UPDATE 10/20/2024: Gentex Homelink Mirrors w/Blue Compass & Backlit Buttons for 2016-23 Tacoma
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by RJP869, May 23, 2018.
  1. Oct 27, 2020 at 1:07 PM
    #81
    deusxanime
    deusxanime Well-Known Member
    MN
    2020 Cement OR DCSB V6 6MT 4x4 Prem+AdvTech+LED
    It seems like it is for some. Or maybe a port option?
    My 2019 Sport with Premium + Tech package did not have the Homelink mirror. I traded that in for a 2020 Off-Road with Premium + Advanced Tech at the same dealer. I was all set to purchase this for my new OR assuming it wouldn't have it, but luckily I didn't because it was there already! So not sure why one came with it and one didn't, but it is nice to have!
    grogie[QUOTED] likes this.
  2. Nov 3, 2020 at 10:00 AM
    #82
    Dundiddit
    Dundiddit Well-Known Member
    Southern California
    2021 SSM TRD OR DCSB AT
    Interior: LED Map lights LED Dome light LED Vanity Lights LED license plate lights Rough Country Seat Covers JDM Car center console cover Center Console and Glove box tray and organizers Suspension: 2” front/rear spacers Wheels and tires: 17x7 +4 offset 4Runner TRD Pro wheels 285/70/17 Nitto Ridge Grapplers
    Does the Homelink work even when the truck is off? I have a 2021 and wondering if I need the cable adapter as well.
  3. Nov 3, 2020 at 10:02 AM
    #83
    grogie
    grogie Sir Loin of Beef
    2019 TRD OR AC, 2018 4R Limited, 2006 Jeep TJ
    For my 2019, yes the Homelink works with the engine off.
    Dundiddit[QUOTED] likes this.
  4. Nov 3, 2020 at 10:05 AM
    #84
    deusxanime
    MN
    Same with my 2020, works even with engine/ignition off.
  5. Nov 3, 2020 at 10:12 AM
    #85
    Dundiddit
    Southern California
    I guess I will take a multimeter to my plug and see if I get a constant to the pins as it says in the first thread. Kind of iffy to have them constantly on, but it is weird when the auto dimming function isn't on when the truck isn't on. Thinking it would be the same with the Homelink portion of it. If that's the case of its constantly on, might as well keep the transmitter in the car. I do like the factory look though and not having extra stuff in my truck. Thanks guys!!
    deusxanime[QUOTED] likes this.
  6. Nov 21, 2020 at 11:03 AM
    #86
    vanrynd
    vanrynd Well-Known Member
    dan
    West Chester, Pa
    2017 Off Road DCLB
    WIP
    Happy Customer Here.
    Thank you for excellent product and service !
    RJP869[OP] likes this.
  7. Nov 21, 2020 at 11:06 AM
    #87
    Hypoxic12
    Hypoxic12 Member
    Oklahoma
    2020 Tacoma TRD Off Road DCSB
    Remote tailgate lock, anytime camera, rough country tonneau, bed mat, LED interior lights, all weather floor mats
    Just installed my Homelink V4 on my 2020. Easy install and with the adapter it can't be used with the engine off. Thanks Bob
  8. Nov 21, 2020 at 1:35 PM
    #88
    DSRamsey13
    DSRamsey13 Well-Known Member
    '23 TRD Pro Solar Octane
    Center console organizer.
    Same-Same. Happy customer. Just installed on my '18 SPORT. Super easy. Also did the adapter because my TACO is parked outside of the garage. Thank you, BOB!!! @RJP869
  9. Dec 5, 2020 at 1:11 PM
    #89
    SR5TacoMike
    SR5TacoMike Well-Known Member
    2020 Tacoma SR5 V6 4X2 Metallic Grey Crew Cab Short Bed
    Great product and great customer service! This is such an easy install...takes more time to program. I would recommend this upgrade to anyone. Only need a T20 torque bit!
  10. Dec 5, 2020 at 1:41 PM
    #90
    RJP869
    RJP869 [OP] Owner of Bob's Automotive Mirrors & More LLC
    Bob
    La Porte, Indiana
    I don't have a Tacoma, but lots of mirrors!
    Thank you - appreciate the kind words! :)
    SR5TacoMike[QUOTED] likes this.
  11. Dec 5, 2020 at 4:04 PM
    #91
    mdh_us
    mdh_us Well-Known Member
    I just installed mine on the 2021.
  12. Dec 20, 2020 at 8:38 AM
    #92
    Tacodude2020
    Tacodude2020 Well-Known Member
    2021 TRD Off Road
  13. Dec 20, 2020 at 8:07 PM
    #93
    mdh_us
    I didn't have to use anything other than what was already there. Unplug the compass only mirror and plugged in the Homelink + compass mirror.
  14. Dec 21, 2020 at 6:52 AM
    #94
    RJP869
    Bob
    La Porte, Indiana
    Here's what we've observed about the 2020 & 2021 trucks in terms of that constant hot wire. Just about all of the 2020's, except for some super early production trucks, had the dead constant hot wire issue. For the 2021's, so far we're seeing that most don't have this issue and the constant hot wire is live. However...notice I didn't say "all"...though probably 85% of the 2021 Tacoma owners we've dealt with to-date could just plug the mirror in, there were a small handful who still needed the adapter. So my theory is that the problem carried over into early production 2021's and then was corrected part-way into production (it's just a theory...didn't do any in-depth research like charting production dates and such).
    DSRamsey13 likes this.
  15. Jan 2, 2021 at 12:58 PM
    #95
    n2xlr8n
    n2xlr8n Well-Known Member
    still looking
    I have a 2021 SR.
    two questions:
    1) Will the Homelink v4/5 mirror replace my stock no-compass model?
    2) If so, how exactly do I find out if need an adapter harness (remove the stock mirror and somehow check the correct pin on the connector?)
    Thanks for your time!
  16. Jan 2, 2021 at 1:09 PM
    #96
    RJP869
    Bob
    La Porte, Indiana
    Hi! To answer your questions:
    1. Yes, as long as yours has the factory auto dim mirror.
    2. If so, on the 12 pin connector you'll see three wires. Looking at the back of the connector with the clip on top, the top left wire is your ignition-switched wire. Fourth from the left is ground. And the single wire on the bottom row is what should be the constant hot wire. Using a voltmeter, check for roughly 12 volts with the ignition off between the wire in the bottom row and the ground wire in the top row. If you show to have constant voltage, no adapter is needed.
    Hope this helps!
    n2xlr8n[QUOTED] likes this.
  17. Jan 9, 2021 at 10:47 AM
    #97
    Brock1sampson9
    Brock1sampson9 New Member
    2020 Red ACLB Tacoma V6 XP Predator
    I didn't see this asked in the thread anywhere, at least not in the last year.
    I have a 2020 SR with the manual dimming basic mirror and no plug. The OP mentions there is wiring that must be connected to somewhere in the A pilar and information can be provided to assist.
    I would like to make this upgrade but I was hoping some information could be shared on the process before I start ordering. I'm pretty handy and confident but I don't want to get too deep into tering open the interior of my brand new truck.
    Thanks in advance
  18. Feb 15, 2021 at 7:11 AM
    #98
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    sent an email
  19. Feb 19, 2021 at 9:44 AM
    #99
    Taco_Coma
    South NJ
    2018 DCSB SR5
    Mine came today is there an install guid on the 2018+ The giant thing on the windshield has me confused. Doesn't look like the OEM mirror just screws off and lifts up
  20. Feb 19, 2021 at 10:11 AM
    #100
    DSRamsey13
    RJP869[OP] and Taco_Coma[QUOTED] like this.
