to have this business & many great customers!
    VaToy[QUOTED] likes this.
  16. Mar 9, 2019 at 7:23 PM
    #36
    Hichung
    Hichung Well-Known Member
    Arkansas
    '18 TRD OR DCSB Tech+Prem 4x4
    Definitely recommend getting a mirror from Bob. Installed my mirror (used model) a few months back and it’s so nice to have homelink integration again!
  17. Mar 10, 2019 at 12:35 PM
    #37
    RJP869
    Bob
    La Porte, Indiana
    Thank you for the recommendation! Much appreciated! :)
  18. Mar 10, 2019 at 1:10 PM
    #38
    VaToy
    Parts Unknown
    I second that. I have 3 doors to control, mine works perfect. So easy to program. It's a true plug and play. Mine was used as well but you would never know it. Bob was awesome to do business with. I spoke to him by phone, he emailed me an invoice, I bought it Wed and installed it Fri.
  19. Mar 10, 2019 at 1:42 PM
    #39
    Ascotta05
    Ascotta05 Well-Known Member
    NC
    So how much for just an auto dim mirror with compass and the wiring harness, for 2018 sr.
  20. Mar 10, 2019 at 5:05 PM
    #40
    Cl4aub
    Cl4aub Well-Known Member
    Montgomery, Al
    2019 TRD Sport 4x4
    I have the auto dim but not compass on my 2019 TRD Sport will I need a harness also to make the gen 4 work
